fredmiranda.com Login
This topic is in the 2009 archive. You can read it and like its posts here. It is read only.
Archive 2009Rokkor 58 conversion kit
JimBuchanan
p.1 #1Rokkor 58 conversion kit
A recent poster, here, disapproved the modification of Rokkor lenses, as it distroyed the lens in some way. I have to be honest, I once refused to touch a mint Rokkor 17mm f/4 lens due to its condition and collectibility. Would I refuse to convert one today, probably not.
But, Minolta 58 owner/users don't have to make that tough decision, because here is the ultimate solution to modifying the getting more rare and mint collectible 58/1.2 lens.
This solution is for, say:
Rokkor 58/1.2 owners that have not converted their lenses to EOS mount. There should be a few left! Note: This is a non-destructive, reversible modification.
Rokkor 58/1.2 owners that have converted lenses and want to redo them for quality, appearance, or optical issues.
https://www.fredmiranda.com/forum/topic/726266/0#6573154
Jan 08, 2009 at 01:39 PM
Eric Gottesman
Details
p.1 #2Rokkor 58 conversion kit
I believe it's better to use such a great lens rather than put it on a shelf. The images I get from my 58 are worth far more than its monetary value.
PS nice work on the adapter!
-Eric
Jan 08, 2009 at 07:25 PM
guissimo
Details
p.1 #3Rokkor 58 conversion kit
This is perfect timing. I was getting ready to attempt the conversion. This was going to be my first conversion, so I've been putting it off since October I'll wait to see if I can get one of Jim's conversion kit instead.
That's true. That looks like a very nice adapter.
Jan 08, 2009 at 07:53 PM
cogitech
Details
p.1 #4Rokkor 58 conversion kit
Jim,
Nice job. I suspect you will be inundated by an onslaught of mirror issue complaints, questions, claims, etc. It would be prudent to explain all of that fully upfront.
Jan 08, 2009 at 07:59 PM
Jammy Straub
Details
p.1 #5Rokkor 58 conversion kit
Very cool. Now about the Nikon version...
Jan 08, 2009 at 10:08 PM
asbalyan
Details
p.1 #6Rokkor 58 conversion kit
I lost the screws during conversions (during un-screwing, it happened)...
Can I get just screws... 2 will work...
Jan 08, 2009 at 11:48 PM
JimBuchanan
Details
p.1 #7Rokkor 58 conversion kit
Hey, I'm struggling to get a 5D in place, so I can understand and offer a mirror solution.
By the way, a Minolta Rokkor lens has to go about 3mm further down the throat of a Nikon camera for infinity. You're asking alot!
Jan 08, 2009 at 11:49 PM
AGeoJO
Details
p.1 #8Rokkor 58 conversion kit
That's a lot too swallow . Just kidding!
Jan 09, 2009 at 12:25 AM
wmarcin
Details
p.1 #9Rokkor 58 conversion kit
Linking to Jim's "adjust infinity focus" guide.
https://www.fredmiranda.com/forum/topic/726266/0#6577191
Jan 11, 2009 at 07:23 PM
Jammy Straub
Details
p.1 #10Rokkor 58 conversion kit
JimBuchanan wrote:
Jammy Straub wroteVery cool. Now about the Nikon version...
I was really just giving you a hard time
I'm pretty sure ulrikft managed to do it with his D700 and clear the mirror. Keep up the good work, it's so nice to see people take on things like this!
Jan 11, 2009 at 08:03 PM
tootalew
Details
p.1 #11Rokkor 58 conversion kit
Recieved my conversion kit today, took less than a minute to install and now my 58 looks orginal, except for the lack of the tab on apereture ring. Very well machined, top notch all the way. I had set the infinity adjust on my lens to just clear the unshaven mirror on my 5D, and it now hangs on the return, but only at the infinity mark. I will re adjust so this won't happen, but its only a few thousands of an inch, meaning I should have sanded just a wee bit more. This lens is so easy to set infinity on any how, its not any issue. Hats off to Jim on this kit and his quick shipping.
Jan 12, 2009 at 07:09 PM
Ivan Lee
Details
p.1 #12Rokkor 58 conversion kit
why not convert to Minolta AF/Alpha mount?
Jan 16, 2009 at 04:51 PM
wkhc168
Details
p.1 #13Rokkor 58 conversion kit
...Show more →
Did you follow Jim's infinity adjust procedure? How do you adjust it such that it clears the mirror on the 5D? Please elaborate. Thanks
Mar 01, 2009 at 09:44 PM
rowan57
Details
p.1 #14Rokkor 58 conversion kit
A quick query about the Rokkor lenses, do i need to modify the lens/use this adapter, if wanting to use on the 40D? Or can i just use a basic adapter (If so, which mount do i need the adapter for?)
Cheers
Rowan
Mar 02, 2009 at 07:41 AM
JimBuchanan
Details
p.1 #15Rokkor 58 conversion kit
One thing to keep in mind, concerning the position of the lens group at the infinity setting (far off objects are in sharp focus). Regardless of adapter or method used to accomplish it, the rear lens housing will be in the same position and distance to the 5D mirror.
The 5D camera mirror, needing the most clearance from the rear lens elements, can be ground down. The rear lens element housing can be filed down, or a combination of both, can be used to achieve clearance. The last option I have heard of, is the user has sacrificed the infinity distances, in order to get the mirror clearance. (The lens stops short of infinity and the shortest distance to the mirror) just like my infinity adjusting instructions, one could use the adjusting screws of the lens to increase the mirror clearance, but loose the far off objects.
All crop sensor cameras, like the 40D, dont have this problem because the mirror is smaller and doesn't swing out as far.
There are no basic bayonet adapters for Minolta lenses to Canon cameras because the Minolta lens to sensor distance is shorter than the Canon lens to sensor distance. On has to shorten that distance to use Minolta lenses to Canon cameras. My Rokkor 58 kit is one way to do that.
Mar 02, 2009 at 08:54 AM
Silentlight
Details
p.1 #16Rokkor 58 conversion kit
Jim, sent you a PM about FL 55/1.2.
Mar 02, 2009 at 06:37 PM
Jman13
Details
p.1 #17Rokkor 58 conversion kit
How does the Rokkor 58 work on the 1D series? (I sold my 58/1.2 a while ago, but curious me wants to know). I'm guessing about the same as the 50 f/1.4 I bought from Jim...great until infinity, and then the mirror hangs on the way back down.
Mar 02, 2009 at 07:15 PM
Ed Sawyer
Details
p.1 #18Rokkor 58 conversion kit
The 5D series is the only ones with mirror issues IIRC. I have had 4 rokkor 58 1.2s and all cleared fine on my 1v (full frame film camera).
-Ed
Mar 03, 2009 at 07:57 AM
Conner999
Details
p.1 #19Rokkor 58 conversion kit
My 58/1.2 (JB mount kit, filed shroud) clears my 1Ds2 with no issues. Unlike the 5D, if it works on one FF 1 series, it will work on any.
Mar 03, 2009 at 11:24 AM
Kazut
Details
p.1 #20Rokkor 58 conversion kit
Jim,sent PM about conversion kit.
Mar 09, 2009 at 05:45 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
