p.1 #1 · Sold: Mind Shift Gear Filter Hive Carrying Case
Mind Shift Gear Filter Hive Case
Price: $20.00 Payment method: PayPal Item condition: 9+ Shows little or no signs of wear Shipping instructions: Buyer pays exact ground shipping through Pirate Ship
I have changed photography focus and no longer need this filter case. Gently used, in excellent condition. Save over the original retail of $59.95.
From the manufacturer:
The Filter Hive Storage Case from Mind Shift Gear is a two-piece accordion-style filter organizer for holding six 4x6" rectangular and six 82mm circular filters. The Hive features a protective exterior case plus a removable interior divider that holds your filters. The removable divided insert features a protective dust flap.You can use the two sections either together or separately. Color-coding on the interior dividers allows you to rapidly identify your filters.
The exterior is coated with a water-resistant material with an additional polyurethane undercoating. Inside, the lining is 200D polyester, nylex lined filter pockets, closed-cell antilon foam, nylon binding tape, and 3-ply bonded nylon thread
The entire case can be belt-mounted or attached to your tripod via its quick-release connection. Front and interior zippered pockets are provided and accessed using thumb pulls. All the zippers are YKK design. The rear of the case features a belt-mountable panel and quick-release grab handle for buckling to a tripod.
