Price: $345.00 Payment method: PayPal Item condition: 9 Shows signs of use, but very clean Shipping instructions: Standard Ground
Leofoto LM-324CLX Summit Series 75mm Bowl Tripod (77” Max Height - 55lb Max Load) - Thinning the tripod herd and in excellent condition. Can be used with 75mm bowl tripod heads or flat base tripod heads by adding the included drop in flat plate. I’ve added padded leg wraps to add protection and makes it much more comfortable to carry particularly when cold. Comes with rubber feet only. This is the newer “CLX” version with updated leg angle adjustment locks and not the older ‘CL” version. No original box or paperwork just the tripod and padded case. I’m the original owner, purchased 10/22/24.
NOTE - I also have a Leofoto LB-75S drop in leveling base that I purchased separately made specifically for this tripod. You would not need this leveling base if using the tripod in the 75mm bowl configuration but this leveling base will allow you to quickly level the tripod with flat base tripod heads. Pricing below with and without this drop in leveling base or just the leveling base by itself.
Pictured below in 75mm Bowl Configuration with a Sachtler fluid head (not included), flat base configuration and flat base configuration with LB-75S drop in leveling base.
LM-324CLX retails for $540
LB-75S Leveling Base retails for $110
$345 for just the tripod with 75mm bowl & standard flat plate configurations.
$395 for the tripod with 75mm bowl, standard flat Plate and LB-75S drop in leveling base configurations
$60 for just the Leofoto LB-75S drop in leveling base but PLEASE BE AWARE that this drop in leveling base is ONLY compatible with Leofoto LM Summit Series and Leofoto LN Mountain series 75mm bowl tripods.
Prices above include shipping to the lower 48.
Check out Hudson Henry's YT site. He is a big fan of this tripod!
Please refer to the product links below for additional spec information.
