       2       3       end
Archive 2005 · RAW 4-way comparison
Joe Marques
p.1 #1 · RAW 4-way comparison
This is my no means scientific. I simply processed a shot through 4 different RAW converters (WB tweaked by clicking on the shirt, levels tweaked, hilights tweaked where needed - all basic stuff done in less than 2 minutes). I purposely chose a 50 1.4 shot wide open in natural light (indoors with window light) at ISO 1600 since I was most curious about how each converted rendered noise (no noise reduction applied in converting) and WB.
The software compare:
Adobe Camera Raw 3.1
Canon Digital Photo Professional 1.6.1
Bibble 4.2.6
Raw Shooter Essential 1.1.2
Here's the 4-way comparison:
http://www.pbase.com/ranger099/image/43480725.jpg
Here's a 50% crop showing a noisy shadow area:
http://www.pbase.com/ranger099/image/43480737.jpg
Personally I like ACR the best although RSE is not far behind and has the best upside because it's browsing speed is the fastest and it's processing speed is second fastest (behind Bibble).
HERE IS THE ORIGINAL SHOT PROCESSED STRAIGHT THROUGH ACR (NO TWEAKS)
http://www.pbase.com/ranger099/image/43533691.jpg
Edited by Ranger099 on May 17, 2005 at 12:19 AM GMT
Edited by Ranger099 on May 17, 2005 at 10:04 PM GMT (Reason: added unprocessed shot)
May 16, 2005 at 11:50 PM
Tim Wild
p.1 #2 · RAW 4-way comparison
Great comparison, thanks I find the ACR noise reduction pretty crappy, I turn it off and let noise ninja do it all inside my batch convert action.
Edited by Tim Wild on May 18, 2005 at 11:48 AM GMT
May 17, 2005 at 12:13 AM
Joe Marques
p.1 #3 · RAW 4-way comparison
My pleasure Tim. Note that I didn't use any noise reduction - I wanted to see how the converters RENDERED noise and ACR rendered the least color noise of the bunch.
May 17, 2005 at 12:18 AM
Tim Wild
p.1 #4 · RAW 4-way comparison
I think the defaults of ACR do a little sharpening and noise reduction, but it depends how you have yours set up, or you could have turned it off.
May 17, 2005 at 12:21 AM
Joe Marques
p.1 #5 · RAW 4-way comparison
I do turn off NR and sharpening in ACR - I like to control both aspects in PS.
Thanks,
Joe
May 17, 2005 at 12:25 AM
gervaise
p.1 #6 · RAW 4-way comparison
Thanks, Joe, this is a good simple comparision. Although I have not used RAW Shooter, I tend to agree that the ACR is the best unprocessed beyond where you left it, and I agree that the sharpening and other stuff is best done in PS/CS2. Thanks for posting this.
May 17, 2005 at 01:20 AM
Steve Tinetti
p.1 #7 · RAW 4-way comparison
What would these files look like without all your tweeking and just convert them "as shot"?
Steve
May 17, 2005 at 01:54 AM
andy1100xx
p.1 #8 · RAW 4-way comparison
Steve
I'd be interested in this as well, just to eliminate any unintentional 'human' interference.
May 17, 2005 at 02:07 AM
m3rocket
p.1 #9 · RAW 4-way comparison
Just keep in mind, that "as shot" mean different things to different converters. To DPP, it's the parameter settings on the camera. For RSE, camera settings are ignored, and the "default" is tweakable on a per camera, and per ISO basis. In looking at the "test," it seems fairly clear to me that ACR is doing some color noise reduction--turning off NR there probably simply turns off luminance noise reduction.
May 17, 2005 at 04:39 AM
simonbaker
p.1 #10 · RAW 4-way comparison
your tests demonstrate nicely the problem with skin shadows I have always been having with ACR. There always seems to be very little colour depth in these areas, everything resolves to 3 or 4 tones of browns or yellows. Your RSE example shows better shadow resolution, but overall the portrait is much flatter than the ACR example - something I've been seeing a lot of in my results. Otherwise I'm reasaonably impressed with the Pixmantic product.
May 17, 2005 at 05:14 AM
jamesf99
p.1 #11 · RAW 4-way comparison
Great test. When I first looked, the ACR was the brightest and appeared to be the "best". Now, I'm not so sure.
The picture is flatter than the DPP rendering. Only you can tell us which skin/hair colors are closer to your subject's, but the skin tones of DPP look more real (albeit with somewhat of a gray cast that could be removed). Look at the right eye (on the left for those who don't know right from left ). There is clearly more depth in the DPP version.
Jim
May 17, 2005 at 08:35 AM
pchew
p.1 #12 · RAW 4-way comparison
Would be interested to see a result from EVU. My own experience shows that EVU gives the best skin tone for RAW conversion.
Perry
May 17, 2005 at 09:03 AM
Nowhere Man
p.1 #13 · RAW 4-way comparison
great test. i'd be interested to see how it handles different types of subjects, like landscapes, and at differnet iso's.
the ACR looks best to me in the images your provided. thanks for sharing!
emo
May 17, 2005 at 09:39 AM
steve_t
p.1 #14 · RAW 4-way comparison
Guy Mancuso wrote:
Be nice to have C1 in there but what i find weird is the colors look better or more natural in RSE but that is were they are the weakest otherwise I would switch to them from C1. I will admit been palying around with the new Arc 3.1 and it is much better at workflow but still can use improvement there but the images are looking better
The seem to have been working on colour since V1.0 (which was somewhat strange in other than flat mode).
May 17, 2005 at 09:44 AM
BeeMan458
p.1 #15 · RAW 4-way comparison
"...but what i find weird is the colors look better or more natural in RSE..."
I think what you're seeing is the blue cast that has been added.
Please forgive me if you find my following to be nutty thinking.
Put some blue glasses on and go outside, high noon, blue skies with a few fluffy clouds in the sky. Where the glasses for a few minutes. Raise the glasses, lower the glasses and then raise them again.
In my case, I became painfully aware of how much yellow/jaundice is in reflected sunlight as opposed to the blue cast we've all been taught that is natural daylight.
It ain't the way we've been taught to see folks.
Look at the clouds in the distance and you'll see the clouds, if the sun is out, have a bit of a yellowish/jaundice look to them as opposed to being white or grayish white as we've been taught to think of the coloration of clouds.
We are clouding (no pun intended) our seeing with what we've been taught as opposed to seeing things as they really are.
Please don't lock me up for what I wrote above.
May 17, 2005 at 09:51 AM
Sam Bennett
p.1 #16 · RAW 4-way comparison
I'd love to see you do this test again, but at least match the exposure/contrast levels. I don't think any of use the defaults these tools give us.
May 17, 2005 at 09:57 AM
Pablo
p.1 #17 · RAW 4-way comparison
I might be missing something, but to me the Canon image processing looks more realistic. The others are nice and warm. I agree they look nicer, but I think the Canon looks more realistic.??
May 17, 2005 at 10:03 AM
Sam Bennett
p.1 #18 · RAW 4-way comparison
For me it's all about workflow. I know that C1 and RSE can produce results close to DPP, but I've found that DPP gets me where I want to be much more quickly - basically I end up just spending a long time tweaking C1 and RSE to give me what DPP would give me by default. Bibble is a total no-go for me since it simply can't deal with super-saturated color channels in my concert photography work.
May 17, 2005 at 11:28 AM
Steve Tinetti
p.1 #19 · RAW 4-way comparison
I agree with Guy, a color chart would be a good idea. Perhaps even a custom white balance shot. Workflow is indeed important also. Since many images still need to some PS tweeking anyway, a converter that allows you the best combination of quality and speed might be best.
With all due respect to the original poster, who specifically stated this was not scientific; this type of "test" should be conducted under more controlled conditions, to narrow the subjective to the objective, IMO. As it is, we're going back and forth based on our subjective opinions of a subjective test shot under subjective conditions. Without a known value anywhere in the shot, how can we agree on anything?
Steve
May 17, 2005 at 12:05 PM
Joe Marques
p.1 #20 · RAW 4-way comparison
...Show more →
Hi Steve,
Thanks for the respect - this response is not a disagreement, it's just my rationale for posting. I actually chose my subject title well and called this a comparison. As a test it's fairly useless - as a comparison it has some value. I approach RAW conversion from a subjective perspective - I have a "look" I want to achieve based on how I saw the shot when captured and a "time value" relating to the effort it takes to achieve that look. I showed this comparison of my basic "quick conversion" using as many pre-sets as possible to get a good result. I subjectively find ACR the best output but RSE the easiest to achieve "close enough".
I do like your idea of a controlled test and I will do so with a GM color chart because I too am curious how each converter handles WB by clicking a color patch. It will also provide objectivity for a entirely different evaluation of RAW converters.
Thanks for posting.
May 17, 2005 at 01:25 PM
       2       3       end
       2       3       end
