I have one and use it all the time with Zeiss and Meyer lenses. The problem with Exakta mount is that there is variation in depth, so for some lenses my adapter is a snug fit, and for some it's pretty loose and I need to put a metal shim under it. Another problem is that the rear flange of the mount varies in thickness, and when it's thick it touches the camera mirror box when you put the lens on. Then there may be a problem with reaching infinity, which sometimes can be solved by adjusting the lens itself.
But overall my adapter does work! I don't remember the seller's eBay name. My adapter has black color and it says "EXA-EOS" on the rear.
