fredmiranda.com Login
This topic is in the 2008 archive. You can read it and like its posts here. It is read only.
Archive 2008Zeiss 50mm F1.4 ZE - Sample Thread
chris hwang
p.1 #1Zeiss 50mm F1.4 ZE - Sample Thread
Just got it, and took a stroll downstairs in Downtown Brea.
Here are the first night shots. Too lazy to create links to every shot.
If you have a flickr account you can see the full size JPG.
Shot with:
Canon 5D
Faithful Mode
Tried to keep ISO as low as I could handheld
DPP Export JPG
Zeiss 50mm F1.4 T* Planar ZE with Hood Mounted.
All Shots @ F1.4
http://www.flickr.com/photos/offstandard/sets/72157610687355411/
If you want me to take some shots in certain apertures or anything reply here and I'll see what I can do. I'll be taking some tripod shots tomorrow side by side with CY and ZE mount.
Dec 05, 2008 at 02:32 AM
Dergiman
Details
p.1 #2Zeiss 50mm F1.4 ZE - Sample Thread
looks nice, me now wants one.
Dec 05, 2008 at 04:39 AM
ocean7
Details
p.1 #3Zeiss 50mm F1.4 ZE - Sample Thread
Thanks Chris! I will come back to see your tripod shots. So far the lens looks quite promising. How easy is the manual focus?
Dec 05, 2008 at 05:38 AM
chris hwang
Details
p.1 #4Zeiss 50mm F1.4 ZE - Sample Thread
Manual focus is OK, the smoothness is about the same as my old CY Zeiss 50/1.4. I don't really rely on the autofocus confirm blink anymore when wide-open. You can still move the focus 1mm or so and it still shows as focused, so I rely on my eye and the ee-s screen (high matte) and when I use the 85/1.4 Zeiss (which has a REALLY shallow DOF wide-open) I try to use the Angle Finder with the magnification, THAT makes focus SPOT ON every time because you see it.
Dec 05, 2008 at 12:26 PM
SJMD
Details
p.1 #5Zeiss 50mm F1.4 ZE - Sample Thread
Forgive me for asking, but is it better than using a CY with an adapter?
I just took some with my 50 1.7 - and I have to admit I love it.
Look at your shots and the color is great and you did a good job making the lens look super.
best
steve
Dec 05, 2008 at 10:52 PM
mawz
Details
p.1 #6Zeiss 50mm F1.4 ZE - Sample Thread
best
steve
It's not going to be much better optically, the only real upgrade from an IQ perspective is the 9-blade aperture (vs 6 in the C/Y version). The real advantages to the ZE are the full meter coupling and body-controlled aperture (in 1, 1/2 or 1/3 stops)
Dec 06, 2008 at 07:30 AM
edwardkaraa
Details
p.1 #7Zeiss 50mm F1.4 ZE - Sample Thread
Judging from the MTF graphs Zeiss seems to have tried to flatten the curves in order to get a more even sharpness across the frame while the Contax version seem to be sharper in the center but loses sharpness more rapidly as you move away from center.
mawz wrote:
SJMD wroteForgive me for asking, but is it better than using a CY with an adapter?
best
steve
Dec 06, 2008 at 07:35 AM
chris hwang
Details
p.1 #8Zeiss 50mm F1.4 ZE - Sample Thread
Ok, I was waiting for the SUN to come out to do these tests but it was OVERCAST all weekend where I am, so I just did this test without any sun around. Can you believe the day I want to do some nice park testing it is overcast for 3 days? This is Southern California!! It's never cloudy more than a day!!! =/
Well, I couldn't get all the tests I wanted to get done. I'll do a center/corner sharpness comparison and a CA comparison sometime later when I get some time. For now I just did some color/contrast and OOF BOKEH tests.
My impression so far... they are AMAZINGLY close in how they render throughout the aperture I tested. They both have pretty strong VIGNETTING at 1.4 but by 2.0 it is gone. Colors are very good throughout. I guess no surprise because they do have the same mechanical design. The main difference would be the OOF blobs between F2.0 and F4.0 on the CY, because they will have the "ninja star" effect, and you'll get more "star points" on the ZE if you stop down to F16 or so for landscape because of the 9 blades compared to the 6 blades of the CY.
SHARPNESS, they are both hairline sharp wide-open at 1.4 (problem being trying to get the correct focus using the MF). The middle frayed plastic/thread looking thing is where I focused. 100% crop below
The ZE seems to let in more light than the CY lens. It is not a White Balance problem, they had the same value and at the same spot they have a neutral gray RGB. The ZE is just brighter. I saw this throughout the test at all apertures.
These were taken with a 5D, Faithful Mode, NO sharpening, DPP Output JPG "8".
http://www.flickr.com/photos/offstandard/sets/72157610821783027/
REALLY boring pictures, and I'm too lazy to take crops and put them side by side, someone can do that if they want... you just have to go to my flickr and download the full-size jpg.
Dec 08, 2008 at 12:43 AM
edwardkaraa
Details
p.1 #9Zeiss 50mm F1.4 ZE - Sample Thread
The ZE seems a touch warmer as well. But in terms of sharpness they are practically similar in the crops provided. As for the ninja star, it depends on the copy as I have both AE and MM versions and neither has the ninja shaped aperture blades at f/2-4.
By the way, it would be easier for comparison to sharpen both files equally (such as level 3 in DPP).
Cheers,
Edward
Dec 08, 2008 at 01:28 AM
chris hwang
Details
p.1 #10Zeiss 50mm F1.4 ZE - Sample Thread
yeah, I didn't want to do any sharpening at all. Just plain RAW. With some DPP sharpening or better yet Photoshop USM you will get REALLY sharp images (at least in the center)
Sharpening also changes the subtle color changes and gradation so just wanted to show you guys the simple raws.
Below also done with Faithful Mode with no sharpening F1.4, ISO 250. Colors are nice.
Dec 08, 2008 at 02:01 AM
edwardkaraa
Details
p.1 #11Zeiss 50mm F1.4 ZE - Sample Thread
I downloaded all the images and did side by side comparisons. The ZE seems definitely warmer and has slightly higher contrast especially at smaller apertures. In terms of sharpness they seem pretty equal, but there are areas where one is slightly sharper than the other which denotes slightly different field curvature characteristics. To my eyes, the Contax has more areas where it is sharper, but this could be different with different subjects. Honestly, for someone who owns already the Contax, there is little incentive to upgrade from the pure IQ consideration. I expect the 85mm to behave in a similar manner. (But this won't stop me from buying them both )
Dec 08, 2008 at 03:24 AM
chris hwang
Details
p.1 #12Zeiss 50mm F1.4 ZE - Sample Thread
True, the only main advantage I see from the ZE, is that you don't have to do STOP DOWN metering. (Although I already miss playing with the aperture ring ahhaha)
But for me, it is definitely worth it as I have the "ninja star" version of the 50/1.4. It is an AEJ version and anything between 2.0 and 4.0 the blade shapes gives an... "unique" look that is quite distracting to me.
I also have the CY 85/1.4 MMG version with the "ninja star" which I'm still using.
Dec 08, 2008 at 03:46 AM
EltonTeng
Details
p.1 #13Zeiss 50mm F1.4 ZE - Sample Thread
You should pay a visit (if you haven't already) to those homes in the Birch/Starflower neighborhood with your shiny ZE 50/1.4.
Dec 08, 2008 at 06:08 PM
chris hwang
Details
p.1 #14Zeiss 50mm F1.4 ZE - Sample Thread
What's on Birch and Starflower?
Dec 08, 2008 at 10:32 PM
EltonTeng
Details
p.1 #15Zeiss 50mm F1.4 ZE - Sample Thread
You would make a left from Birch into Starflower to see the Candycane Lane of Brea. Nearly 95% of the homes have good amounts of decorations on their front yard, and some open their homes for a show.
Depending on your taste, some of these homes are either National Geographic or Jerry Springer in real life.
Dec 09, 2008 at 02:07 PM
chris hwang
Details
p.1 #16Zeiss 50mm F1.4 ZE - Sample Thread
Focus was off, I forgot to put my angle finder in the bag.
Dec 14, 2008 at 02:43 AM
dcmiller
Details
p.1 #17Zeiss 50mm F1.4 ZE - Sample Thread
What focus screen do you have? The split circle, like the brightscreen, should be easy to focus in this kind of light.
Before AF got good no one would try to do manual focus with the standard Canon screens. The Canon screen made for manual focus is not ideal and on the dark side.
Zeiss has links to focus screens on their web site.
Dec 14, 2008 at 11:34 AM
dcmiller
Details
p.1 #18Zeiss 50mm F1.4 ZE - Sample Thread
I agree, but the situation is better now with auto ISO. The shutter can be set and the ISO automatically minimized.
Say your shooting at night and don't want to go below 1/60 shutter. Set the camera to TV 1/60 and ISO to auto. The aperture can be varied with no other user intervention besides exposure offsets.
There's no advantage to shooting alts in AV mode with auto ISO.
Dec 14, 2008 at 11:41 AM
mawz
Details
p.1 #19Zeiss 50mm F1.4 ZE - Sample Thread
dcmiller wrote:
mawz wrote...........
Well, until Canon implements Auto ISO properly (right now they're where Nikon and Pentax were 3 years ago, quite primitive Auto ISO). With proper Auto ISO you can specify minimum shutter speed for ISO bumping, select your aperture in Av mode and not have the camera drop below that shutter speed until max ISO is hit, making Alt's very usable in Av mode with Auto ISO.
Dec 14, 2008 at 12:02 PM
dcmiller
Details
p.1 #20Zeiss 50mm F1.4 ZE - Sample Thread
I think it's implemented fine. If I wanted everything automatic I wouldn't use manual focus lenses.
Index finger on the dial controls shutter speed. My thumb on the wheel controls exposure offset. The camera sets the lowest ISO. I don't have to fiddle with the simple to calculate ISO adjustment.
I always have the option of P mode if I want to go to sleep.
Dec 14, 2008 at 12:18 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
