fredmiranda.com Login
This topic is in the 2009 archive. You can read it and like its posts here. It is read only.
Archive 2009Adobe gamma and calibration
Bsmooth
p.1 #1Adobe gamma and calibration
Just got a Spyder 2 and have calibrated my monitor.But the instructions say I need to not use Adobe Gamma.I did disable it in msconfig,but is there a way to take it out or disable it completely?
Its either that or I need to look at the screen telling me that windows is not running in a normal startup mode. Thanks
Apr 25, 2009 at 07:50 PM
James_N
Details
p.1 #2Adobe gamma and calibration
Do a search for a file named Adobe Gamma.cpl. Its usually located in the c:\windows\system32 folder. You can remove it and back it up elsewhere; then remove the entry in the Startup folder.
Apr 25, 2009 at 08:24 PM
ohenry
Details
p.1 #3Adobe gamma and calibration
Just remove it completely. You have no need for it.
Apr 26, 2009 at 03:45 PM
flash
Details
p.1 #4Adobe gamma and calibration
All you need to do is remove Adobe gama from your start up forlder in Windows. In later versions of Photoshop it is no longer set up to run automatically anyway, so if you have CS4 you will not need to do anything.
And in MS config there is an option to have the warning not display on startup.
Gordon
Apr 26, 2009 at 05:47 PM
Alan321
Details
p.1 #5Adobe gamma and calibration
Uninstall it (via Add/Remove programs in the Control Panel).
Then delete the files.
Then reboot.
Then probably do it all again because it can be a very difficult bugger to kill.
Then when you think it's really gone reboot and check again just to be sure.
Then do your proper calibration and be sure to never let any Adobe software installation re-install Gamma. That could mean doing a custom installation in future instead of the default (recommended) installation.
- Alan
Apr 27, 2009 at 05:28 AM
Alan321
Details
p.1 #6Adobe gamma and calibration
Oh, and if you want to be very thorough then get into the registry and remove all traces of Adobe Gamma.
Apr 27, 2009 at 05:30 AM
Bsmooth
Details
p.1 #7Adobe gamma and calibration
I couldn't find Adobe gamma .cpl,so I just deleted Adobe gamma from the startup.
Unluckily I still only have Photoshop CS,which is a bummer since I am doing primarily doing HDR,or should I say trying to do HDR.
From what I have read and understand Photoshop CS3 and 4 are the best as they have the merge to HDR feature ,which my CS does not.
Trying to merge the HDR and 3 images to make it out of via Trey Ratcliffs method is also proving to be somewhat of a challenge as the images are not lining up very well.
Apr 27, 2009 at 06:18 AM
James_N
Details
p.1 #8Adobe gamma and calibration
Adobe Gamma.cpl is a Control panel applet that's located in the C:\Windows\System32 folder. By default the folder is hidden so its contents do not show up in a search. You first need to unhide the folder by going to Windows Explorer, then click Tools > Folder Options and select the View Tab. Scroll down to the Hidden Files and Folders section of the tab and enable the "Show Hidden Files and Folders" option. While you're there you might also want to disable the "Hide extension for known file types" option.
Apr 27, 2009 at 07:45 AM
