       2       3       …       21       22       end
Archive 2007 · •Eos 1Ds MkIII Master Thread•
Jeff
p.1 #1 · •Eos 1Ds MkIII Master Thread•
As it would appear that the announcement for the Canon Eos 1Ds MkIII is imminent and accurate details are now emerging....
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=139&modelid=15710
http://web.canon.jp/imaging/eosd/eos1dsm3/
Amazon link
From the now-dead link:
Canon EOS 1Ds Mark III 21.1MP Digital SLR Camera (Body Only)
Availability: This item will be released on December 10, 2007.
Price: $7,999.99
Technical Details
* 21.1-megapixel full-frame CMOS sensor
* Large 3.0-inch LCD display with Live View and seven brightness settings
* 5 fps at shutter speeds 1/500 second or faster (for bursts of up to 45 Large/Fine JPEGs or 15 RAW images)
* sRAW mode; 35-zone metering system; 45-point AF; integrated Self-Cleaning Sensor Unit
* Powered by LP-E4 lithium-ion battery pack; stores images on CF, SD, or some SDHC memory cards
› See more technical details
Product Details
* Shipping Weight: 6 pounds
...Show more →
Product Features and Technical Details
Technical Details
* Effective resolution: Approximately 21.1 million pixels (total pixels: approximately 21.9 million)
* Recording pixels: 5616 x 3744
* Sensor type: Full-frame CMOS sensor, with primary R-G-B filtration (28 x 18.7 millimeters)
* Pixel size: 6.4 microns square
* Lens focal length factor: None (1x)
* Imaging processor: Dual DIGIC III image processors
* Maximum frames per second: 5 frames per second (fps) at shutter speeds 1/500 second or faster, in all recording modes
* Drive modes: Single; silent (single-frame); high-speed continuous (5 fps; adjustable 5 to 2 fps); low-speed continuous (3 fps; adjustable 4
...Show more →
Carry on!
Jeff
FM.com Moderator
Edited by Jeff on Aug 19, 2007 at 08:54 AM GMT (Reason: Added text from dead link)
Edited by Jeff on Aug 19, 2007 at 12:11 PM GMT (Reason: grab)
Edited by Jeff on Aug 20, 2007 at 09:24 AM GMT (Reason: added Canon link)
Aug 17, 2007 at 01:58 PM
The Ghost
p.1 #2 · •Eos 1Ds MkIII Master Thread•
http://www.amazon.com/Canon-1Ds-Mark-III-Digital/dp/tech-data/B000V5LX00/ref=de_a_smtd/104-3808773-1007162?ie=UTF8&qid=1187517273&sr=1-6
Aug 19, 2007 at 05:16 AM
EB-1
p.1 #3 · •Eos 1Ds MkIII Master Thread•
No HSC and same old small area AF coverage? Perhaps by Decemeber Canon can at least get the AF (limited such as it is to 19 points) to work reliably.
EB
Aug 19, 2007 at 05:28 AM
krobatshov
p.1 #4 · •Eos 1Ds MkIII Master Thread•
extendable iso 3200 / 50 only?
no real one?
correct me if I'm wrong...
Aug 19, 2007 at 05:49 AM
EB-1
p.1 #5 · •Eos 1Ds MkIII Master Thread•
Three years later and no improvement in ISO/noise? One can only hope it is a typo.
EB
Aug 19, 2007 at 05:59 AM
simonit
p.1 #6 · •Eos 1Ds MkIII Master Thread•
It states full frame (as expected) but says it is 28 x 18.7mm?
and still no mirror lockup button (as expected)!
Edited by simonit on Aug 19, 2007 at 09:13 PM GMT
Aug 19, 2007 at 06:11 AM
pcho
p.1 #7 · •Eos 1Ds MkIII Master Thread•
No focus fine tuning as well. This could be the culprit behind all thos focus issues
Perry
Aug 19, 2007 at 06:12 AM
alba63
p.1 #8 · •Eos 1Ds MkIII Master Thread•
Think before you write: The 5d has 100-1600 + Expanded range as well, but it has only (roughly) half as much pixels. The pixel size is the all desisive parameter for noise. The smaller the pixels, the higher the noise. I guess the new sensor will use the same technology as the 1dIII to increase the effective light sensitive surface while keeping the absolute pixel size relatively lower than with older sensor generations. But in the end 22MP on a FF sensor is just a lot!
Canon cannot deny the laws of physics.
Bernie
Aug 19, 2007 at 06:14 AM
EB-1
p.1 #9 · •Eos 1Ds MkIII Master Thread•
It would be good enough for me if the 1Ds MK III can produce images at ISO 1600 with the noise level of the 1Ds MK II at ISO 800.
I suspect there may be some typos as well, so i'll wait for the offical releases. There is still over 3 months before availability.
EB
Aug 19, 2007 at 06:25 AM
slee915
p.1 #10 · •Eos 1Ds MkIII Master Thread•
How about a Master thread on this lens ?
From the amazon page on 1DsMk3:
Canon EF 14mm f2.8L II USM Lens
Designed primarily for discerning landscape and architectural photographers, the Canon EF14mm f2.8L II USM lens is ideally suited to the EOS-1Ds Mark III's full-frame capability. Measuring 3.7 inches in length and weighing in at under 23 ounces, this ultra-wide angle L-series prime lens is well corrected for rectilinear distortion, provides a 114-degree diagonal angle of view, and delivers high-speed autofocus with higher image quality overall including superior peripheral image quality, compared to its predecessor, the stalwart EF 14mm f2.8L USM lens.
While its large diameter, high-precision aspherical and UD elements, optimized lens element positioning, and flare and ghost-reducing lens coating ensure that this lens delivers the top optical performance in its professional class, Canon has added other features photographers have been asking for--improved dust and water resistance incorporated around the mount, switch panel and focusing ring, and a round aperture that creates a nice background blur and makes it easier to recognize an out-of-focus scene in less than brightly lit conditions. Furthermore, Canon has created a new lens cap specifically for the EF 14mm f2.8L II USM that is held to the lens by a stopper.
Aug 19, 2007 at 07:53 AM
billbunton
p.1 #11 · •Eos 1Ds MkIII Master Thread•
Interesting definition of full-frame:
Aug 19, 2007 at 07:55 AM
Nill Toulme
p.1 #12 · •Eos 1Ds MkIII Master Thread•
"...held to the lens by a stopper." That alone sounds like it's worth its own thread. ;-)
Nill
www.toulme.net
Aug 19, 2007 at 07:57 AM
mcbroomf
p.1 #13 · •Eos 1Ds MkIII Master Thread•
They seem to have it (sensor size) correct in this link
http://www.amazon.com/Canon-1Ds-Mark-III-Digital/dp/B000V5LX00/ref=sr_1_6/103-6632904-9598204?ie=UTF8&s=photo&qid=1187517273&sr=1-6
Revolutionary Resolution
Developed and manufactured by Canon specifically for the EOS-1Ds Mark III digital SLR, the camera's new full-size 36 x 24-millimeter CMOS image sensor offers the highest resolution in its class and is comprised of approximately 21.1 million effective pixels (5632 x 3750) set at a pitch of 6.4 microns. The user can select any one of six recording formats ranging from 21.0 megapixels in Large JPEG or RAW format, 16.6 or 11.0 megapixels in the two medium JPEG sizes, or 5.2 megapixels in the small JPEG or "sRAW" formats. In any JPEG format, the user can set one of ten compression rates for each image size. In sRAW mode, the number of pixels is reduced to one-fourth that of a standard RAW image and the file size is cut in half, while retaining all of the flexibility and creative possibilities associated with full-size, traditional RAW images.
Aug 19, 2007 at 08:37 AM
Nill Toulme
p.1 #14 · •Eos 1Ds MkIII Master Thread•
I wonder why no increased frame rate in sRAW? Is it because it's still using and having to process the data from the whole sensor?
Nill
www.toulme.net
Aug 19, 2007 at 08:42 AM
AGeoJO
p.1 #15 · •Eos 1Ds MkIII Master Thread•
Amazing that Amazon came up with all those specs first while others not quite yet..... Is this the first time around that an on-line retailer did it? It certainly sounds "official" enough then that people outside Canon know about the existence of this camera already.
Aug 19, 2007 at 08:43 AM
DigitalDreamer
p.1 #16 · •Eos 1Ds MkIII Master Thread•
WoW my other thread was deleted because i mentioned posting my 1ds markII? Well i just Pre-ordered it at Amazon, they accepted it..
Aug 19, 2007 at 08:56 AM
AGeoJO
p.1 #17 · •Eos 1Ds MkIII Master Thread•
Now, they charge your credit card right away when you place the pre-order, right?
Aug 19, 2007 at 09:03 AM
nathanlake
p.1 #18 · •Eos 1Ds MkIII Master Thread•
Yea...I guess most of you guys are right....it is just another piece of crap Canon body that nobody will use (INSERT SARCASM AS DESIRED.
Aug 19, 2007 at 09:11 AM
snowboarder
p.1 #19 · •Eos 1Ds MkIII Master Thread•
of course not. I like amazon.com, they have a great customer service
and they don't charge taxes to California (got tough lately as so many stores
are in CA). Put my order also. I want to be at the top of a long, long
waiting line
Hope Dec 10th is a safe estimate, amazon always give very conservative
shipping dates.
Aug 19, 2007 at 09:14 AM
Clovermead
p.1 #20 · •Eos 1Ds MkIII Master Thread•
The 40D is up there too:
http://www.amazon.com/Canon-40D-10-1MP-Digital-Camera/dp/B000V5P90K/ref=sr_1_13/105-7070623-6868441?ie=UTF8&s=electronics&qid=1187532964&sr=8-13
Aug 19, 2007 at 09:16 AM
       2       3       …       21       22       end
       2       3       …       21       22       end
