What's in the future for the Sony A7Cr II?
rhawidantas
p.1 #1 · What's in the future for the Sony A7Cr II?
I know that the not all of the reviews are even out yet for the latest camera.
But I was thinking that it could be fun to speculate, or suggest if someone from Sony is reading this, any improvements that we would like to see for the next version of the A7Cr.
The sensor gains that we have been seeing, like higher dynamic range and ISO performance are of course a given and it's also the increase in the number of autofocus points, real-time AF and pre-capture.
Body-wise, I would like to see the implementation of the new and better battery, which would increase the size of the grip a little bit. I hope they keep the same overall size.
I would like to see the implementation of this screen also ported to the A7Cr.
A viewfinder there that it's a little bit bigger and with better resolution would help but it's not a deal breaker for me.
Buttons are a little bit moushy and I would like to see that updated as well.
What you guys have in mind?
May 18, 2026 at 07:15 AM
EB-1
p.1 #2 · What's in the future for the Sony A7Cr II?
If they really want to keep it small the current battery would be used. Does a CrII need the 30 FPS and CFe?
It could take 3-4 years to replace all models with the new batteries, so I'm not sure they will universally.
May 18, 2026 at 07:44 AM
campy
p.1 #3 · What's in the future for the Sony A7Cr II?
Drop the price by $1000 with minor improvements would be enough for me.
May 18, 2026 at 08:02 AM
Rialto
p.1 #4 · What's in the future for the Sony A7Cr II?
To me, the C-line body needs a joystick, 4-axis flip screen, and better EVF to become attractive. Illuminated buttons would be a nice bonus.
Features nice to have but aren't dealbreakers for me: dedicated white balance sensor, CFe A slot, and mechanical front curtain (was a dealbreaker to a7CR, but if CR II uses the 66.8 MP sensor, ES will be tolerable).
Aesthetically, it'll be cool to have a white version.
May 18, 2026 at 08:55 AM
patotts
p.1 #5 · What's in the future for the Sony A7Cr II?
I don't think they'll improve the EVF, the LCD, buttons or pads -- then there is little reason to buy the more expensive a7R VI. I'm not sure they will actually update all models with the newer battery, at least not the more compact models.
May 18, 2026 at 02:54 PM
chez
p.1 #6 · What's in the future for the Sony A7Cr II?
Yep, no need for the 30fps nor the CFe.
May 18, 2026 at 03:16 PM
Yogifi
p.1 #7 · What's in the future for the Sony A7Cr II?
It needs to be a big update for me to upgrade, otherwise I'm happy to hang onto the a7cii.
I'd like it to be 1cm thinner, can be a little taller but I'm also happy to keep using the bottom plate from an L-bracket.
If they can get it in there then a larger lcd with higher density and to flip up smoothly without having to go to the side.
More natural colours and improved profiles.
Focus confirmation with manual focus lenses.
The ISO wheel skips randomly, I have to disable it else it switches from auto.
Higher resolution evf, bit bigger, with something to easily attach to block sunlight if needed.
Would be great to solve efcs issues, higher mechanical shutter speed.
Better battery life.
More premium feeling build, less like it's made of recyclable goods.
No crop 4k.
It could be the a7ciii changes and it wouldn't change much on my end.
It's the only stuff I really care about at the moment, more resolution isn't something I personally need.
I expect I won't get much of anything I actually want and they'll just upgrade the sensors 🤷‍♂️
With other high-end gadgets, we get more without the size increasing, usually it decreases.
With cameras I feel like they keep just getting bigger. Are we heading back to DSLR sizes?
May 18, 2026 at 03:21 PM
yongliu
p.1 #8 · What's in the future for the Sony A7Cr II?
Just make either the EVF or the screen usable at day time, even at the cost of removing one of them, with whatever other downgrade required, shorter battery life for example.
I bought the A7Cii again recently, just to find that it's still such a pain to frame for my eyes; thinking of selling it again.
May 22, 2026 at 06:37 PM
Juha Kannisto
p.1 #9 · What's in the future for the Sony A7Cr II?
I'll probably get an A7C3 when available as my next camera after A7C2. I would expect the A7V sensor and in general most new features from A7V including the improved battery efficiency. I would welcome EVF improvements such as bigger panel and/or higher magnification if they can do it without a noticeable negative size impact + better screen but I don't really need a 4-way tilting screen esp. if it protrudes more. I'd prefer the same current battery since it's already fine and I have a few of those. Removing the EVF would be a very bad idea and would stop me from getting the camera.
I'd like a "joystick" like the other A7 series have in place of the AF-ON button. A feature that would allow registering names / FL / aperture info etc. for adapted lenses would be nice. Manual focusing aids like Canon and Nikon have as an addition to focus peaking and magnification would be interesting though I'm not really expecting much focus on adapted / manual focus lens supporting features at this point.
It would be very important to keep the size and weight very close to current C models and if it could be made even smaller/lighter without compromising anything important like IBIS it would be a nice bonus.
May 22, 2026 at 06:56 PM
Jeff Kott
p.1 #10 · What's in the future for the Sony A7Cr II?
Don’t get rid of the AF-ON button!!!!
May 23, 2026 at 10:40 AM
MMP
p.1 #11 · What's in the future for the Sony A7Cr II?
A joystick button would be a major functionality upgrade for me. That was one of my main frustrations with the A7Cr.
May 23, 2026 at 01:25 PM
Lukacs
p.1 #12 · What's in the future for the Sony A7Cr II?
2.3M dot tilting screen, 3.6M dot EVF, new sensor, joystick instead the wheel. 28 1.8G and 50 1.8G lens in size and optical performance of 20 1.8G.
Just kidding, Leica pay a decent amount for Sony not cannibalising Q3.
May 23, 2026 at 01:47 PM
bwcolor
p.1 #13 · What's in the future for the Sony A7Cr II?
Each of us compromise to get what we want. I sold my A7Rv to get the small form factor of the A7CR, but regretted the choice. I really couldn’t get over the ten year old EVF tech when compared with the A7Rv. This time around, I sold the A7CR and put an order in for the A7Rvi. A sufficiently improved EVF is unlikely. For everyone’s sake, I hope that I’m wrong.
May 23, 2026 at 02:12 PM
danster_red
p.1 #14 · What's in the future for the Sony A7Cr II?
I'm on the fence between a CR and RV, but realize waiting might be better
Oct 19, 2026 at 09:31 AM
gdanmitchell
p.1 #15 · What's in the future for the Sony A7Cr II?
Dream on. ;-)
Responding to another post, I’d rather see battery consistency across the line-up, even at the cost of a small size increase.
Of course, there are always trade-offs when it comes to controlling camera size and weight. Adding extra controls, fancier screens, etc. all potentially add size/weight… and cost.
Oct 19, 2026 at 09:37 AM
Craig Gillette
p.1 #16 · What's in the future for the Sony A7Cr II?
I think the "evf" is the most mentioned negative for the A6XXXs and A7Cs. I don't know how close they are to the "edge" with "fitting" changes in and not driving size up. I remember as a "boxboy" bagging groceries a few times being asked to "Get it all in one bag but don't make it too heavy."
My guess is a faster sensor/processor to deal with "rolling shutter" could require more battery oomph and generate more heat. A mechanical shutter might be hard to squeeze in as might rear panel changes or improved evf.
Using a detachable plate allows for adding/reducing height some and may help with heat dispersion. I think better evf (and an eye cup) are the changes, I'd like to see.
Making it an A7Rvi with the hump moved to the left upper corner is, well, an A7Rvi with a moved hump.
I'd maybe prefer improving the evf and adding the new sensor, mechanical shutter, accepting frame rate limitations and similar "detuning" to not force battery size or physical dimensions up to deal with heat.
Oct 19, 2026 at 10:58 AM
Geekapoo
p.1 #17 · What's in the future for the Sony A7Cr II?
No EVF upgrade = no upgrade by me, makes any other change irrelevant.
Oct 19, 2026 at 02:58 PM
gdanmitchell
p.1 #18 · What's in the future for the Sony A7Cr II?
Another bit of context comes to mind after reading this post and a few others in the thread: Expecting each new iteration of a camera model line to be significant enough to warrant getting rid fo the previous model may be setting unrealistic expectations.
The upgrade from v.1 of a thing to v.2 is often relatively incremental. It is impossible to make every version upgrade present “orders of magnitude” improvements.
Incremental upgrading is a good thing. It keeps products improving, and over the longer term (maybe 2 or 3 upgrade cycles?) the changes become significant to previous owners.
In any case, upgrading an EVF would be a pretty easy thing for Sony to do. It would not have to increase weight or bulk and would likely not cost them that much more since technology has improved.
But how many owners of the existing model would scrap the current camera for a somewhat improved EVF?
Oct 19, 2026 at 03:29 PM
Geekapoo
p.1 #19 · What's in the future for the Sony A7Cr II?
Well, obviously you have my vote..I'd upgrade! I've always valued an EVF, for me it's part of the enjoyment of the process and greatly aids my composing the shots. Just as important, it's been brutal switching from use of my A1 II or previous models A7RIV and A7RV to an A7CR, A7CII or A6700..all mediocre EVF in comparison..
Oct 19, 2026 at 03:38 PM
Jack Flesher
p.1 #20 · What's in the future for the Sony A7Cr II?
If they improve the EVF, the camera body will likely have to be a bit larger to accommodate that. Adapt it for the new A7R6 battery and the grip are definitely has to be larger. These two changes will likely result in a camera now only marginally smaller and lighter than the A7R6. As an owner of both, I can tell you if the A7CII/R get any larger in the next iteration, there will be zero reason to own one over the A7R6 other than entry cost.
As it is, given the relatively small differences in size and weight at the cost of sub-par EVF, lesser battery life, only one SD card slot, poorer AF and a bit smaller file size compared the A7R6, I am questioning my keeping the A7CR. The only reason I have so far is it is somewhat smaller being carried than the A7R6, it doesn’t look like a pro camera and I think it looks cool (at least in silver) and the files are still quite excellent; and I admit to still enjoying using it for casual “walk around” imaging with a small prime mounted. For those reasons it’s still around, but maybe not for long…
Oct 19, 2026 at 03:45 PM
