EnCapture wrote:
this is a misconception. if you take 2 pictures, 1 with a 1.6x crop factor sensor and one with a FF sensor, using the same lens from the same distance, the image from the 1.6x will appear to have a smaller DOF. however, if you take an equal crop from the full framed image and enlarge it to the same size of the 1.6x image they will look identical (aside from any difference in pixel density). the DOF will be the same.
But this is only part of the picture.
The reason the DoF ends up being different is because you have to use different focal lengths to accomplish the same goal. So, say you want to take a headshot of someone, and you want the FoV of an 85mm lens. With a FF camera, you'd use an 85mm lens, with a 1.6 cropper you'd most likely use a 50mm lens. If you look at the math (I'm going to use a mythical 53mm lens for the 1.6 cropper, just to prevent hair splitting), you'll see that from the same distance you get:
85mm from 10ft @ f/2.8: 8.36 inches DoF
53mm from 10ft @ f/2.8: 13.8 inches DoF
So for all practical purposes (the ones that matter), then yes - FF cameras will produce narrower DoF. If you look at the difference between the two cameras, you'll see that 8.36 * 1.6 = 13.376, so the DoF difference calculation is pretty easy. Use the crop factor as a multiplier to get the DoF equivalent as well.
This also illustrates why most Medium Format lenses don't open up past f/3.5 in general. The DoF at f/3.5 is very narrow already, an 1.4 lens on a Medium Format body would be practically useless.
This also illustrates why FF cameras will in general have a sharpness advantage for certain types of photography. If you're shooting at f/1.8 on a 1.6 crop camera to achieve a certain Depth of Field effect, the same image can be obtained at f/3.6 on a FF camera, which with most lenses is much closer to the "sweet spot" in terms of sharpness.
Edited by Sam Bennett on Aug 12, 2005 at 08:23 AM GMT
