Archive 2005 · Confused by Cokin Filter System
Feifei
p.1 #1 · Confused by Cokin Filter System
I'm confused by the Cokin Filter System. What are the differences among "A Series", "B Series", and "X-Pro Series".
Thanks!!
Mar 23, 2005 at 06:00 PM
nutek
p.1 #2 · Confused by Cokin Filter System
A = point and shoot
P (there's no B) = 35mm SLR up to 82mm lens diameter (but this is misleading as the internal diameter of the Cokin holder is only around 74.5mm...)
X-Pro = 35mm SLR with large diameter lenses, MF and above
Edited by nutek on Mar 24, 2005 at 04:32 AM GMT
Mar 23, 2005 at 06:31 PM
RDKirk
p.1 #3 · Confused by Cokin Filter System
Overall size. The A series is pretty small by today's standards--they'll fit lenses up to about 62mm. The P series is larger and the XP series larger still. You can get the actual figures on the Cokin USA web site or the Adorama or B&H item descriptions.
Mar 23, 2005 at 06:32 PM
Mert
p.1 #4 · Confused by Cokin Filter System
I'am using their P series system with 58mm,67,mm,72mm,77mm and 82mm adapters.
Value and performance is good but dont buy their c.polarizer filters
Mar 23, 2005 at 07:06 PM
Pete Wilson
p.1 #5 · Confused by Cokin Filter System
A - Amateur
P - Professional
XP - xtra large professional
Most 35mm and dslr photographers who use the Cokin system use the P series. The basic Cokin system consists of a filter holder, an adapter ring and of course a filter. The adapter rings are purchased in different sizes to fit the diameters of each of your lenses. The rings are screwed into the lens like a screw on filter then the filter holder slides over the ring and snaps into place.
Several other companies (Lee, Singh-Ray, Hitech) make filters which will fit in the Cokin P size filter holder.
Mar 23, 2005 at 07:11 PM
milouvision
p.1 #6 · Confused by Cokin Filter System
More details on the system: http://www.intro2020.co.uk/pages/cokin.htm
Mar 23, 2005 at 07:50 PM
Feifei
p.1 #7 · Confused by Cokin Filter System
Thank you guys!!!
Your informations are really helpful!!! Thank you!!
Mar 24, 2005 at 10:58 AM
