Archive 2005 · Flash Tilt Loose
WesleyWong
p.1 #1 · Flash Tilt Loose
Is there a way to tighten the sensitivity (diy) of your flash tilt? I know the tilt wears down after a while - when i first got my 420ex and 550ex the tilt used to be sturdy and tight but after time it loosens up. Does anyone know a way to fix this?
This has never been an issue for me but I recently purchased a Lightsphere II and the weight causes my tilt to unlock itself and fall over. I hope this makes sense.
Jun 27, 2005 at 10:51 PM
WesleyWong
p.1 #2 · Flash Tilt Loose
...maybe i am alone..
Jun 29, 2005 at 11:55 AM
nutek
p.1 #3 · Flash Tilt Loose
hmmm now you mention it, I found out that I have the same problem (with the lightsphere) too..
I looked around, but I don't see any screw that can be tightened though..
Jun 29, 2005 at 12:16 PM
WesleyWong
p.1 #4 · Flash Tilt Loose
i guess its all internal.
Jun 29, 2005 at 07:05 PM
Monoman
p.1 #5 · Flash Tilt Loose
the MAIN issue with myt LSII is it's weight. It will wear down my flash if I keep using it. This has made me a little weary...
Jun 29, 2005 at 08:40 PM
