Archive 2005 · Canon 70-200l f4 with 500D
jdevarennes
p.1 #1 · Canon 70-200l f4 with 500D
Does anyone have experience using this combination? The canon 70-200l f4 with a 500D. If so could you share some photos. I am looking to purchase this combination in the next few days and would really appreciate some feedback. Thanks in advance.
Jason
May 02, 2005 at 02:17 PM
boblaw
p.1 #2 · Canon 70-200l f4 with 500D
Here's one taken recently. No Photoshop editing.
May 02, 2005 at 02:32 PM
khiromu
p.1 #3 · Canon 70-200l f4 with 500D
I use 500D with its big brother (70-200IS) and works very good. I also have 77-72 step down ring and use it on 135 / 85, too, and the bokeh are exellent. If you plan on using it on other lens, make sure to buy the largest one such as 77mm instead of 67mm.
May 02, 2005 at 02:53 PM
nutek
p.1 #4 · Canon 70-200l f4 with 500D
http://www.galant-ho.com/fall04/phipps/crw_9565.htm
I usually use the 500D with the 100-400 IS instead. With the 70-200 F4, it's a perfectly usable combo, but if you have the IS version, it's even better.
May 02, 2005 at 02:58 PM
losloslos
p.1 #5 · Canon 70-200l f4 with 500D
Hey, I haven't seen one of your posts (with your URL) in a long time, what a cool URL...and I've used some of your street shots via browser to show friends the "type" of street PJ photography you like to do...cheers!
I'm also looking to use a 500D + 70-200 2.8 IS for my pawnshop work. I found that the borrowed 50macro was too close to my http://www.clouddome.com/specs/tent1.htm Cloud Cube or my Cloud Dome for pawnshop. I rented a 100macro (I recommend renting lenses OFTEN before buying, no kidding) and it didn't have QUITE the distance I wanted either (1.6 crop). I'm upgrading body-wise shortly, one of the mk2's, and either way, I lose more working distance.
This in combination of wanting less lenses to tote around, less $'s spent, I'm gonna try it, I've seen many "good enough" images using the combo...and, my main macro usage is pawn shop type stuff.
G.
May 02, 2005 at 03:20 PM
