Archive 2011 · 300mm f/4 AF w/ Kenko 1.4x?
blkcat
p.1 #1300mm f/4 AF w/ Kenko 1.4x?
Getting my 300mm f/4 in the mail next week and I'm curious if anyone has had success with this combination? I like that the Kenko permits AF to operate but naturally there's no point in autofocus if the images produced are too soft to begin with.
Edited on Aug 05, 2011 at 08:39 PM · View previous versions
Aug 05, 2011 at 08:01 PM
EB-1
Details
p.1 #2300mm f/4 AF w/ Kenko 1.4x?
There is no 300/4 AF-D. Assuming it is the 300/4 AF, I have used it with various TCs and it is fine.
Aug 05, 2011 at 08:31 PM
blkcat
Details
p.1 #3300mm f/4 AF w/ Kenko 1.4x?
You totally can't tell that I'm a Nikon newbie, can you? ;]
Is there any make or model of third-party TC that you would recommend over others?
Aug 05, 2011 at 08:41 PM
EB-1
Details
p.1 #4300mm f/4 AF w/ Kenko 1.4x?
It is a common problem that people forget there were AF lenses from 1986 until 1992 when the N90 and AF-D lenses appeared. Some AF lenses in production before 1992 were never upgraded to AF-D.
I have the Kenko and Tamron 1.4x Pro or whatever the best version is. They are too similar to say which is best, though there are some slight differences in CA depending on the prime lens. The 300/4 AF-S solved some optical and mehcanical problems, save for the crappy tripod collar.
You should check the AF function for noise. Some of the old 300s may require lubrication of the gear train.
Aug 05, 2011 at 08:49 PM
blkcat
Details
p.1 #5300mm f/4 AF w/ Kenko 1.4x?
Holy cow, that's gorgeous. Which model of Nikon TC are you using specifically? I assume you don't find the manual focus to be too much of a burden with the D7k?
Aug 05, 2011 at 09:23 PM
EB-1
Details
p.1 #6300mm f/4 AF w/ Kenko 1.4x?
The TC-14B is the correct Nikon TC for that lens. I thought you wanted AF though. In the old days the 300/4 AF was commonly used with extension tubes for semi-macro work. That lens does not focus too close so it is not ideal for range, but the results are good (reasonably flat field and coverd by typical mid-small apertures).
Aug 05, 2011 at 09:43 PM
TTLKurtis
Details
p.1 #7300mm f/4 AF w/ Kenko 1.4x?
Can't speak on the Nikon stuff, but back when I was with Canon I had this combo and it worked quite well. Pixel peep and I'm sure you'd find issues, but I found the images plenty sharp wide open with extender.
Aug 05, 2011 at 10:43 PM
Kingfishphoto
Details
p.1 #8300mm f/4 AF w/ Kenko 1.4x?
I use the Kenko 1.4X on my gear driven Nikon 300 F4 lens, and the results are fine.
Harry Palmer
Aug 08, 2011 at 07:33 AM
jefflee
Details
p.1 #9300mm f/4 AF w/ Kenko 1.4x?
I have a Nik. 1.4 and the KenkoPro 1.4 (for my 80-200 2 ring), testing both on my 300 AFS I did not see much of an optical difference, the Nikon is better built IMHO.
Aug 08, 2011 at 09:36 AM
CGrindahl
Details
p.1 #10300mm f/4 AF w/ Kenko 1.4x?
Perhaps as a person new to Nikon you may wish to do a bit of reading about lens nomenclature. Here's a good resource on the subject.
http://www.bythom.com/lensacronyms.htm
And here is information about quite a few of Nikon's different lenses, their strengths and weaknesses as seen by one well respected reviewer.
http://www.naturfotograf.com/lens_surv.html
Have fun and let the learning begin...
Aug 08, 2011 at 09:59 AM
Kingfishphoto
Details
p.1 #11300mm f/4 AF w/ Kenko 1.4x?
Hi .
Will the Nikon AF both your 80/200 and 300 ?. In other words i believe the Kenko (I have ) will AF both screw drive and those lenses with motors in the lenses - whereas the Nikon may not do both. My whole point being the Kenko, owning one, will do both, and very well. Just a clarification point, not an arument of course.
Cheers
Harry Palmer
Aug 08, 2011 at 05:38 PM
EB-1
Details
p.1 #12300mm f/4 AF w/ Kenko 1.4x?
The Kenko Pro 1.4x will work with both lenses. I have used it on 80-200/2.8s as well. It is very popular for that purpose.
Aug 08, 2011 at 05:44 PM
Kingfishphoto
Details
p.1 #13300mm f/4 AF w/ Kenko 1.4x?
EB-1.
I have both the 80-200 2.8 and the 300 F4 screw drives- and indeed the kenko 1.4 does work well on both. I also have the Kenko 2X and it works very well on the 80-200.
Cheers
Harry Palmer
Aug 09, 2011 at 05:24 PM
lou f
Details
p.1 #14300mm f/4 AF w/ Kenko 1.4x?
had the kenko, found i got a better image with a crop and resize of the image than adding the kenko 1.4 pro. so i sold it, get the latest nikon 1.4.
Aug 11, 2011 at 04:06 AM
FM ForumsNikon ForumJoin Upload & Sell
Switch to mobile view
