Archive 2004 · Zenitar 16mm fisheye
BrianP
p.1 #1 · Zenitar 16mm fisheye
Has anyone used the Zenitar 16mm Fisheye lens on a full frame or 1.3 crop camera (preferably the 1D Mark II)? I have read a couple of things that have made me wonder how far the rear element goes back, and I didn't know if it might go back too far for these cameras?
Also, if you have any pictures preferably with a 1.3 crop camera (but any would be great), could you post an example or two?
Oct 02, 2004 at 06:30 PM
SYN ACK
p.1 #2 · Zenitar 16mm fisheye
http://www.xcrusive.ismightier.com/fisheye/
1.6x (dig rebel)
taken straight from cam and resized ... haven't had a chance to go out and raelly shoot with it, took most of these the day i got it.
not bad at all for the price!!!
Oct 02, 2004 at 06:51 PM
SYN ACK
p.1 #3 · Zenitar 16mm fisheye
all at f/2.8 too
Tommy Lee
p.1 #4 · Zenitar 16mm fisheye
Syn Ack:
You have a good copy. My copy is not like this at f2.8. It doesn't look sharp until f11 and it is best at f16. However, I am happy with it as it is a very good f16 fisheye for ~$130.
Brian:
I have an EOS mount version. It works with my film body EOS 10S as well as digital rebel. I don't have a 1D-MKII. The rear filter go as far as ~1.1mm beyond the mount. Note: More if the rear filter is loose.
Oct 02, 2004 at 08:12 PM
BrianP
p.1 #5 · Zenitar 16mm fisheye
Thank you Syn Ack and Tommy.
Syn Ack: Your copy does look very good at f/2.8 with the reduced resolution photos. Do you have any larger ones that you wouldn't mind showing?
Tommy: Thanks for the estimate on how far the rear filter goes beyond the mount, and the note on the 10S.
I would still like to hear from anyone that might use this lens with a 1 series digital camera as well. I am not sure how much clearance I have. I feel better, but still not comfortable. I have heard some people reference that if you loosen up the rear filter that it might actually help the image? I am not sure about this, but obviously this would make the situation even tighter.
I would also like to see more photos if people wouldn't mind sharing them!
Oct 02, 2004 at 08:34 PM
khiromu
p.1 #6 · Zenitar 16mm fisheye
I have been using this lens with my EOS 3 without any problem. Mine is M42 version. I also have ELAN II but it only work when the aparture is wide open. I don't know why, but I don't care since I mainly use EOS 3 (which I am selling now to move to digital)..
Oct 02, 2004 at 09:29 PM
nutek
p.1 #7 · Zenitar 16mm fisheye
My sample galleries with the Zenitar::
Reportage shots:
http://www.galant-ho.com/spring04/natrat/index.htm
http://www.galant-ho.com/summer04/tartan-select/crw_6159-2.htm
Landscape:
http://www.galant-ho.com/spring04/zion/crw_6005.htm
http://www.galant-ho.com/spring04/bryce_canyon/crw_5961.htm
I had to disassemble mine (i.e. take out the rubber focussing ring and the focus mechanism) to tweak the focus a little as it was not sharp at f/8 and below. I also mentioned about the rear-filter trick about a month ago in a previous post, but YMMV as if you're using a 1.3x or FF camera.
Oct 03, 2004 at 11:59 AM
Tommy Lee
p.1 #8 · Zenitar 16mm fisheye
Wenyao
Could you discribe the process on how you tweak the lens' focus. My copy is not sharp at f8 and below as well.
Thanks
Oct 03, 2004 at 01:20 PM
BrianP
p.1 #9 · Zenitar 16mm fisheye
Thank you Hiromu and Wenyao.
Wenyao: You have some nice pictures. What does YMMV mean though?
Also, I am still curious if any one has tried it on one of the 1 Series digital cameras.
Oct 03, 2004 at 02:29 PM
nutek
p.1 #10 · Zenitar 16mm fisheye
Here's the reply I got from Mike Fourman of kievcameras some time ago: (the usual disclaimers apply: if you break your lens, that's your business. I almost damaged mine while adjusting the focus as described below, so it's your choice to take the risk.. Nonetheless, mine works nicely for f8 and above now, with f16 being the sweet spot for sharpest focus...)
DeaWenyao
we have to adjust it is Very simple
Take the rubber bend off the lens( focusing)
finf 3 screws under
Put the lens on infinity
unscrew them till the focusing ring fill loose
turn the ring till 1.2 will be across ofrom the red focusing dot
screw them back
Put rubber ring back
Should help
Sincerely
Mike
----- Original Message -----
To: "Mikhail Fourman Kievcamera"
Sent: Tuesday, February 17, 2004 1:45 AM
Subject: Re: Fisheye Lens purchase
> Hi Mike,
> Thanks! I received the lens today.
> There's some things I would like to clarify though:
> I can't seem to get sharp pictures when I set the lens to
> infinity focus at f/11 and below (f/8, f/5.6, etc). The
> subject distance was more than 200 meters away, and even
> when I bracketted the focus at different points near
> infinity (at at infinity itself), the pictures are slightly
> out of focus.
> Stopping down to f/22 does produces slightly sharper
> pictures at infinity focus. Is this normal behaviour for
> the lens, or do I have a bad copy?
> Best regards,
> Wenyao
As for the rear-filter trick:
https://www.fredmiranda.com/forum/topic2/130505/0#1054345
hope this helps!
YMMV = your mileage might vary.
Probably no one wants to use a el-cheapo Zenitar on a 1-series body The Sigma 15EX or the Canon 15mm fish would be more 'professional' candidates on a 1-series body.
Oct 03, 2004 at 02:42 PM
Tommy Lee
p.1 #11 · Zenitar 16mm fisheye
Wenyao
Thanks!
Oct 03, 2004 at 06:00 PM
Guido S
p.1 #12 · Zenitar 16mm fisheye
I used the Zenitar on a 1D without any clearance problems.
Grtz,
Guido
Oct 04, 2004 at 05:15 AM
BrianP
p.1 #13 · Zenitar 16mm fisheye
Thank you Guido. This makes me feel better. Has anyone tried it on a 1D Mark II or 1Ds?
Oct 04, 2004 at 08:34 AM
