Sold: YC Onion Pineta Pro Carbon Fiber Monopod + Desmond DMH-2 Arca head
nmerc_photos
p.1 #1 · Sold: YC Onion Pineta Pro Carbon Fiber Monopod + Desmond DMH-2 Arca head
Price: $350.00
Selling my YC Onion Pineta Pro monopod with quick adjust feet, and Desmond DMH-2 arca swiss compatible head.
Purchased just about a year ago. Have only used less than 10 times. I shoot handheld 99% of the time.
MSRP is $508. I'll take $350. Price is net to me, I will cover shipping and insurance in the CONUS.
Set Screw to Prevent Deflection: 39mm carbon fiber tube. Anti-deflection screw on the top quick-release plate to enhance the stability of the equipment installed. *Max payload with a gimbal: 5kg
Versatile Support Legs Two Adjustable Angles: The support legs adopt semi-auto angle adjustment. Steep angle for passing through narrow aisles; Folded in reverse to adapt to various complex terrains such as sand, mud, gravel, etc.
Extended Legs for Enhanced Stability: The support legs have been extended from the original 160mm to 212mm, making the support area larger and more stable.
2-in-1 Screw: Press spring structure design. The screw size can be switched between 1/4” & 3/8”.
Quick Release System with Full Security: Press the 2 PUSH buttons and lift to remove the top plate. Deep internal travel to avoid sudden pop-ups. Simply snap the top plate back on without pressing the PUSH buttons.
One-Click Safety Lock: Push down to lock the trigger, ensuring safety at all times; One Press to Get Low-Shot Angle: Simply snap the top plate on the base to put your gear in place.
May 28, 2026 at 10:27 AM
