       2       3       …       7       8       end
Archive 2016 · RX1RII recall notice
Admin
p.1 #1 · RX1RII recall notice
Sony released a RX1RM2 Notification today
Posted: 1/19/2016
"Thank you for being a loyal Sony customer. We work hard to ensure your experience with our products and services exceeds your expectations.
Unfortunately we have found that in rare bright conditions, some of our DSC-RX1RM2 cameras may produce image files with unwanted light.
If you experience this problem and your camera falls within the serial range listed below, please contact us at 1-239-245-6360 for a free inspection and service. Please note this free inspection is available until March 31, 2018. If your serial number does not fall within this range, we can assure you that your camera will not present the symptom described above.
We sincerely apologize for any inconvenience you may experience."
Digital Still Camera DSC-RX1RM2 - Affected Serial Numbers
Some products with serial number from 6310198 to 6311127
Here is the Sony support page for more information.
_______________________________________
B&H Photo already has new RX1RII (without the above issue) In Stock right now:
http://www.bhphotovideo.com/c/product/1190330-REG/sony_dscrx1rm2_b_cyber_shot_dsc_rx1r_ii_digital.html
Jan 19, 2016 at 08:09 PM
Admin
p.1 #2 · RX1RII recall notice
Is there any light leak user report with the RX1RII?
Jan 19, 2016 at 08:11 PM
Jeff Kott
p.1 #3 · RX1RII recall notice
Fred, my serial number indicates that it could be affected.
How would you suggest that I test for the light leak?
Jan 20, 2016 at 01:30 AM
dandrewk
p.1 #4 · RX1RII recall notice
Here's what I did - ISO 3200 (or above) @1 second (or greater): Take a shot with cap on lens, using the brightest flashlight you have shining directly on each corner of the extended EVF, where it meets body.
For me, pointing the light at the left edge produced a blue flash on the edge of the frame. I have a "ballistic grade" LED flashlight, so it's probably more intense than direct sunlight. Nevertheless, it was affected, so most likely I'll be sending the camera in.
Jan 20, 2016 at 02:14 AM
Admin
p.1 #5 · RX1RII recall notice
If your camera serial is within the above range, I would send it in. If light passes through the EVF opening, dust and moisture could reach the sensor as well.
Also, there could be other 'silent' fixes.
Jan 20, 2016 at 10:44 AM
realVivek
p.1 #6 · RX1RII recall notice
Fred Miranda wrote:
If your camera serial is within the above range, I would send it in. If light passes through the EVF opening, dust could reach the sensor as well.
Excellent point!
Here are light leak images:
http://www.getdpi.com/forum/sony/57440-sony-rx1r-mk-ii-light-leak-pictures.html
Jan 20, 2016 at 10:58 AM
mogul
p.1 #7 · RX1RII recall notice
If you are not the original owner, will Sony exchange the camera?
Jan 20, 2016 at 11:42 AM
GMPhotography
p.1 #8 · RX1RII recall notice
Great question. I have run into this with warranties before. Some OEMs it's the owner and some it's the gear regardless. I think Sony it's the gear not the owner.
We need to see what they are planning to do. this is going to be interesting to watch how they handle this. To me they should replace all units affected. That's me though
Jan 20, 2016 at 11:47 AM
AGeoJO
p.1 #9 · RX1RII recall notice
Aaah, teething problems - apparently, even Sony is not immune to initial issues, which are not limited to only Nikon and Canon .
Jan 20, 2016 at 11:52 AM
snapsy
p.1 #10 · RX1RII recall notice
Sony's warranties are transferable.
Jan 20, 2016 at 11:54 AM
Jeff Kott
p.1 #11 · RX1RII recall notice
Fred,
I just want to thank you for how helpful you've been with my new RX1rii. I really appreciate your insightful testing and practical advice on setting up the camera, accessories, etc. I read several photo websites regularly (FM is the only group of forums that I read reguarly) and find your advice and comments to be the most practical, balanced and informative of any that I have seen. I also find this place that you have created to have the best group of posters for info and inspiration on the web.
As a side note, to show my appreciation, I now try and make all my photo and computer purchases through your B&H affiliate link.
jk
Jan 20, 2016 at 12:11 PM
Admin
p.1 #12 · RX1RII recall notice
Jeff Kott wrote:
Fred,
...Show more →
Thank you Jeff! I really appreciate it.
Jan 20, 2016 at 01:19 PM
Admin
p.1 #13 · RX1RII recall notice
BTW: I just called 1-239-245-6360 and the Sony representative told me that my camera won't be repaired. Instead it will be replaced for a brand new one. I really wanted to get it fixed instead because the lens is perfectly centered but he said that won't be possible.
FYI: The FedEX return shipping label will be here today and once Sony gets my RX1RII, it will take 7 business days to get the new one.
Jan 20, 2016 at 01:23 PM
slickturner
p.1 #14 · RX1RII recall notice
Same here Fred.
Jan 20, 2016 at 01:33 PM
snapsy
p.1 #15 · RX1RII recall notice
Fred Miranda wrote:
BTW: I just called 1-239-245-6360 and the Sony representative told me that my camera won't be repaired. Instead it will be replaced for a brand new one. I really wanted to get it fixed instead because the lens is perfectly centered but he said that won't be possible. FYI.
In that case they must be sending the replaced cameras back to Japan, either for rework to be sold as 'B' stock or to reclamate parts for new bodies.
Jan 20, 2016 at 01:36 PM
GMPhotography
p.1 #16 · RX1RII recall notice
They can certainly recycle the lens and sensor. The rest just trash IMHO
Jan 20, 2016 at 01:39 PM
Tariq Gibran
p.1 #17 · RX1RII recall notice
Fred, I thought you said earlier your RXIrII's are not in the affected serial range?
Jan 20, 2016 at 06:00 PM
Admin
p.1 #18 · RX1RII recall notice
Initial reports came from Europe. Apparently different countries have different serial number ranges. For the US, the affected serial numbers are from 6310198 to 6311127.
Most folks who pre-order the camera in the US are affected by the recall notice.
Jan 20, 2016 at 06:35 PM
Tariq Gibran
p.1 #19 · RX1RII recall notice
Sorry to hear that. I suspect you are right about the possibility of some silent upgrades and I bet your replacement is as sharp as the one you tested.
Jan 20, 2016 at 06:38 PM
mark1958
p.1 #20 · RX1RII recall notice
Mine is in the range too. I am not sure if you have to send in all the accessories or not. The lady who took my information said yes but I would get instructions on that and all I got was the label etc. So what do you need to send in--- battery, strap, instruction manuals ?
Jan 20, 2016 at 11:08 PM
       2       3       …       7       8       end
       2       3       …       7       8       end
