Just passing along some info on these high power portable lighting systems.
The manufacturer calls them High Power External Portable Flash Set Speedlite Kits. They are similar to the Quantum system, but much less cost.
The same unit is private labeled by several different companies. Bolt is B&H, Flashpoint... is Adorama, Cheetahstand is a dealer in TX (but they always seem to be backordered).
Anyway, to the point. Adorama has a killer price right now. There are 2 versions, 180 w/s, and 360 w/s. Adorama is selling the 360 version, with the 4500mAh battery pack, the Commander Transceiver Set, and the Umbrella Reflector kit for $399.95.
Even if you think you don't need the transceivers because you are going to sync some other way, that set allows you to control the flash output remotely from a handheld controller, and you can still sync with a PW, Yongnuo, pc cable or whatever, if you like.
I think this deal is temporary, although they keep extending it. Check it out if you are in the market. I actually bought mine from B&H, and they price matched it.
The Godox AD360 was the best value solution for small portable power until the Rovelight came along. While the Rovelight is a little bigger, once you pack a speedlight bracket and external battery pack the two are closer than you'd think.
True but I'm reading a lot about the quirkiness of the Rovelight trigger how you'd constantly have to reset the remote. That's what kept me from the Rovelight. I got myself the Adorama Streaklight promotion and couldn't be happier.
That is a good deal. Trigger on Streaklight is nicer because it shows settings and doesn't go to sleep during periods of inactivity. There are also cheap replacement triggers available for spares. Both can't power more than one light at different powers which is a huge miss.
this deal is still on, mine just got here, wow! this flash is a lot bigger and heavier than I thought! I haven't had a chance to use it yet as the battery pack is charging right now, but I have a feeling this is very powerful and look forward to seeing what it can do. I will certainly return to let you all know my thoughts.
first impressions on this flash.... I quickly realized this is more like a strobe than like a speedlight. I have only done a few test shots in the house today and it definitely has some power to it. I will use it tomorrow for some red carpet photos at an event to give it a good test and then will try to do some outdoor testing soon as that is what I was thinking I would use it for mainly.
sherijohnson wrote:
still have to get a chance to shoot with the light, my event last night didn't have as many set ups as I originally thought.... so hope to test soon.
trying to figure out what might be the best soft box type modifier for these lights that is super easy to set up
These are actually a favorite for on location work, easy up and easy break down very light weight!!
right after I posted this, I realized there is a "mini" softbox in the accessory link for the products on adorama's website but it is only like 16 inches wide, not sure if that is big enough to get good results, I typically use modifiers that are over 3 ft across.
I still think I might be leaning towards a "universal" softbox that can be used with any of my lighting systems to maximize my usage of it, that is the downside of owning more than one lighting system.
With this bracket a speed light and the streaklight will fit into it, and it will accommodate any Bowens modifier like the one I listed previously, so you are somewhat universal!!
I actually found a few of the godox softboxes in the amazon link that were universal from what I could tell and I went ahead and ordered them because the price was agreeable however the delivery is sort of slow, but for the low price, I will try to be patient. Hoping they are decent Thank you!
Just a bump up to this one.
I was lucky scored a set of the Godox Wistro 360's from a member here. He was kind enough to include the accessory kit. So yes the small soft box tended to focus more than a larger modifier, but the ease of how it can be deployed keeps it in my bag.
Yes these are more like strobes than flashes in my personal un-professional opinion. They will turn night into day if you run them at full and if you use the y connector the recycle time is crazy fast.
The only downside is I purchased these right during the announcement of the version 2 that has the built in 2.4 receiver.
I still haven't had a chance to do a proper test shoot with my light, but hopefully sometime next week. But I did want to say the link is still good and the special is still on, even if you didn't like it, you could easily sell it for more than you paid for it at this price. I went ahead and also ordered the clamp and the light cover.
the problem with this system for studio lighting is that the remotes do not allow you to turn on and off individual lights for metering. I'm hoping the Godox 360 II fixes this issue.
and the rovelights are much heavier. Not good for putting on a boom stand above a model's head IMO. They weigh several lbs more than the Godox and I'm not sure if the advertised weight (5.5lbs) includes the battery...
It is possible to turn individual lights on and off. Its a bit of a clug but it works.
Just select the light you want to turn off and run its power down. When you get to 1:128 the next step is off.
