fredmiranda.com Login
This topic is in the 2005 archive. You can read it and like its posts here. It is read only.
Archive 2005#22: Multiplicity
Rob_O
p.1 #1#22: Multiplicity
Four 8-second exposures blended to create a single image.
I tried to do a single 20-30 second exposure, moving from position to position after 6-8 seconds or so at each ... but it didn't work as well.
20D, Canon EF-S 17-85 IS USM lens, ISO 200, Av between 5.3 and 6.0 (varied for each image), Tv 8 seconds (x4), focal length 53mm, no noise reduction, USM 100/.3/0.
Comments and critique welcome.
Mar 26, 2005 at 09:42 PM
falco
Details
p.1 #2#22: Multiplicity
That is way cool. Very nice work.
Mar 27, 2005 at 05:16 PM
Rob_O
Details
p.1 #3#22: Multiplicity
Thanks falco.
Mar 28, 2005 at 10:56 AM
mbohunsky
[X]
Details
p.1 #4#22: Multiplicity
Very nice work, as always. OZ Supperleggeras huh? Nice choice.
Mar 28, 2005 at 10:12 PM
Rob_O
Details
p.1 #5#22: Multiplicity
Thanks Milan.
And, yes ... OZ SLs. Gotta love 18x8 alloys (cast, no less) that look good and weigh only 17.6 lbs!
Mar 30, 2005 at 09:40 PM
begreen
Details
p.1 #6#22: Multiplicity
That looks like Arizona. (Nice shot, by the way).
Mar 30, 2005 at 11:04 PM
Rob_O
Details
p.1 #7#22: Multiplicity
That's because it is Arizona. McDowell Mtn range in the Sonoran Desert, NE Scottsdale area.
Cheers
Mar 31, 2005 at 12:15 PM
lxdesign
Details
p.1 #8#22: Multiplicity
wow - only 8 seconds .. you must had to move fast between positions - nice work.
Mar 31, 2005 at 01:40 PM
Rob_O
Details
p.1 #9#22: Multiplicity
Well, it's four (4) 8-second images stacked (blended in photoshop). So, technically there are 24 seconds worth of work represented. ;-)
Mar 31, 2005 at 02:11 PM
webrxinsd
Details
p.1 #10#22: Multiplicity
I am curious how you were able to get 24 seconds of exposure without blowing out everything - was this taken at night or with an ND filter?
d
Apr 01, 2005 at 12:10 AM
Rob_O
Details
p.1 #11#22: Multiplicity
d
Dave,
These shots -- which are four (4) 8-second exposures blended, as opposed to a single 24-second exposure -- were indeed done very late in the day and well after the sun was below the horizon. In reality, it was damn near dark (notice the lights on the house off in the distance, as well as reflections of lights in the front bumper). No ND filter employed however.
Note that I was able to pull of up to 30-second exposures without blowing out details, but those looked like mid-day photos they were so bright.
Apr 01, 2005 at 10:37 AM
chris78cpr
Details
p.1 #12#22: Multiplicity
Can you go into how you blended them a little more
Awesome shot by the way. I think i am going to have to try some of this stuff.
Chris
Apr 05, 2005 at 10:54 AM
ruuskan
Details
p.1 #13#22: Multiplicity
Love the effect, creates a good image!
Apr 05, 2005 at 11:26 AM
Rob_O
Details
p.1 #14#22: Multiplicity
Chris
Thanks Chris.
There are a number of ways to blend images such as this. Assuming you have at least some experience with/exposure to Photoshop (or Elements), here's how I chose to do these specifically. If you're not familar with PS, the following might sound like a foreign language.
First, recognize that the four shots represented here were snapped in succession from a tripod in the same location/position within seconds of each other. Therefore, other than my (ghostly) image, all of the details from each photo are the same (car, background, etc). That made it quite easy to overlay them in Photoshop (no stitching or anything, as has to be done with panos).
I'd estimate a minute and a half to two minutes elapsed between taking the first and last image. The camera was set to 8-seconds in Tv mode and pre-focussed based on test shots prior to shooting these. I used a 10-second delay, so I could manually trigger the shutter then get myself into place. One thing I would probably do differently next time, or at least try to see if it made a difference, would be Exposure Lock ... which I didn't employ for these. As a result, the Aperature value varied slightly from one exposure to the next. This introduced a slight variation in contrast between the first image taken and the last, likely a result of how fast I was losing light at the time of day these were taken (damn near dark).
With my four 8-second exposures transferred from camera to computer, I pulled them all into Photoshop. Using the first image take as a "base", I stacked the other three atop it as individual layers, then aligned their vertical and horzontal centers (so everything was all lined up). I now had a file with four layers, one for each exposure, and could proceed with blending them.
As mentioned, there are a number of ways to blend the images from here. I chose to mask (make invisible) the portions of each photo I didn't want/need -- i.e. background stuff -- and leave visible only the area where I'm in the photo. To do this, I used the Rectangular Marquee tool to select/designate the area where I appear in each of the three overlay photos (performed indidually on each image). With the selected area active, I masked the rest by clicking ctrl+al+I to inverse the selection, then clicking the Mask button at the bottom of the Layers pallete. Now only the "cropped" area was visible. From here I could see how each of the "me" images overlayed on the base photo. I then fine tuned the exposures of each to match; this was mainly a slight contrast/brightness adjustment, but I did look at Levels as well. With each now exactly the same, exposure-wise, I used the Brush tool to further refine my masks on each layer where the isolated images of me overlapped (select the mask for a given layer, set foreground to Black, select Brush tool and set brush properties accordingly).
Once all of that was done, I had essentially the image you see here. I reduced image size (dimensions) to the requisite 640 px max length, then applied a modest 100/.3/0 USM before saving.
Apr 06, 2005 at 10:18 AM
Rob_O
Details
p.1 #15#22: Multiplicity
Thanks ruuskan.
inov8iv
Details
p.1 #16#22: Multiplicity
Looks like a NASCAR pit stop except to get the car washed.
Thanks for sharing,
Apr 06, 2005 at 01:09 PM
Badvmc
Details
p.1 #17#22: Multiplicity
Nicely done, good effect.
Apr 06, 2005 at 02:15 PM
Tim Speciale
Details
p.1 #18#22: Multiplicity
This would go well in this weeks assignemnt as well
Apr 07, 2005 at 11:52 AM
Rob_O
Details
p.1 #19#22: Multiplicity
Thanks Guy, Gilles and "timmy".
Apr 08, 2005 at 10:23 PM
FM ForumsMonthly AssignmentsJoin Upload & Sell
