A7CR vs A7RV
campy
p.1 #1 · A7CR vs A7RV
Assuming same used price and your lens selection would be pretty much the same going forward, why would you pick the A7R over the A7RV? I only see the smaller size as a plus but maybe there are other things. I want to get back into Sony but want it to be a equal or better camera than my Canon R5. Also thought maybe the A7RIV as prices are falling, but don't think it's equal to the Canon R5. I would probably keep the Canon and RF 70-200 f2.8 and sell my other lenses.
Aug 10, 2026 at 08:28 AM
BigBabyMoses06
p.1 #2 · A7CR vs A7RV
I moved from an R5 to a A7RV. Only things I miss from the R5 was the file sizes, colors, and mechanic shutter shooting speed. Assuming we're talking R5 mk1, the Sony is miles better in autofocus. It was like night and day for me.
Be aware that the Cr only does 1/4000 of a second, which I find annoying low and a deal breaker when shooting primes in bright sun. Ask Gemini or Claud or something to compare the abilities and differences of the two.
Edited on Aug 10, 2026 at 08:48 AM · View previous versions
Aug 10, 2026 at 08:47 AM
Jack Flesher
p.1 #3 · A7CR vs A7RV
Size is the only advantage to the A7CR. I understand AF is similar. IIRC, A7RV has a couple frames per second faster framerate, like 10 vs 8 fps. A7RV has 2 dual use card slots, the A7CR, 1 SD slot. Finally, A7RV has a better EVF.
The 33mp A7Cii does have notably better high ISO noise characteristics, for whatever that’s worth in your search. It is my goto travel and street body for that reason as well as looking more like an older P&S camera than a pro digital camera — attracts way less attention, especially with a smaller prime attached.
Seabassius
p.1 #4 · A7CR vs A7RV
Get an a7cr in your hands and try it if you can. I've owned it twice and love the idea of the size of it, but then when it comes to actually using it I'm not as thrilled. For me specifically I like having a nice EVF, joy stick, and good button sizes where I can use it with gloves (I wanted to take it skiing with me). Having said that I still look longingly at that small size
Aug 10, 2026 at 08:51 AM
MikeEvangelist
p.1 #5 · A7CR vs A7RV
I've gone back and forth on this question a couple times. Assuming you buy used, there is no price advantage for either, so here's how I'd sum it up:
Image quality - same
A7Cr advantages - Size and weight
A7Rv advantages - better EVF, better rear screen articulation, two card slots & can use CFe cards (faster buffer clearing if you're shooting fast), joystick & more buttons, can use battery grip.
Aug 10, 2026 at 08:52 AM
Jack Flesher
p.1 #6 · A7CR vs A7RV
Good point. I did have to add a Houge base-grip to my A7C2 to make it handle more naturally.
Aug 10, 2026 at 08:55 AM
Lukacs
p.1 #7 · A7CR vs A7RV
I like A7CR's form, I think it's matters alongside the size, no EVF pumb on top, smaller EVF eyecup. A7CR with small lens fit into my EDC sling, A7RV is not. The low resolution screen, which is articulating didn't work for me, migrated back to A7RIVa for tilting high resolution LCD, also prefer to have joystick, full mechanical shutter with 1/8000 speed. I miss the form factor of the CR though (in case of A7RIVa the AI subject detection and better IBIS also, but not make a drastic difference to me).
Aug 10, 2026 at 09:35 AM
InFocus2014
p.1 #8 · A7CR vs A7RV
I've extensively shot with the A7RV and have purchased and sold the A7CR twice.
There seem to be a lot of A7CR fans out there, so my opinion might not mean very much.
I could never become happy the very low resolution EVF and LCD on the A7CR and found it to be annoying. The lack of eye-cup made it challenging to shoot in sunny or backlighted conditions and the aftermarket cup I purchased was a kluge. I like fast lenses and the EFCS, only, on the CR was not great for bokeh at fast shutter speeds. The low maximum shutter speed sometimes necessitated ND filters. Also, I'm simply not comfortable with one card slot.
I typically shoot the A7R5 with an L-bracket. When traveling I take it off and the camera is comfortably small and light. I've replaced the A7R5 with the A7R6 and I am now a super-happy camper. With complete certainty, there is no third A7CR in my future, but my mind is open for a potential A8CR.
Aug 10, 2026 at 09:46 AM
laterplease
p.1 #9 · A7CR vs A7RV
I'm with @Seabassius on the A7cx handling. If I want a small camera I have several RX100's or an NEX5T. While the cr may be smaller than your Canon, its not a small camera and it still requires full frame size lenses. I kept my A7cr (paired with either the 35ZA or 40G) for a week. Never jelled with it; its not small in my book, the evf is mediocre and inconsistent with the pricing of the body, the flippy lcd is a pita for street shooting/quick deployment, it feels quite chunky in hand, mount a zoom and you'll want an acessory grip and the design is blah (I am a photographer, looks do count). On the other hand, if you want a high pixel count in a FF edc then maybe its worth it for a slightly smaller size. I assume there's plenty of people thrilled with the camera, so there's 2 sides to the discussion.
Aug 10, 2026 at 10:00 AM
MikeEvangelist
p.1 #10 · A7CR vs A7RV
I should add...I miss the A7Cr and am thinking of adding one (again). The size/performance is really unbeatable.
Aug 10, 2026 at 10:17 AM
Andyuk109
p.1 #11 · A7CR vs A7RV
I picked up an A7CR initially to replace a ZF as a body for manual focus lenses
Realised that wasnt really viable for me (ergonomics, evf, no focus confirmation etc) but somehow it has grown on me a bit
Now lives in my work bag with a pair of lenses as an everyday carry option. An A7RV probably wouldn't do the trick
Aug 10, 2026 at 11:40 AM
bwcolor
p.1 #12 · A7CR vs A7RV
In theory the A7CR is great. I sold my A7Rv to purchase one, but the 10 year old EVF ruined things for me. The A7RV and VI are already small compared to many cameras. I bought small 90mm,40mm,17mm lens and repurchased what I consider one of the best Sony lenses, the 24mm GM. I thought that this would make a great travel selection, but soon after purchase I took another system altogether on vacation and my wife used the A7CR/40mm. The other system was medium format and in hand felt much better than either the A7CR, or A7Rv. The other system was amazing, so I sold the A7CR. I suspect that the A7CRii will have a much better technology EVF..probably five year old technology, but that should be a welcome improvement. We are headed overseas soon. My wife complained that the 40mm didn’t work in even moderately cramped spaces, so she will take the A7Rvi and the 24-50mm f/2.8G. This small zoom balances better on the slightly larger camera. If you don’t shoot BIF, the A7Rv is an amazing camera.
Aug 10, 2026 at 11:57 AM
Lukacs
p.1 #13 · A7CR vs A7RV
A7CR is a great concept by the way. With additional grip bulkier high resolution lenses have better handling (GM primes), detaching the grip it becomes an excellent EDC camera in 26MP Mraw with cupcake lenses like G series or Zeiss 35 2.8. I only wish it came with 2.1M tilting screen for my waist level style shooting.
Aug 10, 2026 at 12:59 PM
Craig Gillette
p.1 #14 · A7CR vs A7RV
Although not quite there, one seems close to being able to get a used A7CR and A7Rv for the price of an A7Rvi..
I kind of considered either (from an A7Riv - I like mine, but wouldn't suggest someone buy one these days given the A7Rv or A7CR prices, especially used.)) then dove into the A7Rvi. I have an A6700, too. As mentioned, the size is the selling point for the A6xxx or A7C types. Not everyone likes them. Perhaps grip/handling or finder are the biggest negs for some.
The A7Rv has a number of things the smaller ones don't. Some added controls, speed, two slots, "bigger" for handling bigger lenses (yeah , we know, put your hand under the lens.) and majorly better evf. If one wants to really keep size down, using smaller lenses, etc., then the A7CR offers that. It is smaller and lighter and packs differently. Perhaps, for some, more than just looking at specs and gear pics may suggest.
I've put my 28-200 on the A6700 a few times. It may be at the almost too big lens point. OTOH, I wandered around a wild animal park with the A6700 and 70-350 and I got the feeling I was enjoying it more than quite a few folks with bigger cameras and lenses. Others could easily have a different idea of the lens point suggesting the larger or smaller bodies for their own uses.
Aug 10, 2026 at 03:52 PM
philip_pj
p.1 #15 · A7CR vs A7RV
'There seem to be a lot of A7CR fans out there, so my opinion might not mean very much.'
This is the reason that it does. The oft-mentioned buy-sell-buy-sell cycles indicate that the body is what people want but it's not quite there. How much extra would it have cost Sony to use the a7rv EVF? How much would that unit add to gross weight?
The RX1 external unit for the hot shoe weighed 26 grams. We might surmise that a similarly mounted high res unit might add 100 grams, possibly they could also leave the built in unit as is. 615 grams is still a very light camera, and you could still use it without the better EVF if desired. But they haven't done that..
Aug 10, 2026 at 04:36 PM
Lukacs
p.1 #16 · A7CR vs A7RV
I wrote a review last year on DPR about A7CR.
Overall my conclusion was I'd recommend A7CII instead for following reasons:
-Significant cheaper
-Low resolution screens better suited for 33MP sensor for checking critical focus, and manual focusing.
-Compact lenses are good on 33MP pixel level, but most of them suffers edge softness and especially some level of field curvature which is clearly visible on 60MP.
-Since EFCS only, higher shutter speed (over 1/2000) has significant effect on background blur, A7CII's sensor readout speed is twice as fast as CR's, it's a huge difference when you have to rely on E-shutter preserving bokeh.
Aug 11, 2026 at 03:14 AM
