fredmiranda.com Login
This topic is in the 2008 archive. You can read it and like its posts here. It is read only.
Archive 2008Zeiss Contax 35-70mm infinity mark
Arianne Dubois
p.1 #1Zeiss Contax 35-70mm infinity mark
I have three Zeiss Contax 35-70mm Vario Sonnars in use.
All of them MM. Two new old stock, one with a fresh service and calibration from Oberkochen.
All of those lenses reach infinity focus well before the end position of the helicoid, well before the ∞ infinity mark. The distance increases a bit from tele to wide focal length. But none of the lenses allows a fool-proof mechanical end position for optimal infinity focus. (Possibly done by Zeiss to ensure applicability under different thermal conditions.)
This means also, that I usually have to use the magnifying angle finder to ensur the perfect infinity focal plane. With 3.4 viewfinder darkness I find it not very easy to nail focus with this (otherwise overwhelming) lens. Especially under suboptimal lighting conditions.
Since this is probably one of the most popular lenses here, I would like to hear, if this is a coincidental malfunction of my equipment (unlikely) or a common property of this lens.
Apr 17, 2008 at 01:15 PM
Leon Noel
Details
p.1 #2Zeiss Contax 35-70mm infinity mark
I assume you shoot it on a Canon body via an adapter.
If that's the case, you need to shoot it on a Contax mount body before thinking all samples are done that way to prevent thermal expansion/contraction (even if this is the case I think the effect is minimal). Also most adapter manufacturers tend to make adapter thinner than [register x - register y] because they want to assure you will achieve infinity, that explains the norm of "focusing past infinity".
It's more like the adapter thickness issue, with the "perfect" thickness (eos register + gap + adapter = contax register) it should reach infinity on the mark. Mine reaches infinity at 15m mark.
And on the 50/1.7 you can actually adjust the focus ring so that you can get infinity right on the mark (by loosing a few screws and turn the ring, then fasten them when you are happy) so adapter thickness is less a problem here. However that may not be possible on the 35-70 design, probably because it's a one touch.
Edited on Apr 17, 2008 at 01:33 PM
Apr 17, 2008 at 01:24 PM
TeamSK jay
Details
p.1 #3Zeiss Contax 35-70mm infinity mark
I have two 35-70 and both hit infinity at just past 15. I always thought it was an adapter thickness issue.
Leon Noel
Details
p.1 #4Zeiss Contax 35-70mm infinity mark
Scratch that, inspired by your question I decided to sneak a peek under the rubber grip, look what I found! Sorry for pic quality, it's a snapshot with my webcam to save time.
http://i133.photobucket.com/albums/q69/Blknoel/SnapShot1-1.jpg
That screw, and another identical one on the other side dictate how much the whole structure extends/retracts (focusing mechanism) when I turn the ring, so I think it could be adjusted to match infinity with the mark on the barrel.
Edit: nvm those 2 screws hold the front element to the lens, nothing to do with focus system.
Edited on Apr 17, 2008 at 02:09 PM
Apr 17, 2008 at 01:44 PM
cogitech
Details
p.1 #5Zeiss Contax 35-70mm infinity mark
Arianne,
It does indeed sound like your adapter is too thin. My recommendation would be to buy a cheap Chinese one for use with those lenses.
Another way to approach it would be to compress the flanges on the C/Y side of the adapter as much as you can and then use some suitable material as a shim between the lens and the adapter. The flanges have slits in them and can be tweaked in either direction to make the adapter fit "snugger" on the lens. Compress them and you should be able to gain as much as .5mm between the lens and adapter. I might try thin plastic or layers of foil as a shim.
Apr 17, 2008 at 02:33 PM
Arianne Dubois
Details
p.1 #6Zeiss Contax 35-70mm infinity mark
Our measurements of declination are identical to the experience of TeamSK jay: infinity focus is just past 15. Seems to be a generic thing. Anyone else here?
Leon Noel: Same phenomenon on an original RTS and S2 body. (And yes I'm talking about Contax usage with EOS bodies. I thought this is clear here.)
Our adapters are custom built Zörkendörfers and more complex than the usual ones (tight fit and an extra spring to prevent play on both sides). They simply guarantee the same register as in a full Contax set up (which equals 1.42mm as far as I remember, only from the 21 Distagon we use thinner adapters for the wides). There is no way to mechanically change the stop of the helicoid of the 35-70.
Paul: Do you have the Vario Sonnar 35-70? Is your infinity focus really where it should be?
(PS. Paul: Thank you for everything. Your parcel will hopefully be here in a couple of hours!)
Edited on Apr 17, 2008 at 03:52 PM
Apr 17, 2008 at 03:50 PM
pdmphoto
Details
p.1 #7Zeiss Contax 35-70mm infinity mark
I had one in near mint condition I was using with a standard adapter and, from my recollection, infinity was very close to the infinity mark. That was on a Kodak SLR/c. Maybe the buyer of my lens (and adapter) could chime in on his experience with a 5D.
Apr 17, 2008 at 04:12 PM
cogitech
Details
p.1 #8Zeiss Contax 35-70mm infinity mark
...Show more →
Arianne,
No, I do not have the 35-70 Vario-Sonnar. I hate to admit it, but I have always wondered what the attraction to this lens is.
So, why did I respond? It seemed obvious that the lens(es) are too close to the sensor. The fact that they behave the same way on a native Contax body is baffling. And many others have the same issue? Puzzling. Sorry if I confused things at all.
Apr 17, 2008 at 04:33 PM
jjlphoto
[X]
Details
p.1 #9Zeiss Contax 35-70mm infinity mark
My Canon zooms pass infinity also. As mentioned, I believe it is due to both thermal expansion allowances, and that the lens is most likely not parafocal- infinity position for the tele end will not be the same for the wide end.
I did shim out my CY Distagons for precise infinity stop. I used brass shim stock cut into a ring and laid it in between the adapter and the lens. My adapters are HappyPageHK's 1.4mm thick adapters, and with my .002thds shim brings the total adapter thickness up to 1.45mm.
Edited on Apr 17, 2008 at 06:15 PM
Apr 17, 2008 at 06:04 PM
Alex
Details
p.1 #10Zeiss Contax 35-70mm infinity mark
Is Zeiss Contax 35-70mm Vario Sonnars known to be parfocal? If not, the infinity focus will be different for different focal lengths.
Alex
Apr 17, 2008 at 06:38 PM
StevenPA
Details
p.1 #11Zeiss Contax 35-70mm infinity mark
I, too, believe the lens not to be parafocal.
I've used the 35-70/3.4 with two cameras, the 1Ds and 5D. On both bodies, the 70mm end achieved infinity focus well before the infinity marker. However, the 35mm end on both bodies is pretty much bang on infinity. Though sometimes I wonder if I'm reaching infinity at the 35mm end on my 5D. We're talking fractions of a fraction of a millimetre, so I don't fuss about it too much.
Either way, the lens seems to be designed to give infinity focus at the infinity marker at 35mm, and then infinity focus progressively farther away from the infinity marker as the lens is zoomed in to 70mm.
I consider the 35-70 to be very well designed/aligned in this regard. Have a go at the 80-200/4 and you'll see a lens that focuses at infinity almost a 1/6-1/4 turn before the infinity marker depending on what the focal length is. Yikes!
Apr 17, 2008 at 08:48 PM
StevenPA
Details
p.1 #12Zeiss Contax 35-70mm infinity mark
It's a fantastic lens, Paul. I'm surprised to hear you wonder what the attraction is after presumably having seen tons of great pics that have been shot with this lens by various members. If stopped down landscape is one's game, then this lens pretty much replaces other Contax lenses in its range.
Apr 17, 2008 at 08:57 PM
edwardkaraa
Details
p.1 #13Zeiss Contax 35-70mm infinity mark
All adapters these days are too thin. Use Kindai or CQ and you will get infinity where it should be. I threw away all my Fotodiox and Roxsen adapters in favour of Kindai. They're very expensive but worth every penny.
Apr 17, 2008 at 10:11 PM
Justin D
Details
p.1 #14Zeiss Contax 35-70mm infinity mark
Out of interest, could you expand on what you feel makes teh Kindais worth the extra expense please. I recently bought a Leica R adapter from HK which claimed to be an OEM version of the elephotos (which I have no reason to doubt), and it is an excellent adapter - more expensive (not much, though), and, as you say, worth every penny. It's anodized black, grips the lens and fits the body without ANY play whatever etc. I haven't had a great deal of luck with Leica Adapters - so I'll get them here in the future, but my contax adapters from china or wherever have always been very good... I wonder, though, if they could be better somehow.
Apr 17, 2008 at 11:08 PM
edwardkaraa
Details
p.1 #15Zeiss Contax 35-70mm infinity mark
Well, they're the only adapters I have tried that get me infinity focus at exactly infinity setting. Cheaper adapters always got me infinity at 15m or closer. I have tried the elefoto copy you mentioned and didn't find them good at all, too thin like the others. I recently discovered a Chinese company doing an almost exact copy of the Kindai and it works perfectly as well. I ordered a few for my "cheaper" lenses. I think precision and build quality is what matters most.
Apr 18, 2008 at 12:59 AM
adamM
Details
p.1 #16Zeiss Contax 35-70mm infinity mark
For what it's worth, my happypage adapter focuses at infinity perfectly with the 35-70
It's a perfect combo, i twist to infinity and don't think twice about it.
Lovely lens, i know we've all blathered on about it, but it's worth every blather. Real gem that thing.
Apr 18, 2008 at 01:01 AM
cogitech
Details
p.1 #17Zeiss Contax 35-70mm infinity mark
StevenPA wrote:
cogitech wroteI hate to admit it, but I have always wondered what the attraction to this lens is.
I have certainly seen tons of great pics with the lens. I just have trouble imagining what I would use it for.
Stopped-down landscapes means 28mm or wider, for me. I know this is subjective, and I could probably get by with 35mm, but I'd much prefer wider for that purpose. I do like 35mm focal length for other purposes, but I much prefer to have an aperture of at least f2 at 35mm. At the 50mm-ish focal length, I want a really fast lens. Then 70mm is not quite "normal" and not quite "portrait length". On top of that, the "macro" function is at the wrong end of the zoom, and I have heard several negative comments on the "usability" of the lens.
I'm not trying to put the lens (or it's owners) down. Again, it is seemingly prime-like throughout the range and I have seen all kinds of great photos taken with it. I just have no idea what I would use it for.
Apr 18, 2008 at 09:21 AM
Sahid Limon
Details
p.1 #18Zeiss Contax 35-70mm infinity mark
What? It's not focusing to infinity properly? Feel free to donate one of your copies to me.
I so wish I had it so I could've joined in on the discussion too...
Apr 18, 2008 at 09:34 AM
jonboring
Details
p.1 #19Zeiss Contax 35-70mm infinity mark
If determining precise infinity focus is really hard, how do we know we are doing it right? This has been discussed here before but I never felt like anyone explain a fool-proof technique for determining whether or where the lens reached infinity focus.
John Luke - Always nice to see you here.
Apr 18, 2008 at 01:41 PM
cogitech
Details
p.1 #20Zeiss Contax 35-70mm infinity mark
Someone suggested using the moon. Seems like a good idea, considering that it is certainly further away than anything on earth that I might want to focus on.
When you have a lens that focuses past infinity, it is pretty easy to tell because it reaches a point that is very sharp and then gets blurry again as you pass infinity.
If the (distant) object "snaps" into focus just as the ring stops, then you can feel pretty confident that you've got infinity. Lots of time spent with your camera (and focusing screen) will eventually result in you "just knowing". Not scientific, but often "good enough".
Apr 18, 2008 at 02:18 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
