Archive 2009 · Nikon lens for Micro 4/3 body?
snegron
p.1 #1 · Nikon lens for Micro 4/3 body?
Does anyone know if there are any adaptors that permit Nikon AI lenses to be used on a Micro Four Thirds body (like the Lumix G-1)? I have seen adaptors for Nikon AI to Four Thirds, but I haven't seen anything for Nikon to Micro Four Thirds.
Mar 12, 2009 at 03:32 AM
burningheart
p.1 #2 · Nikon lens for Micro 4/3 body?
I use my Nikon to FD adapter mounted on the FD to G1 adapter. I haven't seen any Nikon to G1 yet but several manufactors are stating coming soon.
Mar 12, 2009 at 03:39 AM
snegron
p.1 #3 · Nikon lens for Micro 4/3 body?
I read about a 4/3 to Micro 4/3, and I have seen Nikon to 4/3, but I wonder if there would be a problem using two adaptors between the lens and the camera?
Mar 12, 2009 at 04:14 AM
burningheart
p.1 #4 · Nikon lens for Micro 4/3 body?
I had no problems stacking adapters, as long as they don't leak any light and maintain the correct overall register distance..
Edited on Mar 12, 2009 at 04:24 AM · View previous versions
Mar 12, 2009 at 04:23 AM
Jonas B
p.1 #5 · Nikon lens for Micro 4/3 body?
I haven't found any problems using two stacked adapters. I use a cheap Leica-R-->4/3 adapter and then the Panasonic 4/3-->micro 4/3 adapter. I also use the same setup for my Olympus OM lenses (OM-->4/3 and the Panny adapter).
I would prefer having just one adapter between the lens and the camera but as long as there is no play between the parts i don't worry about the combinations of adapters I currently use.
burningheart
p.1 #6 · Nikon lens for Micro 4/3 body?
I also use the leica R to FD, FD to 4/3 micro combination.
Jonas
I may have to investigate your Olympus combo
Mar 12, 2009 at 04:26 AM
HansenTsang
p.1 #7 · Nikon lens for Micro 4/3 body?
Panasonic makes an adapter to use Olympus 4/3 lens to micro 4/3 body. So all you need is an adapter that hook up your Nikkor lens to an Olympus 4/3 body.
Mar 12, 2009 at 04:51 AM
HansenTsang
p.1 #8 · Nikon lens for Micro 4/3 body?
Here are some pictures which should speak 3000 words.;-)
The first one is the parts necessary to hook a Nikkor to the micro 4/3 like my G1.
The second one is what they looked like hooked up.
The third one is the result.
Mar 12, 2009 at 05:00 AM
gbharani
p.1 #9 · Nikon lens for Micro 4/3 body?
Wow. Not bad at all
Mar 12, 2009 at 05:03 AM
Jonas B
p.1 #10 · Nikon lens for Micro 4/3 body?
One more thing, now that i came to think of something that just isn't a repeat; Novoflex has announced a Nikon F-->micro 4/3 adapter, preliminary shipping in May. That may be good. OTOH, as a totally Nikon illiterate I don't know if there is any difference between Nikon F and Nikon Ai lens mounts...
Mar 12, 2009 at 05:08 AM
Jonas B
p.1 #11 · Nikon lens for Micro 4/3 body?
Now you speak!
Mar 12, 2009 at 05:09 AM
Jonas B
p.1 #12 · Nikon lens for Micro 4/3 body?
burningheart wrote:
Jonas
Some are really good, some are not. For example; the trusty old OM24/2.8 doesn't really handle the G1 pixel density. The OM50/2Macro and the OM90/2Macro are excellent (as expected).
For a medium tele lens the Voigtländer 75/2.5 (with a LTM-->micro 4/3 adapter) is hard to beat (with regards to size, weight, resolution, bokeh and price).
Just some findings, /Jonas
Mar 12, 2009 at 05:14 AM
burningheart
p.1 #13 · Nikon lens for Micro 4/3 body?
Jonas have you found a wide angle that handles the pixel density yet? I tried my FD 20-35 and 35-105 and a quick test with the Nikon 14-24 and just wasn't satisfied with any of them. The only one I have been satisified with is the Canon 7.5mm circular fisheye but it is still a fisheye and noticable in some shots.
Mar 12, 2009 at 05:21 AM
HansenTsang
p.1 #14 · Nikon lens for Micro 4/3 body?
Jonas, the only Nikon lenses I see a problem is the latest G lens. G lens doesn't have aperture ring on it so pretty hard to adjust the aperture. Unless we can adapt the Nikon G to Canon EOS adapter that 16-9 is making.
Just to clarify Nikkor AI or AIs has the Nikon F mount. Nikon has not change mount since the Rangefiner days.
Mar 12, 2009 at 05:43 AM
wjlapier
p.1 #15 · Nikon lens for Micro 4/3 body?
I haven't seen a direct Nikon F-mount to m4/3 adapter yet-I think Novoflex will have one eventually. There are several ways to do this. I found a Nikon F-mount>C-mount adapter I use with my C-mount>m4/3 adapter. Or I can use the Nikon F-mount>M mount adapter with a M>m4/3 adapter. Here is a pic I took with the second setup using the Minolta Rokkor 58/1.2 at 1.2.
Mar 12, 2009 at 05:21 PM
tom s
p.1 #16 · Nikon lens for Micro 4/3 body?
Novoflex samples are here:
http://dc.watch.impress.co.jp/docs/review/longterm/20090824_310525.html
Nov 13, 2009 at 11:25 PM
mawz
p.1 #17 · Nikon lens for Micro 4/3 body?
Novoflex is shipping the G-capable adapters as well as similar adapters for K and Alpha mounts (Which give aperture control on DA and FA J lenses for K mount and for all aperture-equipped Alpha lenses respectively).
Nov 14, 2009 at 03:49 PM
Kingfishphoto
p.1 #18 · Nikon lens for Micro 4/3 body?
I went to an Oly. demo at a lare camera store today, 11/14/09. They did have on display an Nikon to micro 4/3 adapter on display. They said it would work for Nikon lenses on the ep-1/2 bodies, and would focus to inf. Iam not sure if this is what the OP is asking for?, just offering what i saw.
Nov 14, 2009 at 06:33 PM
Navyblue
p.1 #19 · Nikon lens for Micro 4/3 body?
eBay seller Jinfinance used to have it (along with the Canon one which I have), and I have seen one in person. But it seems that it is no longer listed, may be you can ask him about it.
Nov 15, 2009 at 03:34 PM
seaum
p.1 #20 · Nikon lens for Micro 4/3 body?
snegron,
I have used the Voigtlander Nikon F to M43 adapter on my E-P1 for my 28 2.8 ai-s, 105 2.5 ai-s, 35 2.0D & 50 1.8D lenses. Works great. I got it from Photo Village.
Jack
Nov 15, 2009 at 05:49 PM
Kit Laughlin
p.1 #21 · Nikon lens for Micro 4/3 body?
Stepen Gandy has a Nikon F > µ4/3rd's adapter; see here.
hth, kl. I have one; works perfectly.
Nov 16, 2009 at 04:41 AM
