WA Rules · Current entries
Archive 2007 · #250 an ant's perspective
Reuben Krabbe
p.1 #1 · #250 an ant's perspective
towering tulip
May 20, 2007 at 12:59 PM
zcaley
p.1 #2 · #250 an ant's perspective
I love this! Beautiful and intriguing!
May 20, 2007 at 01:19 PM
Photon
p.1 #3 · #250 an ant's perspective
Beautifully done! I imagine you've used some supplemental light in the foreground. However it was done, the result is popping color and texture in the tulip, with a somewhat muted background. Great combination. Excellent composition. I especially like the way the side lit leaves and stem stand out against dark portions of background.
May 20, 2007 at 02:46 PM
judi
p.1 #4 · #250 an ant's perspective
Tulips are my favorite flower,,,,,so I gotta love this one !! Bet the ants do too :-)
May 20, 2007 at 04:13 PM
ironabike
p.1 #5 · #250 an ant's perspective
Beautiful image. I was thinking of how to beautifully capture an "ant's perspective"--and you did it masterfully. Nice work
Jane
May 21, 2007 at 07:37 AM
teglis
p.1 #6 · #250 an ant's perspective
Very dramatic. You've nailed the lighting.
May 21, 2007 at 10:38 AM
James Markus
p.1 #7 · #250 an ant's perspective
Well done perspective! I like it!
May 22, 2007 at 01:21 PM
hhski
p.1 #8 · #250 an ant's perspective
It towers like the pine. The great lighting does hurt either.
May 22, 2007 at 05:45 PM
Philly Rains
p.1 #9 · #250 an ant's perspective
Stunning! Had this been mine, I probably would have cropped it to the end of the leaf on the left, so it's interesting to see the whole image.
Beautifully lit, and the colors are splendid! A wonderful capture, Rueben!
May 22, 2007 at 06:00 PM
Tom Basore
p.1 #10 · #250 an ant's perspective
This is a very nice shot Reuben, Well done.
May 23, 2007 at 04:05 PM
Medowlark
p.1 #11 · #250 an ant's perspective
I really like this. The lighting is what really makes it and I hope you will descirbe your approach.
al
May 23, 2007 at 06:56 PM
Reuben Krabbe
p.1 #12 · #250 an ant's perspective
so you want to know how i did it? okie dokie
i'm running my nikon d80 with a 18-200mm, popup flash, single strength output flash, with attached eye slave
so basically i found an angle which i liked, then i would place the other flash in a place which would light the scene in a dramatic way, and still be triggered by the popup
then using the manual override on on board flash output i would use that to balance the lighting between the two light sources
minor adjustment to the distance between the external flash, to adjust it's intensity (longer distance=less intense flash). then some photoshop work to darken shadows, white ballance
and poof you have this shot, and a couple other which didn't work, but they helped you get to this shot
May 25, 2007 at 01:18 AM
