FS: Nikon FA and Lenses 35-70 28-105 80-200 100-300 2X Extender
71sbeetle
p.1 #1 · FS: Nikon FA and Lenses 35-70 28-105 80-200 100-300 2X Extender
  Item price reduced in the last 24 hours   Nikon FA
Available 2 following
Price: $80.00
Shipping instructions: CONUS shipping included in the price
I am going to be selling most of my camera. Starting with my Nikon cameras.
This is a very clean Silver Nikon FA body (Serial Number 5068820). I have film tested this camera and everything seems to work great except the shot counter which has been finicky. I basically have to use a bamboo stick to push the small lever before closing the film door. The door seals appear to be missing (or maybe there's not supposed to be seals in the channels?) but I have used the camera in direct sunlight with no light leaks. Other than that it works, I shot a few rolls with it with no other issues. The light meter matches my Sekonic L858D readings (except for a couple of times but at worst case it was only a third of a stop off). It also comes with the original vintage yellow Nikon strap.
I can send sample pictures from a roll I just shot a couple of days ago
Flickr gallery with more pictures:
https://flic.kr/s/aHBqjB9MSM
Will combine shipping on multiple items
  Item price reduced in the last 24 hours   Tokina 35-70 f/2.8 AT-X
Available
Price: $80.00
Very clean lens overall, everything appears to work properly and I haven't had any issues with it. With caps and UV filter.
I can send pictures taken with this lens if needed
  Item price reduced in the last 24 hours   Tokina 80-200 f/2.8 AT-X
Available
Price: $80.00
Very clean lens overall, everything appears to work properly and I haven't had any issues with it. Just noticed that one of the "rabbit ears" is slightly bent but should be able to bend it back easily. With caps, hood, UV filter and case
  Item price reduced in the last 24 hours   Tokina 100-300 f/4 AT-X
Available
Price: $80.00
Very clean lens overall, everything appears to work properly and I haven't had any issues with it. With caps, hood, UV filter and case
  Item price reduced in the last 24 hours   Vivitar 28-105mm f/2.8-3.8 Series 1
Available
Price: $27.00
I tested this lens and everything seems to work correctly, but it does make a noise when zooming in and out and I just noticed from the pictures that the bottom trim piece near the mount seems loose. With caps and UV filter
  Item price reduced in the last 24 hours   Tokina RMC Doubler 2X Extender
Available
Price: $23.00
Doubler, tested and seems to work fine, includes caps
I can send pictures taken with this extender if needed
Aug 12, 2026 at 07:51 PM
