processing film negatives...
jimmuller
p.1 #1processing film negatives...
First, just a comment. I need to find a way to keep film clean when scanning. No matter how hard I try, a piece or dust or something manages to show up. Maybe I need to try harder.
Now the real question. I saw an article about a "new" program called FreeCCR to convert scanned negatives. Have any of you tried it? I did and immediately had a problem. It was larger than my computer monitor and wouldn't let me resize it any smaller. This problem showed up on versions for both Windows and Linux.
It processes reasonably fast. However the colors don't look natural, too green/blue for the few pics I tried. It was touted as using "physics-based" conversion. It didn't work for me. But maybe I missed something. Any of you tried it? Oh, I asked that already.
Thanks.
Jul 09, 2026 at 11:22 AM
bwcolor
Details
p.1 #2processing film negatives...
A dust free environment requires isolated film developing and scanning environments with high quality filtering and humidity control. So, what is your budget? Short of that, isolated film drying with air hepa-filtration and a bit of humidity. I’ve added ion generators. Then immediate sleeving, or copying. Many copy setups can include brushes before entering the film holder. I use Negative Supply gear. Canned air can be used prior to scanning. Beyond that further isolation and ultra clean rooms with hepa vacuums..etc. Short of that, I accept a limited degree of dust.
Jul 09, 2026 at 11:29 AM
retrofocus
Details
p.1 #3processing film negatives...
In a standard home environment, there will be always some little dust flakes creeping in no matter how good you try to control it. For drying film, I always pick either a closed bathroom where I run the shower for 10 minutes before hanging the film strip to dry. This method reduces dust stuck on the film significantly. Other option is an area where not much air movement occurs. In my case this is my finished basement where I can also dry my film nearly dust-free.
Before digitizing, I blow air onto both negative surfaces with a rocket blower. With scanners, film dust removal via IR scan is a good method to automatically remove dust bunnies - which only works for color negatives. For B&W negatives, I need to manually remove them in post processing. Therefore it is best to start scanning with the most dust-free negative as possible to obtain.
What I found not being of any help is using wetting agents as last step in the film development process itself. It did not change the amount of dust on my negatives but only created streaks on the negatives after the water evaporated hard to remove in post processing.
Dust remains one of the most annoying effects both in film and digital photography. For digital it is dust built-up on the sensor and required removal, for film it is dust on the negative. And if you are really "lucky", you get it from both if you digitize your negative with a digital camera .
Jul 09, 2026 at 12:54 PM
rji2goleez
Details
p.1 #4processing film negatives...
I guess I've been pretty fortunate. My developed film hangs in a bathroom to dry. Fans off, tiled environment. I try to scan as soon as it's dry but I do that in my home office. I don't do anything special but the carpet is very low profile so little to stir up. Somewhere between bwcolor's suggestions and my fortunate 'do nothing' approach is probably the sweet spot.
Jul 09, 2026 at 01:17 PM
johnvanr
Details
p.1 #5processing film negatives...
Same here. Film dries in bathroom and I scan quickly. No carpets or carpeting in the rooms where the film goes (not that I planned it that way, it's just the way it is). 35mm is scanned in the Valoi setup with a brush cleaning the film as it goes in and 120 I just blow the dust off as I load the film in the Negative Supply Carrier. Bit of dust here and there, but nothing that can't be quickly removed. Some of my digital files (I'm talking Leica M here) are worse unless I stay on top of my sensor cleaning.
Jul 09, 2026 at 01:32 PM
jimmuller
Details
p.1 #6processing film negatives...
Thanks for all the comments. I have my film developed in a lab so hanging it to dry isn't my problem. It's dust when I'm setting up for a scan. I try to blow dust off but sometimes I forget. I don't notice dust until I've scanned the entire roll and sent them to my computer for viewing like opening up a box of chocolates to see what goodies it contains. I don't have a dust free environment. Fortunately nothing I do in film is so demanding that it's a serious problem. If dust ruins the scan of a pic I really want I can always re-do it. Or try to edit it away, but I haven't quite figured how to do that with the tools at my disposal.
Anyone tried FreeCCR yet?
Jul 09, 2026 at 01:43 PM
johnvanr
Details
p.1 #7processing film negatives...
...Show more →
Not tried FreeCCR and I’m not about to either. I use Negative Lab Pro and I’m happy enough with it to not want to spend any time looking at alternatives.
Jul 09, 2026 at 02:05 PM
rji2goleez
Details
p.1 #8processing film negatives...
...Show more →
I have better luck with dust on the negatives I develop vs what comes back from the lab. It's sometimes amazing how much dust is on the negatives that are in sleeves and then in an envelope where as the negatives developed at home are dust free.
Jul 09, 2026 at 02:14 PM
bwcolor
Details
p.1 #9processing film negatives...
...Show more →
I’ve had labs that specialized in dust covered negatives.
Jul 09, 2026 at 02:17 PM
James Markus
Details
p.1 #10processing film negatives...
...Show more →
I've used this before - particularly when the film is in an Epson flat bed scanner frame.
Just lightly drag it over both sides one time.
Amazon lnk
Jul 10, 2026 at 09:15 AM
Ayoul
Details
p.1 #11processing film negatives...
Hi. I tried FreeCCR this past few days and it's a very nice software, it looks a little bit like the negadoctor workflow.
I don't see any greenish or bluish cast on my scans. You didn't forget to set the white point ? I don't put it on a totally burned part of the film but on the "whitest" point possible of the roll : some white tissue exposed to the right, a car that was probably white, this kind of thing.
This software looks very promising to me.
Jul 15, 2026 at 08:01 AM
Queso_Grandee
Details
p.1 #12processing film negatives...
Have you taken a look at NegPy? It's a newer free program that works pretty well. I typically use NLP but I've been testing this new software out. It seems really promising.
Jul 17, 2026 at 10:44 PM
jimmuller
Details
p.1 #13processing film negatives...
I just tried the Linux App. I get "Incompatible processor. Core dumped" and something about a wrong Qt version. I'm trying to move completely away from Windows so I refuse to try the Windows version. To answer your question, I tried it but didn't literally look at it because it wouldn't let me. At this point it's not worth the trouble to chase down. But thanks for the suggestion.
Jul 18, 2026 at 04:14 AM
Queso_Grandee
Details
p.1 #14processing film negatives...
jimmuller wrote:
Queso_Grandee wroteHave you taken a look at NegPy? It's a newer free program that works pretty well. I typically use NLP but I've been testing this new software out. It seems really promising.
Oh wow, I'd suggest reaching out to him via Reddit and let him know. Im sure he can help fix it for you and others. NLP is also another option if you can install LrC on Linux.
Jul 18, 2026 at 07:05 AM
James Markus
Details
p.1 #15processing film negatives...
...Show more →
Jim, I'm getting wacked colors out of the linux based FreeCCR. There must be some variable that is not being taken into account. I also got different responsiveness based on platform. Ubuntu MATE 26.04 was slow, and MX Linux (Trixie) was the most responsive. The output looked better in the app/OS. I don't know what color space FreeCCR uses, but I could not get the same tones or contrast as the usual suspects. That is my guess what is going on. First is win11>Lr>NLP>Ps, Second is MX Linux 25.2 Kernal 7.0.14-2>Export to 16bit tif
Canon-EOS-1_Portra-160-Cinestill-C-41-4min-102-degrees
Jul 20, 2026 at 11:34 AM
jimmuller
Details
p.1 #16processing film negatives...
Thanks for the report. It confirms my impression that FreeCCR s not quite ready for prime-time TV. Maybe the developer is still fixin' it. If I had been able to resize it to my screen so I could have access to the controls I might have worked it to see what I'd done wrong. As it was it was just too much trouble. FilmScanConverter, written in Python, seems to work just fine. Until I find something better I have no reason to look for something better, if you take my meanin'.
On a different note, I put more film into the F today. I actually like the feel of the Nikkormat FTn better but I'm doing this for fun anyway.
Jul 20, 2026 at 12:06 PM
mskad2
Details
p.1 #17processing film negatives...
Thanks for the tip. I didn't know about this one and so far I like it very much. The UI and workflow are very intuitive and the quality of the automatic conversion is so far the best of all dedicated software that I tried.
Jul 20, 2026 at 07:46 PM
Desmolicious
Details
p.1 #18processing film negatives...
jimmuller wrote:
James Markus wroteJim, I'm getting wacked colors out of the linux based FreeCCR. There must be some variable that is not being taken into account.
Nikkormats are really solid cameras. Nothing cheap or budget feeling about them at all.
Jul 20, 2026 at 08:33 PM
James Markus
Details
p.1 #19processing film negatives...
Ditto. Didn't know about this one (it is only at v0.4), but is extremely fast, and on the default the conversions weren't bad.
Jul 20, 2026 at 08:52 PM
jimmuller
Details
p.1 #20processing film negatives...
FWIW, I tried NegPy on Windows11 with an image that was problematic because of its color content. With NegPy's default settings it produced a nice result. I glanced at the documentation (hard to find on github - and did I ever mention how much I hate github? it was written by people trying to find counterintuitive ways to organize and name things) but I didn't spend any time trying the rest of the tool sequences. Since it won't run on my Linux processor that would be a waste of time.
Jul 21, 2026 at 08:24 AM
FM ForumsFilm Is Not Dead ForumJoin Upload & Sell
Switch to mobile view
