fredmiranda.com Login
This topic is in the 2014 archive. You can read it and like its posts here. It is read only.
Archive 2014Corsican Mantis at Prayer
e6filmuser
p.1 #1Corsican Mantis at Prayer
These are shots of the mantis whose portraits I posted earlier. I wanted to show the whole insect in some kind of habitat context. I think that I must have changed my viewing position for the second one slightly to get the hotel wall as a background.
Ideally, a different angle for the first one would have made the leaf less prominent but I can accept the leaf as a price for the mouthparts being extended.
EM-1 Kiron 105mm, probably f11 or f16, TTL flash, 1/200 ISO 200.
Harold
© Harold Gough 2014
© Harold Gough 2014
Dec 27, 2014 at 03:04 AM
Dalantech
Details
p.1 #2Corsican Mantis at Prayer
I really like the compositions
What were you using to diffuse your flash, and how far away was it from the subject? The specular highlights are "hot".
Dec 27, 2014 at 03:15 AM
e6filmuser
Details
p.1 #3Corsican Mantis at Prayer
Thanks.
There was a kit diffuser on the flash which was level with the camera body. It was a bit of a rush job. My camera had been in the car and I was about to pack the remainder of our luggage for our long drive to the airport, so there was no time for experimentation. A few minutes later the mantis could not be found.
Sorry to be a bit vague but the lack of a PC and Photoshop has delayed processing by nearly three months and details, originally clear in my mind, are now based on probability. My standard flash setup was two off-camera, one (diffused) on an L-bracket to the left, pointed down at an angle, and one on the lens barrel aimed from the right. I doubt that the latter was used, being fiddly and time-consuming to set up, although the value of the shots may have persuaded me. I would hope that I used the L-bracket and not the hot shoe but cannot be sure.
Harold
Dec 27, 2014 at 03:35 AM
surfnron
Details
p.1 #4Corsican Mantis at Prayer
These are nice Howard. Have you considered darkening the underside of the leaves in post? Bright undersides on leaves does not look natural to me ~ Ron
Dec 27, 2014 at 06:51 AM
e6filmuser
Details
p.1 #5Corsican Mantis at Prayer
Thanks, Ron.
Unfortunately, I have no access to Photoshop for some time yet.
Harold
Edited on Dec 30, 2014 at 12:55 AM · View previous versions
Dec 27, 2014 at 06:59 AM
Details
p.1 #6Corsican Mantis at Prayer
The second stands out from the cleaner of the two backgrounds and is a beauty Harold
Dec 27, 2014 at 09:03 AM
e6filmuser
Details
p.1 #7Corsican Mantis at Prayer
I have seen a few mantis before, but this is the first time I had an all-around view.
I knew they were around because there were a couple on the glass wall of the restaurant patio area the previous evening.
Here is one with the wings showing, the dust, especially bottom left, being the glass of the outer edge wall. I had to prod it a bit to get the wings partly extended.
Harold
© Harold Gough 2014
Dec 28, 2014 at 01:51 AM
e6filmuser
Details
p.1 #8Corsican Mantis at Prayer
Going in for a closer crop solves that problem.
Harold
© Harold Gough 2014
Dec 30, 2014 at 12:57 AM
FM ForumsMacro & Still LifeJoin Upload & Sell
