The coatings are optimized for each lens - so comparing a 50 to 35-70 is apple & oranges. T* ensures a constant coloring across the Zeiss lenses. It's not a constant formulation unviersally applied to all Zeiss lenses.
The closest thing you could compare are two of the same lenses - say a 50/1,4 AE and 50/1,4 MM and see if the front optic reflects differently. But, that only tells about the front optic (and rear) optic - not the internals. Each optic within the lens is also coated.
I suspect if you took the same MM lens that was in production for 10 years and compared one from year 1 to year 5 to year 10 - you'd see differences.
