fredmiranda.com Login
This topic is in the 2009 archive. You can read it and like its posts here. It is read only.
Archive 2009Color Issues between lightroom 2 and PS CS4
wfournier
p.1 #1Color Issues between lightroom 2 and PS CS4
I have been having a heck of a time trying to sort this out. I am running a Macbook with OS X 10.5.6 with Lightroom 2.2 and PS CS4. I have a NEC 1970NX calibrated with a spyder3 pro that I use for editing. I feel like I do have a basic understanding of color management, but from what I am running into it seems like maybe I don't know as much as I thought I did. I cannot get the colors to be the same between lightroom and CS4. I tried changing the color space in CS4 to Pro photo (what lightroom uses by default I believe) but neither that nor any other color space I selected for CS4 made any appreciable difference. I did notice that when I told CS4 to save for web/device the color looked similar to the lightroom colors. How can I get the to be the same?
Here is an example of what I am looking at:
This is the same file open in both lightroom and CS4, the image on the left is lightroom and the one on the right is CS4. The lightroom image just looks dull and lifeless to me, almost desaturated. What can I do to get this all to play nice together?
Feb 09, 2009 at 11:06 PM
Nchakos
Details
p.1 #2Color Issues between lightroom 2 and PS CS4
lightroom delivers files to photoshop in "prophoto" color space... u should convert to the profile u want before u save it.
Feb 10, 2009 at 10:45 AM
v.bampton
Details
p.1 #3Color Issues between lightroom 2 and PS CS4
Check your settings against these screenshots: http://www.lightroomqueen.com/blog/2009/01/02/why-do-my-photos-look-different-in-photoshop/
If they're correct, try recalibrating your monitor.
Feb 10, 2009 at 01:57 PM
15Bit
Details
p.1 #4Color Issues between lightroom 2 and PS CS4
You're not alone - i have the same problem. Pictures exported from LR look a little less punchy and paler than if i open them in CS4 and then directly export. Mostly its not very noticable, but just occasionally it makes a real difference to a picture. As far as i can figure i've got the colour settings all correct and i'm converting to srgb on output (with ICC included) in both cases. I am monitor calibrated, also with spyder 3 (don't know if that is relevant). I'll be watching this thread for some helpful answers....
Feb 10, 2009 at 03:55 PM
wfournier
Details
p.1 #5Color Issues between lightroom 2 and PS CS4
ok I think I may have gotten this at least mostly sorted out. I was trying to look at this today with just my laptop monitor and could not see the difference, when I moved back to the dual monitor setup, the issue was back. I found that there is a newer version of the Spyder software than I was running, so I updated that and re-calibrated, that did not make a difference. I then noticed that I could not see the profile changing when I dragged the photoshop image window from one display to the other. So on a hunch I changed the "primary monitor" to my external monitor and now things seem to match. My guess is that since photoshop was running on my laptop monitor (menus and tools etc) that was the color profile that was being used. So no matter which display the image was on, it was using the profile from my laptop display. Lightroom however was switching profiles when dragged from one monitor to the other and then they didn't match.
Feb 10, 2009 at 05:08 PM
thedigitalbean
Details
p.1 #6Color Issues between lightroom 2 and PS CS4
...Show more →
Sounds like a bug in PS CS4. Was 'Hardware Acceleration' turned on in the performance panel? Its possible the bug could be related to that. If you have the time, definitely report it in the user to user forum.
Feb 10, 2009 at 06:06 PM
v.bampton
Details
p.1 #7Color Issues between lightroom 2 and PS CS4
15bit, it's screenshot time.... a Photoshop window overlapping the same image in Lightroom would work a treat. It may be because you're dropping to a smaller colour space, but it's difficult to tell without seeing what you're seeing.
Feb 10, 2009 at 10:17 PM
15Bit
Details
p.1 #8Color Issues between lightroom 2 and PS CS4
I can do better - two pictures. Number 1 was exported as a jpeg from lightroom with reduction in size to 800 pixels long edge at the same time (and sharpening turned on). Number 2 is sent to photoshop (edit image in CS4), resized and exported for web (no sharpening as reduction algorithm makes it look ok). Sending to CS4 as smart object makes no difference.
The "correct" image is the darker, more contrasty one (#2). If i look at LR and CS4 side by side they look the same and correct. The CS4 export looks the same as the image i see in LR. The export from LR looks more pale and less contrasty. If i load both exported images into CS4 and look side by side, the problem with the LR export is still there.
jools
#1
http://farm4.static.flickr.com/3353/3271613794_609ef60f76_o.jpg
#2
http://farm4.static.flickr.com/3370/3271614088_588c9f1644_o.jpg
Feb 11, 2009 at 01:50 AM
v.bampton
Details
p.1 #9Color Issues between lightroom 2 and PS CS4
Turn the sharpening off and try it again. That looks like the difference you're seeing is caused by the sharpened edges.
Feb 11, 2009 at 02:50 AM
15Bit
Details
p.1 #10Color Issues between lightroom 2 and PS CS4
I thought that too, but it doesn't seem to make much difference. Also, i would expect an image to become more contrasty, not less, upon sharpening.
Feb 11, 2009 at 08:16 AM
v.bampton
Details
p.1 #11Color Issues between lightroom 2 and PS CS4
Ok, try something else... I'm wondering if resizing artifacts could be at work. Try exporting full res, and comparing that.
Feb 11, 2009 at 09:25 AM
15Bit
Details
p.1 #12Color Issues between lightroom 2 and PS CS4
Tried that this morning. Export for full size jpeg with no sharpening, again done directly and via CS4. The same result as last time.
It interesting that the files from CS4 are about 10% smaller (in Kb) than those from lightroom, so there's obviously a different jpeg conversion routine in the different software.
Feb 12, 2009 at 03:18 AM
