Thypoch Simera 21mm f/1.4 ASPH. Review
Admin
p.1 #1 · Thypoch Simera 21mm f/1.4 ASPH. Review
TITLE
Order the Thypoch Simera 21mm f/1.4 ASPH. lens:
Thypoch Store (Use promo code: FREDMIRANDA for a 5% discount at checkout)
B&H Photo: Black | Silver
___
Review Quick Links:
  1. Initial Impressions
  2. Resolution and Contrast at Infinity distance: Simera 21mm f/1.4 vs Voigtlander 21mm f/1.4 Nokton
  3. Sunstar Rendering
  4. Field Curvature
  5. Distortion
  6. Minimal Focus Distance performance
  7. Rendering compared to Voigtlander 21mm f/1.4 Nokton
  8. Chromatic Aberration (CA)
  9. Final Thoughts
  10. Samples 1: Cars and Coffee
  11. Samples 2: Harsh Lighting
Leica M11-D paired with the Simera 21mm f/1.4 ASPH. lens
Back to Quick Links
Initial impressions of the Thypoch Simera 21mm f/1.4 ASPH. lens:
I'm reviewing the silver version of the Thypoch Simera 21mm f/1.4 ASPH. It doesn't include a focus tab, but I'm happy to report it also doesn't have the infinity "lock" found on earlier versions of the Simera 28mm f/1.4 ASPH.
My first impression is that this is a rather large lens for the Leica M system, though surprisingly lightweight and not as thick in diameter as you'd expect for a 21mm f/1.4. It comes in at 426 grams without the supplied metal hood. We'll be comparing it throughout this review against its closest rival, the Voigtlander 21mm f/1.4 Nokton, which is about 60 grams heavier and noticeably thicker in diameter, despite both lenses being similar in length. That extra slimness makes the Simera feel more balanced on an M body, though since there are no 21mm framelines in the Leica M finder anyway, length isn't really a practical concern for either lens, and neither blocks an external optical viewfinder.
The Simera is available in black and silver finishes and shares a 62mm filter thread with the Voigtlander, but it stands apart with a minimum focusing distance of 0.23m in Live View, versus 0.5m for the Nokton, a real advantage for close-up work. It also adds a declick switch for the aperture ring, appealing to video shooters, and gives the focusing ring a tactile detent right at the 0.7m rangefinder coupling limit. The Voigtlander has no such marker, so moving from 0.7m down to 0.5m means you lose rangefinder coupling without any physical indication that you've crossed the line.
Leica M11-D paired with the Simera 21mm f/1.4 ASPH. lens with included hood
The Simera 21mm f/1.4 ASPH has 14 aperture blades, and as we'll see in my tests, it produces distinct 14-point sunstars starting at f/4. Its aperture shape also stays much more circular when stopped down, compared to the Voigtlander's 12 straight blades, meaning you can expect more rounded specular highlights from the Simera at smaller apertures.
Throughout this review, I'll be comparing the Simera's design, characteristics, and performance against the Voigtlander 21mm f/1.4 Nokton. The optical design is clearly inspired by the Cosina Voigtlander: the two share the same element and group count (13 elements in 11 groups) and a remarkably similar overall layout. It's pretty obvious Thypoch didn't try to reinvent the wheel here, taking the Cosina design as a starting point and adding enough tweaks to make it their own. Side by side, though, there are noticeable differences, particularly in center sharpness and field curvature shape, which we'll get into in more detail later on.
Simera 21mm f/1.4 ASPH. (silver) versus Voigtlander 21mm f/1.4 Nokton (black)
The Simera 21mm f/1.4 ASPH. lens is made up of 13 elements arranged in 11 groups, including 3 ED, 2 aspherical, 3 high-refractive index lenses.
The focusing ring on the Simera 21mm rotates smoothly, with just the right amount of resistance. A standout feature, similar to the Simera 28mm f/1.4 ASPH I reviewed previously, is that this lens also uses internal focusing. That means it doesn't extend when you adjust the focus ring, and the same can be said for the Voigtlander.
Leica M10-P Safari paired with the Simera 21mm f/1.4 ASPH.
The aperture ring on the Simera 21mm is designed with 1/3-stop increments, similar to the Zeiss ZM lenses. The clicks are more distinct than on the Simera 50mm f/1.4, with firmer feedback here on the 21mm, though I do think the ring rotates a bit too freely. As you adjust from wider to smaller apertures, the numbers on the barrel get progressively closer together, which I personally find less appealing than lenses with more consistent spacing between markings. The increments themselves also shift partway through: 1/3 stops up to f/5.6, then 1/2 stops from f/5.6 to f/8, and finally full stops from f/8 to f/16. This is likely a byproduct of the barrel design and its mechanical depth-of-field indicator, but it's not ideal if you prefer consistent spacing throughout the range.
Mounted on a Leica M3: The aperture numbers on the barrel get progressively closer together
One of the more innovative features on the Simera lens is its depth-of-field indicator, small open vents on the barrel that shift color as you adjust the aperture. Depending on the lens finish, they transition from silver or black to red, clearly marking the zone that'll be in focus. It's a fully mechanical approach that feels like a refreshing alternative to traditional depth-of-field scales, and it's especially useful here on the 21mm, where the wider field of view makes zone focusing more practical than it is on longer lenses like the 50mm or 75mm.
Mounted on a Leica M3: Innovative feature, with small open vents on the barrel that change color as you adjust the aperture
Another standout feature is the ability to declick the aperture with a simple flip of a switch on the aperture ring, enabling smooth, silent adjustments that are especially useful for videographers who need seamless transitions between settings.
Voigtlander 21mm f/1.4 Nokton vs Simera 21mm f/1.4 ASPH.
The focus throw on the Simera is relatively short, a 90-degree rotation from 0.23m to infinity, with an even shorter throw within its rangefinder-coupled range up to 0.7m. That's typical of modern M-lenses and makes for quick, precise focusing across distances. For comparison, the Voigtlander 21mm f/1.4 Nokton has a longer 120-degree throw and a minimum focusing distance of 0.5m.
The Simera also includes a tactile alert right at the point the rangefinder disengages, letting you know Live View will be needed to focus any closer. It's a unique touch the Voigtlander doesn't offer, and it's encouraging to see newer lenses build in details like this. One thing to watch for at close distances though: the focusing ring is quite sensitive and reacts to even the slightest movement.
Leica M11-D on charging dock paired with the Simera 21mm f/1.4 ASPH. with hood
Personally, I lean toward lenses with a longer focus throw for the extra precision it offers, since on both the Simera and the Voigtlander, even a minor adjustment can throw the subject out of focus. It's a design that rewards accuracy, but it demands careful, deliberate handling to keep the rangefinder properly aligned. Fortunately, my copy is well-centered and tracks accurately with my Leica rangefinder bodies, so focus performance has been optimal throughout.
Leica M11-D on charging dock paired with the Simera 21mm f/1.4 ASPH. without supplied hood
Thypoch Simera 21mm f/1.4 ASPH. Specifications:
  1. Focal Length: 21mm
  2. Maximum Aperture: f/1.4
  3. Minimum Aperture: f/16
  4. Lens Mount Leica M
  5. Angle of View: 90 degrees
  6. Minimum Focus Distance: 0.23m (0.7m rangefinder coupled)
  7. Optical Design 13 Elements in 11 Groups
  8. Special glass: 3 ED, 2 aspherical, 3 high-refractive index lenses
  9. Diaphragm Blades: 14
  10. Filter Size: 62 mm
  11. Dimensions (D x L): φ66 x 69 mm
  12. Weight: 426g without hood (measured)
  13. Metal hood included (bayonet style)
  14. Finishes: Aluminum anodized Black, Silver
Aug 24, 2026 at 08:09 PM
Admin
p.1 #2 · Thypoch Simera 21mm f/1.4 ASPH. Review
Back to Quick Links
All images were shot wide open at f/1.4, around 9am PST, with subjects at a variety of distances.
Post processing was kept to a minimum, just light sharpening and small exposure tweaks. I used the Adobe Color profile throughout so the lens's natural color rendition and tonal character could come through.
Camera: Leica M11-D (Shot at f/1.4; ignore estimated EXIF aperture)
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/4.0    1/1600s    64 ISO    0.0 EV
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/4.0    1/8000s    64 ISO    0.0 EV
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/4.0    1/1000s    64 ISO    0.0 EV
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/4.0    1/5000s    64 ISO    0.0 EV
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/4.0    1/320s    80 ISO    0.0 EV
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/4.0    1/10000s    64 ISO    0.0 EV
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/4.0    1/3000s    64 ISO    0.0 EV
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/4.0    1/2000s    64 ISO    0.0 EV
Aug 25, 2026 at 11:12 AM
RomanMF
p.1 #3 · Thypoch Simera 21mm f/1.4 ASPH. Review
Cool to see you reviewing this one. I've enjoyed mine quite a bit. Been shooting it across film and digital bodies. It's especially fun on my MP since I don't know what the frame will be exactly!
Aug 25, 2026 at 12:03 PM
_jim_
p.1 #4 · Thypoch Simera 21mm f/1.4 ASPH. Review
My experience is that this is a phenomenal lens (other than the frustrating ergonomic choices - namely the too-thin-too-close-to-the-body focus ring).
These photos look great. Don't let the people on the 3d pop thread see this...don't want to get mired in whatever that whole thing has become.
Aug 25, 2026 at 12:05 PM
Admin
p.1 #5 · Thypoch Simera 21mm f/1.4 ASPH. Review
Back to Quick Links
Here's a quick summary of the key differences between the Simera 21mm f/1.4 and the Voigtlander 21mm f/1.4 Nokton in terms of resolution and contrast. Both lenses perform similarly once stopped down to f/4 and smaller, but the Simera delivers higher contrast and resolution at wider apertures, especially wide open and in the center, where I see the biggest gap. Beyond resolution and contrast, both lenses' coatings produce the same neutral color cast, which is welcome, and both show similarly well-corrected lateral CA. The Voigtlander does render a slightly wider angle of view, though this could just be copy variation. I tested three copies of each lens, and the results shown here come from the sharpest, best-centered copy of each.
A high-resolution sensor brings a new level of clarity to lens evaluation, exposing both strengths and weaknesses across the frame. The results here were mostly what I expected going in, but I repeated the test multiple times over several weeks to make sure they held up. The other major difference between these two lenses, beyond the Simera's edge in center performance at wide apertures, is that its field curvature shape is considerably more pronounced. Because that curvature bends inward, the mid-field and extreme corners fall out of the focus plane when focusing at center. To account for that, I refocused for each crop region separately: center focus for the center crop, corner focus for the mid-field and extreme corner crops. I relied on magnified Live View throughout to keep focus precise and eliminate any rangefinder error from the comparison.
Digging a bit further into the results: the Simera shows a clear advantage in center resolution wide open, but that comes at a cost, Thypoch appears to have allowed a more extreme field curvature shape in exchange for that center performance.
One note on methodology: distortion, chromatic aberration, and vignetting are left uncorrected in my infinity tests, which is why the mid-zone and extreme corners appear darker here, there's no correction applied. This is intentional, so these characteristics remain visible and easier to evaluate in the 100% crops.
  1. Distance: Infinity
  2. Focus: Center - Best of three shots at maximum magnification
  3. White Balance: Daylight
  4. Both lenses are well centered, as verified with my decentering test.
  5. Software used: Lightroom with FM Default Landscape Sharpening; all other settings are at default.
    PS: Vignetting, Chromatic Aberration (CA), and distortion were not corrected either in post-processing or in-camera.
    Center Resolution and Contrast
    (open the browser window to view entire image without resizing)
    f/1.4
    f/2
    F/2.8
    F/4
    F/5.6
    F/8
Aug 25, 2026 at 07:08 PM
Admin
p.1 #6 · Thypoch Simera 21mm f/1.4 ASPH. Review
Mid-zone Resolution and Contrast
f/1.4
f/2
F/2.8
F/4
F/5.6
F/8
Aug 25, 2026 at 07:10 PM
Admin
p.1 #7 · Thypoch Simera 21mm f/1.4 ASPH. Review
Extreme Corner Resolution and Contrast
f/1.4
f/2
F/2.8
F/4
F/5.6
f/8
Aug 25, 2026 at 07:11 PM
Admin
p.1 #8 · Thypoch Simera 21mm f/1.4 ASPH. Review
To illustrate my point about the Simera's field curvature being more extreme by design, here's a section showing 100% crops from the area between the corners and mid-field, both lenses wide open, but this time with focus locked at center rather than refocused for that zone. You'll see the Voigtlander pulling ahead here, not because it's inherently sharper, but because its flatter field curvature keeps that zone closer to the focus plane when center-focused. This characteristic showed up in all copies of the Simera I received.
f/1.4 off-axis (focused at center for both lenses)
Aug 25, 2026 at 07:19 PM
DandA123
p.1 #9 · Thypoch Simera 21mm f/1.4 ASPH. Review
Might I assume that possibly by f2.8 or f4, by focusing both lenses on the center of the frame, that mid-field and especially the corners (or even extreme corners), are fairly comparable in sharpness from both lenses...essentially neutralizing the apparent field curvature seen in the Thypoch 21mm? The silver Thypoch 21mm was the lens I was/am most interested in acquiring, but early reviews suggested mediocre corner performance and that's why I held off up till now. Its field curvature certainly explains why.
Aug 25, 2026 at 09:20 PM
Admin
p.1 #10 · Thypoch Simera 21mm f/1.4 ASPH. Review
You assumed correctly. Stopping down increases the depth of field enough to mask the field curvature, bringing both lenses to a similar level even with center focusing. As you can see in the crop below, a couple of stops down for landscapes, their performance is effectively equalized...especially since we usually shoot at f/8 and smaller apertures anyway.
In fact, the Simera's field curvature can work to your advantage in landscapes by helping keep the foreground sharp since it matches that curved plane. It reminds me of the Zeiss ZF/ZE 28mm f/2 Distagon which is one of my favorite landscape lenses that shared a similar trait.
Aug 26, 2026 at 11:51 AM
Admin
p.1 #11 · Thypoch Simera 21mm f/1.4 ASPH. Review
Back to Quick Links
Sunstar rendering
Sunstar preferences are subjective. Some photographers want crisp, well-defined rays, while others prefer a softer, more organic rendering. The Simera 21mm f/1.4 ASPH manages to offer a bit of both: circular bokeh when stopped down, paired with clearly defined sunstars starting at f/4.
That balance comes down to the aperture design. Its 14 rounded blades aren't inherently built for razor-sharp sunstars, but they do excel at holding a circular aperture shape through the aperture range, which is what gives specular highlights that smooth, round look both wide open and stopped down. In short, the design leans toward pleasing bokeh over aggressive sunstar rendering, though it still delivers well-defined stars once you're at f/4 or beyond.
For context: the Simera 21mm produces well-defined sunstars from f/4 through f/16, similar to the Simera 28 and 50mm f/1.4 ASPH. The Simera 75mm f/1.4 tells a different story. Its 16-blade design needs to be stopped down to f/11 or f/16 before sunstars reach comparable definition.
Below is a progression showing the Simera 21mm f/1.4 ASPH from f/1.4 to f/16 in 1-stop increments. True to its 14-blade aperture, the lens consistently produces 14-point sunstars throughout, as the samples show.
f/1.4
f/2
F/2.8
F/4
F/5.6
F/8
f/11
f/16
Aug 26, 2026 at 02:30 PM
DandA123
p.1 #12 · Thypoch Simera 21mm f/1.4 ASPH. Review
...Show more →
This confirmation was exactly what I was looking for and your explanation and comparative shots illustrate this perfectly. Thanks very much!
Aug 26, 2026 at 10:20 PM
Admin
p.1 #13 · Thypoch Simera 21mm f/1.4 ASPH. Review
Back to Quick Links
Field Curvature
The field curvature of the Simera 21mm f/1.4 ASPH actually varies depending on the focus distance.
Up close, it curves slightly outward, but beyond 2 to 3 meters, it gets a bit more complex and wavy. At long distances, it reverses entirely, bending backward or inward.
While I expected some field curvature at infinity, it's definitely more pronounced than usual here. In contrast, the Voigtlander 21mm f/1.4 Nokton starts out similarly curved near close range, but flattens out nicely at infinity.
I have a strong feeling this lens was optimized for a thicker sensor stack (like Sony's), and that on a Sony body, the field curvature would be much more neutral at infinity. I'll have to test that out to see.
To demonstrate this, I shot a series ranging from the minimum focus distance out to near infinity. For clarity, I converted the images to black and white, with the sharpest areas highlighted in black in the animation below:
Aug 27, 2026 at 12:56 PM
Admin
p.1 #14 · Thypoch Simera 21mm f/1.4 ASPH. Review
Back to Quick Links
Distortion
Similar to the Voigtlander 21mm f/1.4 Nokton, the distortion is minimal and of the pincushion variety, though it's virtually unnoticeable in real-world shooting.
If you ever want to correct it in Lightroom, a simple setting of -2 handles it perfectly.
This makes it a stellar choice for both street and architecture photography.
Here’s a straight-out-of-camera shot showcasing how minimal the distortion is:
Uncorrected for distortion
  LEICA M11-D    Thypoch Simera 21mm f/1.4 ASPH. lens    21mm    f/6.8    1/90s    200 ISO    0.0 EV
Pincushion corrected "-2" in Lightroom
Aug 27, 2026 at 02:23 PM
rscheffler
p.1 #15 · Thypoch Simera 21mm f/1.4 ASPH. Review
Looking forward to that test.
The question and uncertainty about stack optimization was a long-running discussion in an older Thypoch thread. I'm not sure if we ever were able to decisively conclude whether Thypoch optimized their mirrorless mount versions of these lenses for thicker sensor stacks vs. M mount versions. But some of these lenses are only available in M mount as it is, such as this 21mm and I think the 50 and 75. Unless you buy the cine versions. And there I think it was implied by some that there was stack optimization, but not entirely sure if it's actually the case.
It's also interesting to see the deeper plane of focus at the edges of the frame in the field curvature gif. I'm guessing this is a side effect of increased vignetting resulting in an effectively smaller aperture in this region, resulting in somewhat deeper depth of field, yet not deep enough to offset field curvature at wide apertures at infinity.
Aug 27, 2026 at 10:05 PM
Steve Spencer
p.1 #16 · Thypoch Simera 21mm f/1.4 ASPH. Review
...Show more →
Thypoch has not been consistent in what mounts they make their Simera lenses.
The 21mm and 75mm Simera are only available in M mount.
The 50mm Simera is available in M and Z mount
The 35mm Simera is available in M, Z, E, and RF mount.
The 28mm Simera is available in M, Z, E, RF, and X mount.
They also offer all of these lenses in E mount as a cine version.
They say nothing about why they take this approach and what they do about sensor stack optimization. In the other thread Nehemiah tested a 50mm cine lens and it seemed to have a different optimization than the non-cine version but with just one lens tested it is hard to know that for sure.
I suspect that Thypoch doesn't optimize for any mount, but purposely designs for a medium sensor stack thickness considering that good enough for both thin sensor stacks (like the Leica M) and thick sensor stacks (like Sony E mount). Fred's results are largely consistent with that so far. I expect his Sony test will show that the lens isn't really optimized for that mount either. We will see how that turns out and my guess of taking a middling approach is of course just a guess. I could easily be wrong.
Aug 28, 2026 at 06:34 AM
_jim_
p.1 #17 · Thypoch Simera 21mm f/1.4 ASPH. Review
Fred, do you still have your Zf?
If the design of the 21 Simera is optimized for a middle-of-the-road sensor glass thickness, it might be possible that the Nikon cover glass is well suited for that.
I will say that the experience of using the lens on my Zf is better ergonomically than on my M's. The thin mount adapter adds enough space between the body and the focus ring to make it more comfortable. Additionally, having an EVF is far more accurate that using an external VF.
Aug 28, 2026 at 11:43 AM
_jim_
p.1 #18 · Thypoch Simera 21mm f/1.4 ASPH. Review
At least mine seems to work well on the Zf (though, I recognize that the lower resolution sensor is less demanding).
Jenny by Jim Fischer, on Flickr
Dowtown Atlanta by Jim Fischer, on Flickr
Girl at Georgia Aquarium by Jim Fischer, on Flickr
Jenny at Georgia Aquarium by Jim Fischer, on Flickr
Alex by Jim Fischer, on Flickr
Tyler & Alex by Jim Fischer, on Flickr
All: Nikon Zf, Thypoch 21mm f/1.4 Simera
Edited on Aug 28, 2026 at 11:58 AM · View previous versions
Aug 28, 2026 at 11:53 AM
_jim_
p.1 #19 · Thypoch Simera 21mm f/1.4 ASPH. Review
With an external VF on film, it's more challenging to use, but still worth it (in my own opinion).
Dad by Jim Fischer, on Flickr
Lloyd Center by Jim Fischer, on Flickr
Leica M5, Thypoch 21mm f/1.4 Simera, Fomapan 100, Adox XT-3 1:1.
The Gordon House Kitchen by Jim Fischer, on Flickr
Leica M5, Thypoch 21mm f/1.4 Simera, Cinestill 800T.
Aug 28, 2026 at 11:57 AM
RomanMF
p.1 #20 · Thypoch Simera 21mm f/1.4 ASPH. Review
This thread is making me want to bring this lens back out. First time I used it was on my MP as a B-cam covering a live music event 😅
EDIT: Hmm having issues with the FlickR embeds.
RMF_Mothe_MP by Roman France, on Flickr
RMF_MotheII_MP by Roman France, on Flickr
Aug 28, 2026 at 01:07 PM
