Wireless Transfer Utility on Linux?
jimmuller
p.1 #1 · Wireless Transfer Utility on Linux?
I've been using the Nikon Wireless Transfer Utility, a.k.a. Nikon Transfer 2, to move images to my Windows laptop when I don't have so many to move. (A USB cable is faster and also charges the battery, but wireless transfer is more convenient.)
I'm trying to move all my computer activity to a Linux Mint (Cinnamon version) computer so I can eventually replace Windows with Linux on the laptop. I have Linux versions or substitutes for most of my apps, and for those with no good substitute yet the Windows programs run just fine under wine.
I managed to install the Nikon apps Studio and Wireless Transfer Utility by running the installers in wine, and the WTU setup program also runs in wine. I can connect the computer's WiFi to the camera's WiFi. But there the success stops. On Windows, once a connection is established the computer apparently brings up a background connection program (unless Windoze is off in its own dreamworld), the network icon on the camera's screen turns green, and I can transfer pics from the camera. On the Linux computer that last connection never seems to happen. The background program would seem to need wine as its default launcher, but I'm not sure yet what that program is.
Have any of you managed to do this on a Linux computer?
Aug 07, 2026 at 07:45 AM
snapsy
p.1 #2 · Wireless Transfer Utility on Linux?
The Windows implementation uses a Nikon-installed service named "NkPtpEnumWT3" to facilitate the transfer of files via PTP from the camera. I don't believe there's any way to natively run Windows service under Linux (even with Wine) but you might be able to get it to work with a Windows VM using VirtualBox.
If you don't want to do that you can try my AirNef utility, which uses the same PTP protocol to transfer files from the camera. It was originally designed in the pre-Z days but it can be made to work with Z camera but with some acrobatics turning WiFi on/off that might be too cumbersome. Here's the link:
https://github.com/horshack-dpreview/airnef
Lastly, if you have a newer Nikon camera with FTP support I would recommend that instead. It's faster and more reliable than the PTP mechanism.
Aug 07, 2026 at 08:27 AM
jimmuller
p.1 #3 · Wireless Transfer Utility on Linux?
Thank you. I may try your PTP program if I get adventurous enough. I tried an FTP connection but no luck so far. Setting it up on the camera (Z5ii) isn't intuitive. But there are several things I need to try before throwing my hands up in surrender. I can always revert to a cable connection but sometimes wireless is so much more convenient.
Aug 07, 2026 at 04:06 PM
snapsy
p.1 #4 · Wireless Transfer Utility on Linux?
Did you set up an FTP server on the computer (Linux)? That's the more involved part but there should be some online guides that step you through it. It's definitely worth the effort.
Aug 07, 2026 at 04:09 PM
RoamingScott
p.1 #5 · Wireless Transfer Utility on Linux?
This is the exact use case they created Imaging Cloud for, FWIW
Aug 07, 2026 at 04:14 PM
EB-1
p.1 #6 · Wireless Transfer Utility on Linux?
And to have access to your image files. TANSTAAFL.
Aug 07, 2026 at 04:32 PM
jimmuller
p.1 #7 · Wireless Transfer Utility on Linux?
Oh yes. I've used it to transfer files between my laptop to the Linux machine. But I may not have done the connection right from the camera.
FWIW, I refuse to put anything on the cloud. In the cloud? At the cloud? Whatever the correct prerposition should be.
Aug 07, 2026 at 04:39 PM
snapsy
p.1 #8 · Wireless Transfer Utility on Linux?
I assume it got past the WiFi part and is giving you grief about the FTP login? What error are you getting? Did you setup a separate FTP user for the camera or use your regular Linux login? (Or anonymous?)
Aug 07, 2026 at 04:50 PM
jimmuller
p.1 #9 · Wireless Transfer Utility on Linux?
Ah, well, you see, I'm getting no message at all. Which is to say nothing happens. I'm using the same user name and password I use for connecting my Windows machine to Linux. But the thing is, I probably didn't set up the camera correctly. There is no reason to think the Linux is on the camera's WiFi.
F'rinstance, when I go to the Connect By FTP page I see Configure and Options. Not sure what each does. So I figured I need to create a profile. When it was finished it showed three (!) connection possibilities, whereas Connect To Computer shows only 1. What the'? (How do I get rid of one I don't want?) I tried starting two of them, but neither one showed up in the Linux connection options. When I do Connect To Computer the Windows machine shows Nikon-something-or-other as a WiFi to select.
Oh well, I can always transfer files by pulling the SD card, and I have to connect to USB every so often to charge the battery anyway.
Aug 07, 2026 at 07:52 PM
mivadep
p.1 #10 · Wireless Transfer Utility on Linux?
It's certainly not wireless, but if you do go the SD card route, I'm a huge fan of Rapid Photo Downloader. It truly is rapid and remembers what you've already transferred.
You might be better off asking this question over at pixls.us which is all about open source photography.
Aug 07, 2026 at 07:57 PM
snapsy
p.1 #11 · Wireless Transfer Utility on Linux?
You want the camera to use your home router (infrastructure mode) rather than creating its own ad hoc network, ie both the camera and computer will talk to each other through your home WiFi network rather than through an ad hoc direct connection.
Delete all your existing network profiles in the camera and follow these steps in the camera:
Connect to FTP Server -> Network settings -> Create profile -> Connection wizard.
Name the profile, then press OK
Select "Search for Wi-Fi network" and press OK
Select the SSID of your home WiFi Network
Enter your WiFi password, press OK
Aug 07, 2026 at 08:34 PM
jimmuller
p.1 #12 · Wireless Transfer Utility on Linux?
Thanks
Aug 07, 2026 at 09:23 PM
old-gregg
p.1 #13 · Wireless Transfer Utility on Linux?
@jimmuller I too love the convenience of wireless transfer, but recently migrated to a more convenient setup. Do you have a smart NAS in your house? You can install an FTP server on it. When I shoot this way, I don't need my laptop or my desktop to be turned on. The NAS is up and running 24/7. When I'm done shooting, open the laptop and I see the files on the network share.
Aug 07, 2026 at 10:04 PM
