MA Rules · Current entries
Archive 2009 · #57 Catching Fire
lavanut
p.1 #1 · #57 Catching Fire
I thought this might be a nice subject for "Close up"...the moment the match lights...
Comments are always welcome.
Jan 16, 2009 at 10:18 PM
CDalessandro
p.1 #2 · #57 Catching Fire
WOW! perfect timing.
Carolyn
Jan 17, 2009 at 09:16 AM
jmcaverly
p.1 #3 · #57 Catching Fire
Great shot.
Jeff
Jan 17, 2009 at 11:57 AM
lavanut
p.1 #4 · #57 Catching Fire
Carolyn
Thanks. I went through a lot of matches trying to get this. I'm glad I didn't set off my smoke alarm (which was right above me) in the process.
Jan 17, 2009 at 06:17 PM
burningcloud7
p.1 #5 · #57 Catching Fire
why is the speed of the stick not blurred, but the flame is? The speed of the stick should be moving at a higher rate of speed than the flame itself when ignited. With a flame that large on both sides, not very much flint appears to have been burnt. I tried this also with a friend and can not seem to get that photo like that. I shot at 6 frames per second.
How did you get it to appear like that? After looking at it very tight, what direction did you strike the match?
Jan 18, 2009 at 01:20 PM
hanamj
p.1 #6 · #57 Catching Fire
Nice!
I agree, please share some technique!
John
Jan 18, 2009 at 02:23 PM
lavanut
p.1 #7 · #57 Catching Fire
I think I was going left to right in this shot. I tried it both ways. The reason the stick isn't blurred is that I was also using dual flashes, firing at 6 frames/sec to sync with the camera. The flame looks blurred just due to the nature of fire. The shutter speed was 1/125.
After a lot of trial and error, this is what ultimately worked best for me. I pre-focused on the spot on the match box where I wanted to get the shot. Then I moved the match towards that spot as slow as I could to get it to strike . I waited for it to start to light and slowed down the speed of the stick in the area where I'd pre-focused, hesitating for a fraction of a second. Only then did I start to fire off some shots, usually only 2-3 at a time. With macro, you don't have a lot of room for error on focusing, so knowing the spot on the box is very important and hitting it even more so.
I found out rather quickly that even at 6 frames per second, actually catching the match lighting at a "normal" striking speed requires a heck of amount of luck. I had way more missed shots than successes, so I changed my approach.
Painting the box black and clamping it in a vise also helps. And of course you have to be careful not to light the box when you slow the match stick down, too.
Jan 18, 2009 at 02:32 PM
Kingdon Hawes
p.1 #8 · #57 Catching Fire
I think we have this months winner. Great shot.
Jan 20, 2009 at 11:45 PM
lavanut
p.1 #9 · #57 Catching Fire
Thanks for the compliment, but there are a lot of good shots here. I'm just enjoying the practice and seeing what other folks do. It's a great way to learn and expand my skills!
Jan 21, 2009 at 09:09 PM
Bill Sutherland
p.1 #10 · #57 Catching Fire
Striking shot
Jan 23, 2009 at 07:20 PM
lavanut
p.1 #11 · #57 Catching Fire
Bill Sutherland wrote:
Striking shot
Thanks, Bill. I hope it matches up well with the competition!
Jan 27, 2009 at 10:36 PM
