fredmiranda.com Login
This topic is in the 2016 archive. You can read it and like its posts here. It is read only.
Archive 2016Lightroom and AMD Radeon vs NVIDIA Geforce
JoeMelzer
p.1 #1Lightroom and AMD Radeon vs NVIDIA Geforce
Hi all,
as approximately 100% of all people using Lightroom do, i struggle with the so-called performace of Lightroom. I tried every trick and every guide, have my computer quite maxed out. So ...
When nvidia presented the new Geforce 1070 / 1080 I thought maybe it's time to change graphics cards. Currently I have something like an amd radeon 7950, that is about 4 years old now. But in the last months I did not find a single article/thread/opinion/blogpost/tweet about the performace in Lightroom. Obviously, in After Effects or Premiere those new cards can significantly boost performace. But what about lightroom?
Is there anybody out there who switched from amd to nvidia (or vice versa) and can talk about performace differences? I currently drive to displayes, one WQHD and one 4K. So, a lot of pixels to push. Of course I use Lightroom on the 4K Dispaly, because pictures look so damn good.
Please, anyone? Opinions, Links, Reports?
Thanks a lot
Aug 23, 2016 at 05:09 AM
Ian.Dobinson
Details
p.1 #2Lightroom and AMD Radeon vs NVIDIA Geforce
Joe I guess it depends on where you "struggle with the so-called performace of Lightroom"
LR doesn't use the GPU in anything other than a few functions in the DEVELOP MODE . so if you are hoping that a new GPU will suddenly make LR a speed monster then I think you'll be disappointed .
that said I have to say I can't be one of your 100% of people (so you'll have to downgrade to 99.999999% at least )
i don't find LR slow on either my 2012 i7 iMac or my (not exactly power house) 2013 base i5 macbook air .
I know where LR will take its time and my workflow's are such that LR can do its thing at its own pace while I'm either not at the machine or I'm doing other stuff . most people rag on about the 'lag' going between images etc . but getting LR to build 1:1 previews before you start stuff and not going between images while in DEVELOP (where it will redraw its preview even if a 1:1 exists) basically removes any of that 'lag'
other stuff like large exports etc I just go do other stuff while LR does its thing .
as for stuff in develop maybe its a mac thing but I really never notice any issues moving sliders around with or without the GPU turned on . back when I was using a PC (home build) then yes I did find stuff in develop to be an issue at times but my machines were built on the cheap and that was also back when i was using LR4 (which I have to say was a ta slower )
Aug 23, 2016 at 07:40 AM
15Bit
Details
p.1 #3Lightroom and AMD Radeon vs NVIDIA Geforce
The issue of GPU performance is a tricky one in general, and when i posed the same question a couple of years ago here and on the Phase One forums (about GPU performance in Capture One) i got no useful info.
There are two programming interface options which can be utilised - OpenCL and CUDA. OpenCL is an open standard, CUDA is NVidia only and came first. Some things are programmed in one, some in the other. Adobe has used both in PS, and i don't know if they have ported the CUDA stuff over to OpenCL.
In terms of raw performance, the latest 1000 series NVidia cards totally dominate for Single Precision compute performance, though for Double Precision calculations the AMD cards are quite a bit faster due to the way that NVidia implement their DP pipeline. The majority of compute tasks are apparently Single Precision, and i assume that is the case for LR/PS also. Double Precision calculations are more commonly required for scientific computing where higher levels of accuracy are needed. I've never seen any comments from any application writer about their "Precision" though, so the assumption of Single Precision is just that, an assumption.
Another consideration is that the NVidia cards use quite a lot less power than the AMD's.
All that said, i have a GTX970 driving 1920x1200 and 1680x1050 screens (on an overclocked i5 running at 4.3Ghz) and the difference in LR between "Use Graphics Processor" being ticked and not ticked is not all that dramatic. There is a difference though.
Aug 23, 2016 at 12:44 PM
Greg Campbell
Details
p.1 #4Lightroom and AMD Radeon vs NVIDIA Geforce
IMO, LR GPU "performance" is more of a marketing gimmick than a truly useful feature.
In any event, it's not remotely worth blowing many hundreds on a high-end video card.
Aug 23, 2016 at 06:35 PM
JoeMelzer
Details
p.1 #5Lightroom and AMD Radeon vs NVIDIA Geforce
Thank you all so far. To specify matters: I know that GPU only speeds up the develop process. I am aware of CUDA, OpenGL (OpenCL) and all related stuff. But although I build 1:1 previews there is quite some lag (2-4 seconds) when switching images. D800 RAWs for that matter. As far as I picked up bits and pieces, switching images is CPU driven, developing is GPU driven. So the switching process will not benefit from a newer GPU.
For me, the speed increase from LR 5 to LR 6 and therefore from CPU developing only to GPU supported developing was quite dramatic. It might be the combination of a 4K screen and large RAW files. Therefore I imagine, there might be another speed boost.
Oh, and by the way, I tried increasing cache size, using smart previews, tried moving the cache folder to a ram disk. None of these methods led to a real speed boost...
Any other thoughts?
Aug 24, 2016 at 01:36 AM
elkhornsun
Details
p.1 #6Lightroom and AMD Radeon vs NVIDIA Geforce
Photoshop application performance depends on the CPU, amount of RAM, and I/O performance (which is why a SSD or two can help in some areas).
At least with CS6 there is a tremendous amount of drive fragmentation that occurs and I finally added a dedicated scratch disk to my computers that I use for post processing. Do a defrag after using CS6 for a day and see how fragmented the drive has become. With batch processing of 2,000 files after a wedding I would have to defrag the drive that I had already defragged before starting the batch processing.
This is one reason I prefer to use a tower computer so I can have the operating system and applications on one drive, my input data on a second drive drive, a third scratch drive, and output data gets sent to a fourth drive.
Video card performance is important for CAD, gaming, and video editing, and not at all for Photoshop or Lightroom.
With most applications there is a key bottleneck and for single image processing it is going to be the drives I/O performance and the speed of the CPU so long as there is an adequate amount of RAM and a 64-bit operating system.
Aug 26, 2016 at 05:40 PM
Ian.Dobinson
Details
p.1 #7Lightroom and AMD Radeon vs NVIDIA Geforce
...Show more →
More thoughts
1: But although I build 1:1 previews there is quite some lag (2-4 seconds) when switching images. D800 RAWs for that matter.
but where are you switching images ? Library or Develop ? in develop LR redraws even if there is a 1:1
2:Oh, and by the way, I tried increasing cache size, using smart previews, tried moving the cache folder to a ram disk. None of these methods led to a real speed boost...
if your machine can still see the original raw file then smart previews have no relavence as they are only used as a substitute .
it may be the size of the files and the 4K screen . I will admit I've never played with files that large (i use a 5D3) and my iMac is the old screen res (2k ? ) . but then again I can flick thru my raw files without lag on my macbook air as well . not just on the air's screen but when connected to a HD TV/Monitor .
Aug 27, 2016 at 01:35 AM
JoeMelzer
Details
p.1 #8Lightroom and AMD Radeon vs NVIDIA Geforce
Ian.Dobinson wrote:
1:
Earlier quoteBut although I build 1:1 previews there is quite some lag (2-4 seconds) when switching images. D800 RAWs for that matter.
I thought, this is so stupid, it can't be true. But it is! How stupid is that? Switching in Library is instantaneous, switching in Develop takes 3 seconds. Of course, If I cull and edit, I switch in Develop, not in Library. So building previews in advance takes time and does not speed up editing at all?
Thanks for that remark, I'd have never thought of that ...
Aug 27, 2016 at 05:37 AM
Ian.Dobinson
Details
p.1 #9Lightroom and AMD Radeon vs NVIDIA Geforce
bingo
I full in lib mode and if I want to take something to develop then it's only a quick keystroke away . D for develop , R takes me straight to crop (my most used area when I cull ) and G goes straight back to grid in library
Things speed along just fine like that
Aug 27, 2016 at 06:58 AM
OntheRez
Details
p.1 #10Lightroom and AMD Radeon vs NVIDIA Geforce
The tips are all good and I wasn't aware of a few of them. I believe that it can be stated, categorically, that Lr makes little or no use of the GPU to enhance performance. I'd also add that I really don't believe that Adobe actually cares about improving/quickening Lr. It's a cash cow, and they own the market.
I'm quite familiar with the difference between single and double precision as I've spent a fair amount of time in my checkered career working massive data sets with complex multivariate analyses. Definitely a difference.
I'm running a fairly recent iMac (late 2013), NVIDIA GeForce GTX 780M 4096 MB, 3.5MHz i7, and 32GB RAM. Honestly, I didn't see that much improvement in either program when moving from a 2010 dual quad Mac Pro (1 GB VRAM, don't remember brand/number) though the iMac's 64bit bus was an improvement over the Mac Pro's 32 bit.
Everything involved in my PP is SSD based. The OP has not mentioned if he's running off disk or SSD. If you haven't moved to SSD, do so before you spend money on anything else.
As for Lr performance, I find it abysmally slow to load (with a USB3 device), have to wait a count of maybe 1,2,3 when switching from Libray to Develop (the selection for module switching is absolutely the same no matter which method you use to change), and god forbid having to change catalogs. Most of the adjustment sliders are fairly responsive, though a couple seem to stumble a bit. I'm running openGL, giving Lr access to far more RAM than it needs, a large SSD scratch disk. Previews are set minimum and lowest resolution with no 1:1. If you go to Perferences>Performance>System Info you'll get some rather interesting information. Also look at the catalog settings.
One of Lr's truly sluggish action is generating the preview after returning from a plugin (in Develop). This not waiting on the plugin to write (which varies widely, but after it has completed its action, Lr getting around building a preview.
All in all, I'd postulate that a newer/faster graphics card isn't going to make much difference. Disk speed, RAM to some extent, and control of preview building are the only things I've found that help. Bluntly, in my not so humble opinion - Lr is a dog - and unlikely to ever be rebuilt to maximize modern hardware/graphics.
Robert,
I do everything in RAW, and they do get ever bigger, but I don't think that's the key issue. Just my nickel's worth of my experience. (I would note that people's perceptions of fast/slow can and do vary widely.) Also, no experience with 4K monitors so haven't a clue. To the OP, don't waste your money on a Graphics card swap. Faster processors and plenty of RAM are about all you can do.
Aug 27, 2016 at 09:52 AM
Paul Mo
Details
p.1 #11Lightroom and AMD Radeon vs NVIDIA Geforce
Ian.Dobinson wrote:
bingo
I have a Logitech gaming mouse and have assigned two buttons to G and D - switching between Library Grid view and Develop module is just under my left index finger.
Aug 27, 2016 at 11:02 PM
CanadaMark
Details
p.1 #12Lightroom and AMD Radeon vs NVIDIA Geforce
Photoshop uses the GPU more than Lightroom, which is almost entirely CPU except for a few things (excluding plugins). Also, keep in mind that certain plug-ins are very GPU heavy (Like some of the NIK Plug ins, and especially HDR processing). Nvidia's Kepler cards do particularly well as double duty cards, especially the Titan X. So well in fact that it Nvidia fixed that going forward so people would buy the Quadros instead of the Titans haha. I can easily use 3-4 GB of video RAM in Photoshop, and I noticed a huge difference when I upgraded my video card. Photoshop would completely crash when it maxed out my VRAM, now that I have a Titan X with 12GB RAM, all my issues were resolved. It can and does make a difference, but you have to balance that with specifically what you use Photoshop/LR for, because it may or may not make a big difference.
You can't make a blanket statement like "don't waste money on a video card" because the answer is "it depends". There are scenarios where it can make a significant difference, and there are scenarios where it will make zero difference.
Aug 30, 2016 at 03:42 PM
