fredmiranda.com Login
This topic is in the 2005 archive. You can read it and like its posts here. It is read only.
Archive 200528mm Test: Zuiko / Canon
Mike Hatam
p.1 #128mm Test: Zuiko / Canon
Canon 16-35/2.8 vs Zuiko 28/2
Background:
The Zuiko 28/2 has an excellent reputation as one of the sharpest Zuiko's made. I only have one copy, so I don't know if mine is good, bad, or average. I do know that I have an excellent copy of the 16-35, so I decided to compare them.
Note that when I set the Canon 16-35 at 28mm, it actually turned out to be 27mm (according to the EXIF data), so there is a very slight difference in focal length in this test.
The Test Results:
http://www.thehatams.com/Images/28mm-Test.jpg
Interpretation:
I didn't want to spend a lot of time on this particular test, so I'm just showing two sets of images - corner crops take at f11, and center crops taken at f2.8.
I'm continually impressed with this copy of the Canon 16-35. It does not beat the Zuiko in sharpness or contrast, but it does perform admirably well, especially when stopped down. At f2.8 (wide open for the Canon), the Zuiko pretty well hammers the Cannon.
For those who want the absolute best image quality at 28mm, I think it comes down to two choices - the Zuiko 28/2 or the Leica 28mm. Unfortunately, I have not tested those two against each other yet, so I don't know which is better, but I suspect they are similar in image quality.
The Zuiko 28/2 can be hard to find, but it's not expensive (typically going for under $600), so this may be an excellent option for those who want a serious 28mm prime lens.
Mike
Disclaimer: I will be selling lenses on FM that are mentioned in this report. I make my lens testing available as a way of contributing to the FM community. Unfortunately, some will probably interpret this post as an attempt to manipulate the market in some way. My reputation on FM is important to me, and I would not risk ruining my reputation by posting false test results, or making false claims in this report.
Aug 14, 2005 at 06:27 PM
Taz
Details
p.1 #228mm Test: Zuiko / Canon
Once again, Mike...you've done us all a good service by yet another test. Very much appreciated!
Aug 14, 2005 at 06:43 PM
RobertP
Details
p.1 #328mm Test: Zuiko / Canon
Wow, this is a great test. I have the 2.8/28 distagon, so I wonder how it compares, but this Zuiko looks damn good. I'm taking Guy's advice and I'm currently trying to gather up some wides before I go full-frame.
Aug 14, 2005 at 08:12 PM
Tom_W
Details
p.1 #428mm Test: Zuiko / Canon
I was expecting to see the Canon 28/1.8 in the test.
Actually, I don't think it would have fared any better than the 16-35 and might well have been worse, at least at wide apertures in the corners.
Nice job, Mike.
Aug 14, 2005 at 08:33 PM
Graham Mitchell
Details
p.1 #528mm Test: Zuiko / Canon
Mike, I'm really enjoying these posts. Thanks so much.
Aug 14, 2005 at 08:35 PM
Steve_T90
Details
p.1 #628mm Test: Zuiko / Canon
What's the conventional wisdom on the obvious choice -- the EF Canon 28mm f/2.8? How does the Zuiko or Leica have a discernable edge over the Canon prime?
Aug 14, 2005 at 08:37 PM
Guest
Guest
Details
p.1 #728mm Test: Zuiko / Canon
Another great test Mike. I have the Olympus 28/2 and have not even had a chance to test it yet. Hope it works as well as yours!
FWIW, I have heard this is the sharpest lens Olympus made. (Hard to believe as I've seen some incredible images from Zuiko macro lenses, but it sure looks good here...)
Aug 14, 2005 at 09:09 PM
rico
Details
p.1 #828mm Test: Zuiko / Canon
The EF 28/2.8 was the main lens of my (three year) D30 era. When cropped, it produces a great image, even when wide open. There are just five elements (one aspherical), so contrast is high and field flatness is well-addressed. There's no chromatic aberration to speak of. On FF, the EF28/2.8 is not so hot because the image decays visibly at the far edge, and falls apart completely into the corner. However, the lens is small in size and cheap in price, so I highly recommend it. Just don't compare it to a Leica Elmarit-R 28 at $2500!
Aug 14, 2005 at 09:21 PM
Mr Joe
Details
p.1 #928mm Test: Zuiko / Canon
Thanks for the test. I had heard the 28/2 is supposed to be one of the sharpest of the Oly's. Impressive.
Aug 14, 2005 at 09:53 PM
Makalii
Details
p.1 #1028mm Test: Zuiko / Canon
Thank you, very interesting post. Please forgive my ignorance but can Olympus/Zuiko lenses be used on Canon EOS cameras directly or is some kind of adapter required?
Thanks,
David
Aug 14, 2005 at 10:19 PM
Mike Hatam
Details
p.1 #1128mm Test: Zuiko / Canon
You're welcome David.
You need an OM-to-EOS adapter to use an Olympus Zuiko lens on a Canon EOS body. They are available on ebay or through CameraQuest, and range in price from $80 - $175. I recommend the CameraQuest adapters ($175).
Mike
Aug 14, 2005 at 10:27 PM
Makalii
Details
p.1 #1228mm Test: Zuiko / Canon
Thanks Mike!
David
Aug 14, 2005 at 10:51 PM
RobertP
Details
p.1 #1328mm Test: Zuiko / Canon
How about a Zuiko 24mm f/2 test now!
Aug 15, 2005 at 02:35 AM
Mike Hatam
Details
p.1 #1428mm Test: Zuiko / Canon
Sorry Robert - I don't have a 24/2... someone else will have to do that test
Aug 15, 2005 at 05:27 PM
Cinstance
Details
p.1 #1528mm Test: Zuiko / Canon
I vote for the Zuiko 24/2.8
Aug 16, 2005 at 03:10 PM
Brambling
Details
p.1 #1628mm Test: Zuiko / Canon
The Zuiko aperture ring is at the objective/filter side of the lens focus ring, on the Zeiss lenses it is on the camera body side of the lens focus ring, so on teh Zeiss lenses it can be harder to get your fingers in to adjust the aperture without knocking the focus off.
Mike Smith
Aug 18, 2005 at 03:09 AM
Mike Hatam
Details
p.1 #1728mm Test: Zuiko / Canon
In my experience, it's easier to adjust the apeture on the Zuiko without moving your eye away from the viewfinder and without bumping focus.
As Mike Smith said, it's at the front end (filter end) of the lens, and easier to manipulate than the Zeiss.
Aug 18, 2005 at 07:52 AM
Guest
Guest
Details
p.1 #1828mm Test: Zuiko / Canon
Yep, out front where it is on the Leica M and where it should be on any small lens that gets focused manually.
Aug 18, 2005 at 09:53 AM
Mike Hatam
Details
p.1 #1928mm Test: Zuiko / Canon
Daniel - you'll enjoy this lens
Aug 18, 2005 at 10:03 AM
MarkSaperstein
Details
p.1 #2028mm Test: Zuiko / Canon
I've been comparing the Zuiko 28/2 against the Zeiss 28/2 and Leica 28/2.8 R. The results are very interesting so far. The Zuiko seems to be sharper than the Zeiss at f/2 and f/2.8.
--Mark
Aug 19, 2005 at 12:07 PM
