Archive 2007 · What is the right way?
Yakim Peled
p.1 #1 · What is the right way?
Dear FM'ers,
I wonder what is the right way to compare pictures from two cameras, one with 4MP and the other with 10MP. Should I compare simple 100% crops from each and thus compare pixel to pixel or should I blow up the 4MP picture to 250% and thus compare equal picture sizes?
Happy shooting,
Yakim.
Dec 02, 2007 at 09:03 AM
tonno1970
p.1 #2 · What is the right way?
Are you looking to substitute you 1D with the 40D?
I really do not know how to help you, I have the 1D and 400D but in the end I always prefer what the 1D takes also at High ISO like 400 or 800....
ciao GP
Dec 02, 2007 at 09:06 AM
Yakim Peled
p.1 #3 · What is the right way?
No. I have both. It's just that after I got the 40D I am comparing 100% crops and the difference is not that big. I guess I should go the other way but I still want to know what is the conventional wisdom.
Happy shooting,
Yakim.
Dec 02, 2007 at 09:09 AM
dfresh
p.1 #4 · What is the right way?
Pixel to pixel would seem the most fair and accurate way to me.
Dec 02, 2007 at 09:10 AM
Pixel Perfect
p.1 #5 · What is the right way?
Uprezzing the 1D shot would not be fair to it IMO. 100% crops would be fairer. Don't forget the 1D had superb per-pixel sharpness and punched well above it's weight. At the time it was much sharper than the 6MP 10D and really unless you were after larger than A4 prints was unbeatable. Many still lament it's abilities. I'd die to see it's 1/500s flash sync and 1/16000 top shutter come back. Imagine the IQ from it now combined with Digic III and the improved microlens array, 14 bit capture. Make an awesome B&W camera.
Dec 02, 2007 at 09:16 AM
Steve Spencer
p.1 #6 · What is the right way?
Hi Yakim,
It seems to me that the pixel to pixel comparison makes sense, but I would think that what is most important is the comparison at the image size you want to print to. How does an 8 X 10 from each camera look? How about an 11 X 14, etc.? I think what you will see is that pixel to pixel the 4mp looks better but as the print size increases the 10mp will start to look better and will eventually be clearly superior. Knowing what size the crossover in quality occurs would seem like very useful information. I hope this helps.
Dec 02, 2007 at 09:17 AM
Yakim Peled
p.1 #7 · What is the right way?
I am not concerned with what is fair. I am concerned with what is the conventional wisdom, and why.
Happy shooting,
Yakim.
Dec 02, 2007 at 09:19 AM
Richard Nye
p.1 #8 · What is the right way?
Why not do prints of each and compare the prints?
Dec 02, 2007 at 10:33 AM
Xavier Rival
p.1 #9 · What is the right way?
I would tend to do the comparison after getting the pictures to the form I want to use them in. That may be print or web-resized pictures or other. Not sure whether it is the conventional wisdom, but it would be mine (if I have any ).
Dec 02, 2007 at 10:47 AM
DavidP
p.1 #10 · What is the right way?
Exactly.
And the best way to duplicate that digitally is to make both imges the same size (in terms of number of pixels).
For viewing on the PC monitor, I would make the dpi about 80 - 100. Use whatever size in inches you'd normally print at.
Dec 02, 2007 at 10:52 AM
danmitchell
p.1 #11 · What is the right way?
There are so many variables that it is almost impossible to come up with a truly objective way of doing this.
My thinking is that the best - and certainly most useful - test is to go through your normal workflow with both cameras, trying to create the best image possible in the sort of format that you might typically use: small web image, large prints, etc.
See what the result is in these real world cases and make an educated subjective evaluation. That's what matters.
Dec 02, 2007 at 11:23 AM
Yakim Peled
p.1 #12 · What is the right way?
Thanks for your suggestions. I take it that there is no conventional wisdom…..
Happy shooting,
Yakim.
Dec 03, 2007 at 05:06 AM
Tentacle
p.1 #13 · What is the right way?
There is, but it depends on the kind of end result you use your camera for.
If you shoot for web publication you'll have different constraints than if you print, say, 20"x30" size. The same applies to doing low light stuff (read: high ISO) or not, for instance.
Dec 03, 2007 at 05:42 AM
Yakim Peled
p.1 #14 · What is the right way?
I shoot a lot of high ISO but when viewed at 100% there is not much difference. I'll upload some pictures tomorrow.
Happy shooting,
Yakim.
Dec 03, 2007 at 06:06 AM
Jman13
p.1 #15 · What is the right way?
Exactly. Pixel to pixel doesn't matter much...it's how you display your images. If you only display them for the web, look at web shots. If you make prints...make prints!
It's one reason I never understand when someone sees an ISO 800 shots from the 30D or 40D and says "wow, that's a lot of noise!" If they'd just print it, they'd see that it's hardly any noise. You'll get an impression of how those to cameras output for display, and that will help!
Dec 03, 2007 at 06:49 AM
Yakim Peled
p.1 #16 · What is the right way?
I must confess. I have very few pictures which I feel that are worth printing and up to now I have not….
Happy shooting,
Yakim.
Dec 03, 2007 at 06:56 AM
Lord Fluff
p.1 #17 · What is the right way?
I don't think viewing at 100% will help anyway since you are comparing different amounts of the sensor. My newly acquired 1DsII looks good at 100%, but it's when you realise that you're looking at an enormously tight crop that you realise there is a difference.
As others have said, the only fair test is to do a test shot on each camera, print em up and see what you think.
Dec 03, 2007 at 07:45 AM
Yakim Peled
p.1 #18 · What is the right way?
For all interesed.....
https://www.fredmiranda.com/forum/topic/594170
Happy shooting,
Yakim.
Dec 04, 2007 at 05:55 AM
mh2000
p.1 #19 · What is the right way?
whatever your final intended output is... print?
Dec 04, 2007 at 09:54 AM
Yakim Peled
p.1 #20 · What is the right way?
No. I rarely print. It's just an impression that I have. When I got the 40D I expected night and day difference in that regard. After all, 6 years is a small eternity in computer lifespan. However, I was disappointed. I keep shooting with it mainly because of the 1D's poor battery consumption.
Happy shooting,
Yakim.
Dec 04, 2007 at 10:10 AM
