Sony Exposure/Overexposure
Blakehfreeman
p.1 #1 · Sony Exposure/Overexposure
Recently decided to buy a pretty significant Sony set up to try it again after trying the Sony cameras about a decade ago when the AF was atrocious. Needless to say Sony has fixed that issue and then some, but I've noticed a fair amount of my shots overexposing. Mind you, easy enough to compensate via dialing down exposure/shooitng full manual.
Is this a system known quirk/anything I should look out for? This is across lenses, across setting, ie aperture priority/shutter etc.
Thanks!
Sony A7r6
•Sony 35mm 1.4 GM
•Sony 50mm 1.2 GM
•Sony 85mm 1.4 GM ii
•Sony 100mm 2.8 GM Macro
•Sony 28-70mm 2.0 GM
•Sony 50-150mm F2 GM
•SIGMA 200mm F2
•Sony 300mm F2.8 GM
Oct 12, 2026 at 12:13 PM
RustyRus
p.1 #2 · Sony Exposure/Overexposure
What metering mode are you using? Seems like the most logical place to start if overexposing-
Edited on Oct 12, 2026 at 12:20 PM · View previous versions
Oct 12, 2026 at 12:16 PM
Blakehfreeman
p.1 #3 · Sony Exposure/Overexposure
I agree, don't know Sony terminology yet but have tried both of the metering modes that are averaging the entire scene. This was the first thing I checked when I noticed the exposure.
RustyRus wrote:
What metering mode are you using? Seems like this logical place to start if overexposing-
Oct 12, 2026 at 12:19 PM
Alan Parker
p.1 #4 · Sony Exposure/Overexposure
My older A7R4 doesn't always get it right either, but I think with the tech in the A7R6 this should be mostly corrected? Maybe there's a setting off on your end?
Oct 12, 2026 at 12:28 PM
Blakehfreeman
p.1 #5 · Sony Exposure/Overexposure
Camera is new so I’d assume not but reset everything to default and still occuring.
Oct 12, 2026 at 01:01 PM
Jack Flesher
p.1 #6 · Sony Exposure/Overexposure
Looks like you have an outstanding kit. All of those lenses hold up to the 67mp sensor.
I use multi metering and it's usually spot on unless there's a bright light source or large block of shadows in the composition. I do have my finder set to emulate exposure and color, so I can "get a hint" if a capture might need a + or - EV. I normally shoot in A mode and have my rear command wheel set to EV.
All that said, my guess is your over exposure issue is being caused by the DR optimizer, under Exposure> #6> 1st menu item -- TURN THAT OFF and I suspect you'll see immediate improvement.
Oct 12, 2026 at 01:19 PM
bwcolor
p.1 #7 · Sony Exposure/Overexposure
I just completed a two week vacation and first use of this same camera. I used the multi mode metering and aperture priority with the histogram displayed in the view Finder and then would use exposure compensation to make sure that I have the exposure, correct. all of the images were nicely exposed.
The post above probably identifies your main problem.
Oct 12, 2026 at 01:36 PM
Blakehfreeman
p.1 #8 · Sony Exposure/Overexposure
Thank you both!
Oct 12, 2026 at 01:49 PM
johnahill
p.1 #9 · Sony Exposure/Overexposure
you have a lot of fast glass, are you shooing f1.4 with high iso?
Could be reaching the max shutter speed, which would flash in the display if so
Oct 12, 2026 at 02:36 PM
EB-1
p.1 #10 · Sony Exposure/Overexposure
I have not noticed any particular overexposure with my a7rVI. Of course in contrasty light you sometimes need to dial it back as with most all cameras.
The a7rVI has adjustable zebra thresholds so you can tweak those to see what is going to overexpose. What are they set to and is it overexposing before they are displaying?
Oct 12, 2026 at 03:33 PM
