Archive 2008 · CS3 color conversion problem
Randy Walton
p.1 #1 · CS3 color conversion problem
For some reason, when I make a image mode conversion to Lab color it fills the image with black and I can't remove. This happens regardless if the file is a raw, tiff, jpeg, or psd image. I've never had this happen before and I can't seem to find a way to correct the problem. I've never had this happen prior to yesterday. I did update camera raw through bridge recently.
I would appreciate any input or suggestions how to fix this.
Regards,
Randy
The following are screenshots as the image is being converted and the result. This was a raw (Nikon nef) file converted with ACR. This image is unimportant, just used as an example of the problem.
RGB file opened in CS3
http://i.pbase.com/g3/18/407218/2/94526106.q8030fNQ.jpg
File being converted to Lab Mode
http://i.pbase.com/g3/18/407218/2/94526108.xxJvSmPR.jpg
Mode chage results
http://i.pbase.com/g3/18/407218/2/94526107.lHbNruUc.jpg
Mar 22, 2008 at 01:05 PM
jerryrock
p.1 #2 · CS3 color conversion problem
The first step to troubleshooting Photoshop is to reset preferences:
While launching Photoshop, Hold down Alt+Ctrl+shift on the PC or Cmd+Option+Shift on the mac.
Mar 22, 2008 at 05:44 PM
Randy Walton
p.1 #3 · CS3 color conversion problem
This step successfully removed all the settings I have set in preferences but did nothing to eliminate the problem I'm having. Look at the channels pallet shown, the Lab channel shows as solid black. It's almost as though you've instructed PS to fill with black.
Mar 22, 2008 at 08:32 PM
Pandacat
p.1 #4 · CS3 color conversion problem
Wasn't there an anouncement this week that Adobe pulled their RAW updates to CS3 and Lightroom because of a problem like this? Check PhotoShopNews...
http://photoshopnews.com/2008/03/16/adobe-yanks-lightroom-14-camera-raw-44/
Larry
Mar 22, 2008 at 08:44 PM
Randy Walton
p.1 #5 · CS3 color conversion problem
Larry
Thanks Larry, I'll remove the updated acr file and replace with the old one and see if that does the trick.
Randy
Mar 22, 2008 at 09:29 PM
Randy Walton
p.1 #6 · CS3 color conversion problem
Bingo! That was the problem, the new acr update 4.40.79. Removed it and replaced with the prior file and all is as it should be. Thanks!
Randy
Mar 22, 2008 at 09:41 PM
paulhodson
p.1 #7 · CS3 color conversion problem
Don't you just hate it when updates do that? I always ignore them if I can for a few weeks so some other poor chap can beta test them for me.
Mar 23, 2008 at 02:42 AM
