Sold: FLM CP30-L4 II Tripod
Cduff406
p.1 #1 · Sold: FLM CP30-L4 II Tripod
     FLM CP30-L4 II
Price: $400.00
Shipping instructions: Will ship USPS
Continuing my downsizing project, I am going to part ways with my FLM CP30-L4 II tripod. I uses this primarily as a second tripod and as my hiking tripod. It's in great shape and works flawlessly. I can't find any marks on it at all, but it has been used so there are probably some handling marks on it somewhere. It's a great, stable tripod. I'm just thinning the tripod herd around here...
Here are all the specs straight from the FLM website:
The FLM CP30-L4 II 10X Carbon Fiber Series II Tripod is a 4-section support with a twist leg system. With a simple half-turn, you disengage the leg locks, which enables you to extend the legs for the tripod to reach its maximum height of 68.3". To shoot close to the ground, you can collapse the legs to have a minimum height 3.6" and a folded length of 23". This strong and durable tripod has a load capacity of 44.1 lbs, and it only weighs 3.1 lbs, making it easy to carry to any location.
Additional information
Materials
Aluminum Alloy, Carbon Fiber
Folded Length
23" / 58.42 cm
Load Capacity
44.1 lb / 20.00 kg
Maximum Working Height
68.3" / 173.5 cm
Minimum Working Height
3.6 in / 9.1 cm
Weight
3.1 lb / 1.41 kg
Leg Lock Type
Twist Lock
Leg Sections
4
Tube Diameter
1.18 in / 30 mm (Maximum)
Foot Features
Removable, Rubber, Spiked
Tripod - not extended
Tripod apex
Tripod top plate
Tripod feet
May 15, 2026 at 05:45 PM
nguyenhm16
p.1 #2 · Sold: FLM CP30-L4 II Tripod
PM sent
Jun 02, 2026 at 09:14 PM
