       2       3       4       5       end
Archive 2011 · Zeiss 25mm f/2.0 has amazing resolution
RCicala
p.1 #1 · Zeiss 25mm f/2.0 has amazing resolution
I know others have reviewed it, but we got our first copies in today. I just finished testing them and the 25 f/2.0 does something I never thought I'd ever see: it had higher resolution than the fabled Zeiss 21mm f/2.8. (They were actually dead even when the 25mm was shot at 2.0, the 25 was easily better at f/2.8).
I'm at work so no pretty pictures, only testing photos: http://www.pbase.com/rcicala/zf22mmf20
Dec 29, 2011 at 01:04 PM
plasticmotif
p.1 #2 · Zeiss 25mm f/2.0 has amazing resolution
Can't wait to see more examples!
Dec 29, 2011 at 01:19 PM
FlyPenFly
p.1 #3 · Zeiss 25mm f/2.0 has amazing resolution
That would be amazing for the size and f stop.
Still, 4mm more on the wide end is a dramatic difference in field of view.
Dec 29, 2011 at 01:25 PM
plasticmotif
p.1 #4 · Zeiss 25mm f/2.0 has amazing resolution
I'm asking Denoir if he'd do one of his fancy MTF overlays. I've only compared the MTFs at f4 for the 25/2 and 5.6 on the 21.
Can't find others.
The 25/2 @2 is remarably close to the 21/2.8 @2.8 - wide open they are amazing.
It seems to be a hair worse than the 21 when it's apeture is at 4 and the 21 is at 5.6 - that's to be expected. Look at the contrast
http://i227.photobucket.com/albums/dd256/ustjwe/Distagon28_21_engl.jpg
http://img.photobucket.com/albums/v518/plasticmotif/25f2mtf.jpg
Dec 29, 2011 at 01:27 PM
johnahill
p.1 #5 · Zeiss 25mm f/2.0 has amazing resolution
I'd still like to see more shots from this lens at distance at mid apertures. I know the f2.0 probably does some magical things close-in and wide open but for 'normal' landscape/cityscape shots at f5.6 focussed to infinity this lens doesn't seem to be worth the premium over the 25/2.8 which excels at infinity.
Dec 29, 2011 at 02:10 PM
johnahill
p.1 #6 · Zeiss 25mm f/2.0 has amazing resolution
Having said that I'd dearly love the 25/2 to be as good as the 25/2.8 for infinity then I could finally get a 25 zeiss in ZE mount :-)
Dec 29, 2011 at 02:17 PM
wiseguy010
p.1 #7 · Zeiss 25mm f/2.0 has amazing resolution
I am really interested in more pictures because the reviews do not confirm these findings (certainly at infinity in the corners).
Dec 29, 2011 at 02:29 PM
Tariq Gibran
p.1 #8 · Zeiss 25mm f/2.0 has amazing resolution
Yes, it would be wonderful to see some examples at or near infinity focus with important detail in the top corners.
Dec 29, 2011 at 02:43 PM
wayne seltzer
p.1 #9 · Zeiss 25mm f/2.0 has amazing resolution
You would expect the 25/2 to be better up to 2.8 and then at f4 I would expect the 21 to pull ahead from then on.
And I assume you are talking about center resolution only, right? As we know from MTF's and user reports/pictures that the 25/2 is weak in the corners till f8 or f11.
Dec 29, 2011 at 03:32 PM
Tariq Gibran
p.1 #10 · Zeiss 25mm f/2.0 has amazing resolution
At longer distances- close to infinity focus - I believe it remains very weak in the corners even closed down...but I would love to see some examples which contradict this.
Dec 29, 2011 at 03:40 PM
wayne seltzer
p.1 #11 · Zeiss 25mm f/2.0 has amazing resolution
And is this weakness in the corners due only to field curvature and thus the plane of focus just shifts forward when you get near the corners or is it just not sharp period and field curvature is not evident?
Dec 29, 2011 at 03:50 PM
RCicala
p.1 #12 · Zeiss 25mm f/2.0 has amazing resolution
Center and overall resolution (weighted average). The absolute corners are a bit soft, but the edges not bad at all. Imatest MTF50 results (LP/IH, unsharpened raw images) for 9 copies tested today, along with 9 copies of the 21mm f/2.8 we tested as a control (since we know what values we expect with it). Left column is peak spot MTF50, right column weighted average (1.0 center 1/4; 0.75 middle 1/4; 0.5 outer 1/3). The bottom row, after the gap, is average of the column.
21@f/2.8 25mm@f2
max avg max avg
835 738 971 743
837 702 893 782
837 701 914 790
841 705 937 811
844 755 865 762
867 757 873 746
883 757 863 757
890 804 920 800
910 762 931 806
860 742 907 777
Absolute corner values ran about 400-450 for the 25mm (about the same corner numbers we see with the 21 and 35 f2), but that is at 15 feet, not infinity. I can't speak to infinity at all. But this is the first lens shorter than 85mm that has ever resolved as well as the 21mm in our tests. The 50mm f/2 is close. None of the 35mm are.
Dec 29, 2011 at 03:55 PM
wayne seltzer
p.1 #13 · Zeiss 25mm f/2.0 has amazing resolution
Thanks!
What about f4 and 5.6?
Dec 29, 2011 at 04:11 PM
RCicala
p.1 #14 · Zeiss 25mm f/2.0 has amazing resolution
Wayne, we don't go that far (we're testing for decentering and tilt, which is most apparent wide open) but I'll put them back on the machine tomorrow and get some f4 and f5.6 numbers.
Dec 29, 2011 at 04:44 PM
RCicala
p.1 #15 · Zeiss 25mm f/2.0 has amazing resolution
wayne seltzer
p.1 #16 · Zeiss 25mm f/2.0 has amazing resolution
Roger,
Oh ok, then only do f4,5.6 testing if you want to and if you have some spare time as I know you probably have better things to do.
Would be interesting what you measured for 24Lmk2 and especially my beloved 24G/1.4 which I first rented from you before buying it later. Maybe later sometime I will rent this 25/2 from you and test it out.
Dec 29, 2011 at 05:04 PM
Mescalamba
p.1 #17 · Zeiss 25mm f/2.0 has amazing resolution
This kinda raises question why ZA 24mm f2 isnt that good.. (my guess, cause its Sony).
Dec 29, 2011 at 05:09 PM
thrice
p.1 #18 · Zeiss 25mm f/2.0 has amazing resolution
^^ just like the 135/1.8, 85/1.4, 24-70/2.8 etc? Right? Troll.
Dec 29, 2011 at 06:24 PM
RCicala
p.1 #19 · Zeiss 25mm f/2.0 has amazing resolution
Wayne, I've only got f/1.4 numbers handy on the two 24mms. The Canon Mk II measured the same way as above had average values of 620 peak (range 640-575) and 540 weighted average. The Nikon was 650 (range 690-605) and 560, again at f/1.4. I'll see if I can find the f/2.8 numbers for those.
Dec 29, 2011 at 06:38 PM
rscheffler
p.1 #20 · Zeiss 25mm f/2.0 has amazing resolution
My Zeiss dealer mentioned that all of the new Zeiss are aimed at high resolution performance in anticipation of future high resolution sensors. I don't recall the exact numbers he claimed, but 100MP sticks in my mind.
Dec 29, 2011 at 07:19 PM
       2       3       4       5       end
       2       3       4       5       end
