fredmiranda.com Login
This topic is in the 2008 archive. You can read it and like its posts here. It is read only.
Archive 2008Nikkor 50/1.2 on 5D?
Silentlight
p.1 #1Nikkor 50/1.2 on 5D?
Before I go ahead and scratch the rear element of my brand spanking new Nikkor 50/1.2, I better ask..... will it work on the 5D or will the rear element make contact with the camera body or mirror at infinity focus? Mirror is not shaved.
It looks like I may have to cut off a protection tab on the lens to clear the mirror.
Aug 04, 2008 at 12:28 PM
TR3B
Details
p.1 #2Nikkor 50/1.2 on 5D?
I've done the mod on my Nikon 50mmf/1.2. You will have to chop the Nikon to clear the mirror. I have a dremel and have shaved several Nikon primes. I use cotton balls taped to the rear element to ensure no metal gets inside. If you are concerned about your ability to do the job, I would be willing to do a swap as I am considering going to Nikon and the tab won't affect me. I bought mine new from Matsuistore in Japan in May and have used it once. I have an older Nikon 55mm f/1.2 and an Olympus 55mm f/1.2 that I use for low-light. I didn't want to scratch the lens so it never left the house. The lens is a serious mint condition, albeit the mod with all paperwork, box, and caps. No hood. I paid, I believe $488 with shipping.
Just a consideration if you don't feel comfortable doing it.
By the way, the first Nikon I modded, I got some very fine shavings in the lens, but it was a 50mm f/2 and I still use it occasionally without notice.
Just be careful if you decide to proceed.
Edited on Aug 04, 2008 at 06:55 PM
Aug 04, 2008 at 06:53 PM
Anden
Details
p.1 #3Nikkor 50/1.2 on 5D?
I did not have to modify the 50 1.2 ai I used on my 5D. Maybe I was lucky?
A
Aug 04, 2008 at 10:40 PM
eddyboy
Details
p.1 #4Nikkor 50/1.2 on 5D?
Nikkor 55mm 1.2 also works without a hitch...
Aug 07, 2008 at 12:29 AM
Silentlight
Details
p.1 #5Nikkor 50/1.2 on 5D?
Well I finally received my adapter and got my answer. Had to grab the thin snips and cut off about 1mm from the top of the protective tab in the back so it could fit inside the 5D lens cavity without scraping the body. No Dremil required. But I crossed my fingers before pushing the shutter with the lens focused at infinity!!
Pretty lens. I will get to play with it next month in front of a bunch of Canon reps
Edited on Aug 13, 2008 at 11:26 AM
Aug 13, 2008 at 11:25 AM
ISO1600
Details
p.1 #6Nikkor 50/1.2 on 5D?
i haven't ever tried to mount a 50/1.2 AI, but my AIS had to be modded so that the tab wouldn't gouge the mirror box. Keep in mind, this was on a 5D that had NO adapting issues w/ Zeiss 21 and 28... so it was a "good" 5D.
whenever "modding" nikkors, i would just rip the tab off with some pliers. Takes about half a second, and it doesn't have to be pretty.
Aug 13, 2008 at 08:39 PM
apras
Details
p.1 #7Nikkor 50/1.2 on 5D?
i also used my 50mm 1.2 AI without modification on my 5d.
Aug 13, 2008 at 09:47 PM
Conner999
Details
p.1 #8Nikkor 50/1.2 on 5D?
The purpose of the tab is simply to protect the rear element when the lens is sans rear cap?
Aug 14, 2008 at 05:21 AM
StevenPA
Details
p.1 #9Nikkor 50/1.2 on 5D?
Yep.
Aug 28, 2008 at 09:44 PM
niklasl
Details
p.1 #10Nikkor 50/1.2 on 5D?
I have used both 50/1.2 Ai and Ais on my 5D without any issues with a Cameraquest adapter.
Sep 11, 2008 at 12:00 PM
ovredal73
Details
p.1 #11Nikkor 50/1.2 on 5D?
I dont know so much about these 50-ish Nikons - is it possible to use any of them - for example a 55 1.2 Nikkor-S.C. or Nikkor-S (both non ai...?) on a 5D?
Meaning - is there a difference between all these versions for use on a 5D?
Silentlight, I don´t mean to hijack your thread, hope its ok that I add this question here...
Edited on Sep 11, 2008 at 01:40 PM
Sep 11, 2008 at 01:39 PM
Silentlight
Details
p.1 #12Nikkor 50/1.2 on 5D?
From what I have read the IQ of 55/1.2 wide open is not as good as the 50/1.2.
http://www.naturfotograf.com/lens_norm.html
I should however warn you that 50/1.2 shows a minor amount of CA problems wide open at high contrast areas. Close it to f2 and it's not a problem. 9 blades gives you nice stars.
Another source to read....
http://www.kenrockwell.com/nikon/50mm-f12.htm
Sep 11, 2008 at 02:08 PM
rsrsrs
Details
p.1 #13Nikkor 50/1.2 on 5D?
hi,
the nikkor ai 55mm 1,2 works well on the 5D
mine is type VI
http://zneyder.de/ebays/distel_s_.jpg
rest infos here
http://www.mir.com.my/rb/photography/companies/nikon/nikkoresources/50mmnikkor/indexA.htm
cheers
mit freundlichen gruessen
r schneider
Edited on Sep 11, 2008 at 02:18 PM
Sep 11, 2008 at 02:14 PM
ovredal73
Details
p.1 #14Nikkor 50/1.2 on 5D?
Silentlight, thanks for your reply and those links!
André
Sep 11, 2008 at 02:24 PM
ovredal73
Details
p.1 #15Nikkor 50/1.2 on 5D?
Wow, thats an amazing shot, rsrsrs
Sep 11, 2008 at 02:25 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
