fredmiranda.com Login
This topic is in the 2003 archive. You can read it and like its posts here. It is read only.
Archive 2003EF-S: Canon's first short back focus lens
Peter de Weerdt
p.1 #1EF-S: Canon's first short back focus lens
Canon EF-S18-55mm/3.5-5.6 lensTogether with its new EOS300D digital SLR, Canon introduced the EF-S18-55mm/3.5-5.6 lens. This S indicates short back focus, which means this lens uses the extra room the back swing of the mirror in the 300D makes. By doing so this lens has a good wide-angle performance in a very light and compact barrel. The lens doesn't cover full frame though and is meant to be used on a 1.6 cropped sensor like in the 300D body. A rubber ring prevents the lens to be mounted on any other EF mount camera that doesn't have the back swing mirror.
The question now is, is this lens the first of a Canon EF-S series or just a single kit lens? My bet is that more S lenses will follow. A strong indication is the release today of Canon's MkII of the extension tube EF12 and EF25. These extension tubes have specifically been developed for the EF-S mount and work together with the EF-S 18-55mm zoom.
Aug 20, 2003 at 02:31 AM
FM ForumsLatest Photography NewsJoin Upload & Sell
