       2       3       end
Archive 2015 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
LightShow
p.1 #1 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
http://photorumors.com/2015/06/23/venus-optics-announces-the-laowa-15mm-f4-the-worlds-widest-11-macro-lens/
110 degrees of view angle
1:1 macro ability with infinity focus
+/- 6mm Shift ability
12 elements in 9 groups with 3 pieces of High Refractive elements and 1 piece of Extra-low dispersion lens
Multi-layer low-reflective coatings to avoid unnecessary flare
Carefully control on the sharpness both in the center and the edge.
Limited barrel distortion
14 pieces of aperture blades form a close-to-circular aperture
Flat Front element surface for filter installation.
The enclosure of the lens is made of metal to strengthen its durability.
Canon EF, Nikon F, Sony Alpha A, Sony FE & Pentax K mounts are available.
Full Frame Sensor Supported
Price: $479
http://www.venuslens.net/
http://photorumors.com/wp-content/uploads/2015/06/Venus-Optics-Laowa-15mm-f4-Wide-Angle-1-1-Macro-Lens-550x435.jpg
http://photorumors.com/wp-content/uploads/2015/06/Venus-Optics-Laowa-15mm-f4-Wide-Angle-1-1-Macro-Lens-2.jpg
http://photorumors.com/wp-content/uploads/2015/06/Venus-Optics-Laowa-15mm-f4-Wide-Angle-1-1-Macro-Lens-design.jpg
http://photorumors.com/wp-content/uploads/2015/06/Venus-Optics-Laowa-15mm-f4-Wide-Angle-1-1-Macro-Lens-MTF-chart.jpg
THIS SOUNDS(LOOKS) LIKE FUN
http://www.venuslens.net/wp-content/uploads/2015/05/5N1A8939.jpg
http://www.venuslens.net/wp-content/uploads/2015/05/15%E5%8E%9F%E7%89%87-2.jpg
http://www.venuslens.net/wp-content/uploads/2015/05/2.jpg
http://www.venuslens.net/wp-content/uploads/2015/05/4.jpg
http://www.venuslens.net/wp-content/uploads/2015/05/6.jpg
http://www.venuslens.net/wp-content/uploads/2015/05/5.jpg
More pictures in their galleries tab... some raw's are available too.
http://www.venuslens.net/wp-content/uploads/photo-gallery/_DSC1772%20(1).jpg
Edited on Jun 23, 2015 at 01:20 PM · View previous versions
Jun 23, 2015 at 12:33 PM
U.C.
p.1 #2 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
15mm FF with 6mm shift capability and a flat front with only a 77mm filterthread....
How is this possible?
And how to reach the 1:1 magnification with 15mm FF? Your object in the lens?
Jun 23, 2015 at 12:48 PM
gwaww
p.1 #3 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Very interesting! Now that is unique!
Jun 23, 2015 at 12:50 PM
LightShow
p.1 #4 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Min. working distance 0.47 cm (1:1)
I've used my CV15III with a helicoid adapter, and I can get good magnification, I don't know about 1:1.
Edited on Jun 23, 2015 at 01:07 PM · View previous versions
Jun 23, 2015 at 12:54 PM
U.C.
p.1 #5 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
0.47cm.... that's really close.
Your last picture is maybe 1:3 (FoV of about 10x7cm).
BTW: the samples of the venus are far from 1:1
Jun 23, 2015 at 12:58 PM
LightShow
p.1 #6 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Somewhere between 1:2 & 1:3, as the height of the flower was close to the height of the sensor.
SoulNibbler
p.1 #7 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Where do we pre order? Also are there some ringflash or secondary lighting allowances made?
Jun 23, 2015 at 01:21 PM
Aaron D
p.1 #8 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Interesting. If its price is comparable to their 2:1 60/2.8, I might have to save up for this. Sadly, news of this looks like it crashed their server.
Jun 23, 2015 at 02:12 PM
LightShow
p.1 #9 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
oops!
Jun 23, 2015 at 02:16 PM
trogdon
p.1 #10 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Interested in just the shift and wide angle, will have to keep an eye on this. Sounds a bit ridiculous
Jun 23, 2015 at 02:43 PM
Dpedraza
p.1 #11 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
$479 per the article
Jun 23, 2015 at 03:15 PM
Jman13
p.1 #12 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Was super interested until I saw the shift only works for APS-C and smaller sensors. It's a FF image circle, but not larger than FF. If it had been just a FF shift 15mm lens, is have bought it in an instant. Still, a cool lens.
Jun 23, 2015 at 03:21 PM
harvey steeves
p.1 #13 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
so, shift it and crop as little as you can get away with.. You expect a FF shift/macro for $500?
Jun 23, 2015 at 04:05 PM
mountain_drew
p.1 #14 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
It says that the shift works only in APS-C but someone took pictures on the 5D without too much issues in the corner. I'm looking forward to seeing full resolution images though.
See here :
http://willchaophotography.com/lw-15mm-f4-0-macro-11-review/
http://willchaophotography.com/wp-content/uploads/2015/06/before-after.jpg
Jun 23, 2015 at 04:29 PM
mountain_drew
p.1 #15 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Another image from this album on flickr : https://www.flickr.com/photos/nickadel/sets/72157654695902976
Perspective correction with lens shift - DSC_2679_compare by Nicky Bay, on Flickr
With an image that doesn't look so great...
Venus 15mm Macro Test : Fungi - DSC_3634 by Nicky Bay, on Flickr
Jun 23, 2015 at 04:35 PM
Jman13
p.1 #16 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Do I expect it? No, of course not. However, when I first read the specs it was an insta-buy. Now, it's a maybe buy. On a 15mm prime for my A7 II if be inclined to go smaller, like the CV 15 III, but if reviews show this as having some shift capability and if I can use the macro ability in certain areas I may still get one.
Jun 23, 2015 at 04:36 PM
Aaron D
p.1 #17 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
Thanks...I didn't read whole article.
Jun 23, 2015 at 04:41 PM
LightShow
p.1 #18 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
A video of it in action...
which i found here: http://www.sonyalpharumors.com/venus-announces-the-worlds-widest-11-macro-lens-15mm-f4-0/
Jun 24, 2015 at 11:08 PM
phuang3
p.1 #19 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
The chinese spec says the MFD is 122mm and the minimum working distance (your subject to 1st element) is 4.7mm. The shift feature is designed for APSC sensor. On a FF sensor there will be severe vignette. IMHO, the best part of this lens is the deep DoF at close up which you won't get with longer macro lenses.
Jun 25, 2015 at 12:58 AM
justruss
p.1 #20 · Venus Optics Laowa 15/4 1:1 macro, did I mention it has Shift too?
It's a 15mm FF lens:
1. Put on FF camera.
2. Shift as much as you want.
3. Crop.
4.
5. Profit.
Seriously: It'll still be pretty damn wide after you reduce vignetting and crop post-shift. I wouldn't worry about it so much.
Jun 25, 2015 at 02:34 AM
       2       3       end
       2       3       end
