p.1 #1 · Sold: Canon CINE-SERVO CN7x17 KAS S 17-120mm T2.95 with IB/E eUMS PL/EF
Price: $4,800.00 Payment method: PayPal Item condition: 8 Well used - may exhibit "dings" or finish marks
I've had this lens for a little under a year and it's amazing, however I'm trying to downsize my kit to not be quite so big and heavy so I'm going to let this thing go. I'm sad because this was a "dream lens" for me... but I'm getting older and I'd like my kit to get lighter.
The lens itself is in pretty good shape. It shows signs of use, but nothing that would indicate it's been abused. Everything works as it should. The glass is clean. It includes the hood, caps for both the lens and hood, rear EF cap, rear PL cap, a B+W filter on the front, and a Pelican case with custom foam in it to hold it alI. It has been converted using the IB/E Optics eUMS system from it's original EF mount to a field-swappable EF/PL mount and all the parts to do so are included. This was a $3000-ish service and I believe was only done by AbelCine so I'm assuming that's who did this one. It also includes the original EF parts if you ever want to have it swapped back to stock.
I can also include a Bright Tangerine Morissey lens support and two 12" Bright Tangerine Titanium Rods. Also includes 24-pin to right-angle short extension cable and 24-pin to D-Tap cable.
