what did you guys do with your EF lenses ?
lens_payoff_0l
p.1 #1 · what did you guys do with your EF lenses ?
Question - I have some quality EF - L lenses and am thinking of selling and moving over the Leica ( I have th Leica q3-43) or keep using it - but I don’t like the idea of having 2 systems. Trying to get some wisdom from experienced users.
I have EF- L
50 f1.2
24-70 f2.8 II
70-200 f 2.8 II
Of course I would loose money on selling it - one tought I had was to get used Leica SL2 SL2-S or SL3 and get an adaptor and then uses these lenses.
Other would be to sell - of course if I sell I would have to go to EBay as I don’t have enough posts here and I am sure no one would buy this from a person who recently joined.
Another alternative is go give to MPB - and get some cash.
OR - I am sure this one is going to be the most popular - use these lenses with my Canon 5D MK III.
Thoughts ?
Jul 26, 2026 at 06:33 PM
jojib
p.1 #2 · what did you guys do with your EF lenses ?
I have superb EF L lenses and that's the main reason I bought the R6MKII even though I've gone with Sony mirrorless system before. Also, I still shoot occasionally with the 5Ds. Having said that if you are not ok with two systems then you might as well trade or sell the EF lenses while they still have a value.
Jul 26, 2026 at 06:54 PM
MintMar
p.1 #3 · what did you guys do with your EF lenses ?
I went to RF camera and I am using it as better focusing EF Camera with a shorter battery life, that can at least offset that shorter battery life by goodies like horizontal levels and instant histogram.
Jul 26, 2026 at 07:49 PM
Gochugogi
p.1 #4 · what did you guys do with your EF lenses ?
Some EF designs have never been replaced with a RF version or the RF replacement is silly expensive. So I sold off most of my EF lenses but kept a few favorites and continue to use them.
Jul 26, 2026 at 07:58 PM
MintMar
p.1 #5 · what did you guys do with your EF lenses ?
I guess it's still cheaper to buy a RF-EF adapter for each of those lenses than buy RF versions.
Jul 26, 2026 at 08:11 PM
Ferrophot
p.1 #6 · what did you guys do with your EF lenses ?
Still using them with EF-RF adaptors. Since getting the RF25-105 f4L the primes don't see much daylight, but they are still used for photography after sunset. I only converted to RF lenses as the EF ones failed or better coverage RF ones arrived (200-800). Even my 2001 Sigma EX 70-200 2.8 still works a treat on the R6.
Jul 26, 2026 at 10:26 PM
rscheffler
p.1 #7 · what did you guys do with your EF lenses ?
Transitioning to mirrorless, I adapted my existing EF lenses to the new R cameras and then slowly added or replaced those lenses with RF equivalents. Four years later and the only EF lens I still regularly use is the EF 200-400 in part because there is no direct equivalent, though the 100-300 with 1.4x TC is close (and optically much better). Also a selection of TS-E lenses, but those get far less frequent use. Everything else that I had in EF now has an RF equivalent that I prefer for various reason. Some are smaller or lighter. Some are considerably better, optically or with respect to AF performance.
The two EF zooms you have will work even better on Canon mirrorless than on Canon DSLRs. I'm not sure what the performance tradeoffs will be if you adapt them to L mount. AF may be slower than if you were to get an R5 or R6II, R6III, etc. Also, the older Leica SL cameras don't have phase-detection AF pixels on the sensor, which means that for some applications with moving subjects, AF performance may not be even as good as the 5DIII (it's something you'd have to test) and I don't know how this might be complicated by adapted EF lenses as opposed to native L mount lenses.
What is driving your interest in the Leica cameras? I mean for me with Leica, albeit the M system, it has primarily been the lenses. If I had the extra cash lying around, I'd buy into the Leica SL system, but not for the cameras, rather for lenses like the APO Summicron line. I wouldn't personally be interested in adapting my EF lenses to an SL camera.
Given your location, when you're visiting Manhattan, you could stop by the Leica store there to try out the SL cameras with your lenses (you'd probably have to bring the adapter) and compare how those perform to the native Leica L mount lenses. I have not been to that Leica store but other ones I've visited have been very easygoing about trying out whatever equipment they have on display.
Jul 26, 2026 at 11:40 PM
tsangc
p.1 #8 · what did you guys do with your EF lenses ?
Same here. I kept them all despite having an RP and R5 and use them all the time. They got better with the adaptors.
Jul 27, 2026 at 12:11 AM
burningheart
p.1 #9 · what did you guys do with your EF lenses ?
See this post by Fred on adapters
https://www.fredmiranda.com/forum/topic/1929020/4#16974291
If you keep the lenses and use them on the 5D MKIII you will be shooting multiple systems. Though there are many who shoot multiple systems, it is really up to each individual if they want to.
I shoot multiple systems and still have many EF lenses, do I use them a lot. No, but each still has its uses and can not be replaced by an RF lens or equivalent lens on another system. Some I use for IR because the RF lenses has an IR light inside the lens that may impact the image whereas the EF lens is fine. I use my Tilt shift lenses on my GFX system.
I go by a rule of thumb on lenses if I do not have a use for them I sell them. Otherwise they sit collecting dust. I don't think of it as loosing money as I have had use of them over the years but if it is no longer being used then I may as well get something in return.
Jul 27, 2026 at 12:28 AM
Sy Sez
p.1 #10 · what did you guys do with your EF lenses ?
Kept the 16-35F4L, and sold the rest to MPB.
Jul 27, 2026 at 07:11 AM
gdanmitchell
p.1 #11 · what did you guys do with your EF lenses ?
The answer will be different for everyone, but if you are really moving to a new system it probably makes sense to do it wholesale (if gradually) and just move on from most, if not all, of the EF lenses.
I know it hurts. I’m on the verge of a long-planned transition from my Canon DSLR system with a group of excellent EF lenses to a Sony system. I may keep one of the less-used but important EF lenses and use it with an adapter, but I’m going to move to native glass on the new system.
Options for the old glass?
- Try to sell on the used market. (Plus: you may get a bit more money. Minus: the usual issues with private sales.)
- Sell to one of the used lens resellers. (Plus: Quick and easy, and you move on. Minus: You won’t get as much for the lenses as you might from a private sale.)
3. Give them to some deserving young, promising photographer or to college/school problem that is still relying on Canon EF gear. (Plus: You do a good thing, and it may be very easy. Minus: You dont’ recover any cash value.)
Good luck.
Jul 27, 2026 at 09:39 AM
Llewtwo
p.1 #12 · what did you guys do with your EF lenses ?
If the 70-200 is non IS it's a bundle worth roughly 2000 retail on the used market. The 50 1.2 is widely available used in the EF mount. The 24-70 remains a sought after lens and is one of Canon's best lenses in my opinion. If the 70-200 is non IS it is several generations old but still a good lens. It would be a good bundle for someone looking for those lenses and either mirrorless with an adapter or older EF bodies. If it were me I would want to sell them all in one transaction even if I lost a couple hundred doing it that way. A dealer isn't going to give you much for them in my opinion. If you pay the fee you can try to sell them here. The buyers and sellers here are pretty reputable. You would be the unknown I guess here.
Jul 27, 2026 at 01:33 PM
