fredmiranda.com Login
This topic is in the 2006 archive. You can read it and like its posts here. It is read only.
Archive 2006Help calibrating high-end Trinitron (Sony GDM-F520)
calemon
p.1 #1Help calibrating high-end Trinitron (Sony GDM-F520)
Hi:
I have a couple of questions, some generic and some specific to my hardware.
I've just recently received a Monaco EZColor suite that I'm going to be using to calibrate everything, in particular my Sony GDM-F520 CRT. I believe that this CRT is the base platform for the Artisan system, except the Artisan dot pitch might be larger.
This CRT is intended for professional graphics use and already has excellent colour and many settings that a lot of monitors don't have. Because of this, I'm not sure if they offer me anything when it comes to calibration.
1) As I go through Monaco/X-Rite's process, it has me leave the contrast at 100%. This makes photos look pretty good and punchy but is high enough that some sharpness is being lost and there's an irritating look to, well, everything BUT photos. I did another profile with the contrast set at 70%, which is more comfortable for general use. What's the best way to "solve" this issue? Adjust the contrast depending on the situation and make sure to max it out when working on photos? Do what I did and profile at something <100%?
2) The F520 has three preset modes that affect gamma principally - Standard, Dynamic and Professional. The manual vaguely indicates that "professional" is for accurate colour response, standard is suited to desktop apps, and dynamic is for gaming and movies (which I've used it for). During the whitepoint part of profiling the software showed me meters of R, G and B and told me to center them. I noticed that without getting into separate R,G,B adjustments it was best centered on "standard", which surprised me. Just wondering if anyone has any comments on whether "professional" is actually good for something.
2a) Set to 6500K all the readouts were practically 'in the green' without further RGB channel adjustments. I tried to get it perfect by adjusting the channels but I could never get it close. More practice required. Has anyone bothered? Should I be adjusting channel brightness or contrast first?
3) The F520 has 4 colour temperature modes. Preset (choose 5500, 6500, 9300), Easy (a slider that moves in 100K increments), Expert (RGB Brightness and RGB contrast controls), and "sRGB". sRGB has no tuning controls or settings of any kind, and disables brightness and contrast completely (although I would guess they are at 100%). The manual vaguely says this is a mode for professional colour work. What the heck is this for? In the past google has led me nowhere.
4) I generally connect via the 5 BNCs because it suits my situation. Has anyone else used EZColor with an F520 and does connecting by D15 to enable DDC buy me anything? I saw reference in reviews of the Monaco software that said it will control the monitor through DDC but the software itself makes no mention of it anywhere. Would DDC + sRGB mode lead to a totally hands-off calibration or offer any similar advantages?
For what it's worth, other than being at 6500K, the calibrated display doesn't look all that different from the uncalibrated. I think the colours were pretty good to begin with. I'm not sure how to extract from the software how much "correction" was applied in the profile. I also profiled my circa-2000 Thinkpad beater laptop - sucked (not surprised).
Thanks,
Craig.
Oct 13, 2006 at 10:15 AM
calemon
Details
p.1 #2Help calibrating high-end Trinitron (Sony GDM-F520)
One bump with a "better" topic. Someone somewhere must have experience calibrating pro CRTs. (I'm hoping)
Craig.
Oct 16, 2006 at 05:59 AM
