Archive 2005 · D70 - What's causing this?
Lowkey
p.1 #1 · D70 - What's causing this?
Hi all
I am not sure that this is the right forum to post this, so forgive me if I screwed up!
Sometimes pictures taken with my D70 exhibit a weird color shift/ change. It seems like it happens only when the color is really vivid - like the camera can't handle the saturated color.
Here are two examples - the one is of two traffic lights at a dirt track race, and the other is of a player in a rugby match - full sunlight. It has alos happened before with a bright yellow daisy, where the inside part of the flower had the same green blocks. Any Ideas??
These things are spoiling some of my few good shots!
http://www.pixspot.com/albums/userpics/Lights.jpg
http://www.pixspot.com/albums/userpics/normal_Kick.jpg
Jul 30, 2005 at 11:27 AM
Glenn01
p.1 #2 · D70 - What's causing this?
Yeow! That's not right (no kidding ). Do you have any boost settings cranked (such as saturation or colour - not sure what all options are on the D70)? Other than that, I'd say it needs a recalibrated, or new sensor. Maybe someone else with a D70 might have a better answer though, so hang in for a bit before you run off to the repair centre.
Glenn
Jul 30, 2005 at 11:30 AM
Bill De
p.1 #3 · D70 - What's causing this?
I agree with Glenn. Unless there is a setting really off... although I doubt it... it looks like it needs serviced.
Jul 30, 2005 at 11:35 AM
mrimpossible
p.1 #4 · D70 - What's causing this?
Lowkey wrote:
Hi all
Have you downloaded a custom curve into it? - or the previous owner (or is it new?)...
It could have a wacky custom curve in it that's making it over-saturate - I'm not near a manual right now but that's my guess. I can't remember if there's a "reset to default" option somewhere.
Jul 30, 2005 at 12:27 PM
Lowkey
p.1 #5 · D70 - What's causing this?
I have checked the settings, nothing funny or out of the ordinary.
The funny thing is that it only happens at random and not very often. It also SEEMS that it happens when I take a lot of pictures.
Normally I delete the pics after I have loaded them onto the PC, so the CF card is always clean. When I take a lot of pictures, maybe the camera is writing to a bad sector on the card?
I wonder if it could be the CF card? Anyway, I am going to try a reset to factory settings on the camera, format the card and take the battery out of the camera for 12 Hours
Jul 30, 2005 at 12:44 PM
brandofamily
p.1 #6 · D70 - What's causing this?
What mode are you shooting in? Any custom settings? Saturation? Hue? White balance?
Jul 30, 2005 at 12:48 PM
Glenn01
p.1 #7 · D70 - What's causing this?
OK, I just assumed you were getting this on any card. The very first thing I'd do is swap in another card. That's the easiest and cheapest check.
Glenn
Jul 30, 2005 at 01:01 PM
Lowkey
p.1 #8 · D70 - What's causing this?
Thanks, that's a good idea - will try it and report back. Thanks for the suggestions
Jul 30, 2005 at 01:19 PM
deapee
p.1 #9 · D70 - What's causing this?
oh wow...that's scary. I'm interested in hearing what the cause is -- if it were me, I'd be sending my camera back to nikon for repair.
Jul 30, 2005 at 01:34 PM
jmcfadden
p.1 #10 · D70 - What's causing this?
if I had to guess 2 things come to mind . The first is Sensor Blooming and the second is a DSP processing issue. Is this issue present in a Raw file or only jpegs? If it isn't in the raw then a likely issue is the DSP in the camera , if it is in the Raw it also could be the Raw Compression which is always on with the D70. My guess is this has to go back to Nikon
J
Jul 30, 2005 at 02:16 PM
deapee
p.1 #11 · D70 - What's causing this?
Someone else was complaining of this...they were shooting in RAW...they rebooted their computer, and the photos opened fine when they tried again.
Jul 30, 2005 at 04:55 PM
Jack OBrien
p.1 #12 · D70 - What's causing this?
If you're shooting raw, which converter are you using? I've had Bibble do this same thing. It seems like a raw conversion issue to me, deapee's idea of rebooting sounds like a good idea.
Jack
Jul 30, 2005 at 09:16 PM
apbianco
p.1 #13 · D70 - What's causing this?
If you're shooting RAW and have `hightlight clipping' turn on, you can see things like that.
If this is straight out of camera JPEG, it has to be some serious problem.
I doubt it. What you see here follows a source image pattern.
Jul 31, 2005 at 01:53 AM
