p.1 #1 · Withdrawn: Like new Tamron X-mounted 150-500mm lens
Tamron 150-500mm f/5-6.7 Di III VC VXD Lens (FUJIFILM X)
Withdrawn
Price: $900.00 Payment method: PayPal Item condition: 9+ Shows little or no signs of wear Shipping instructions: Shipping will be split 50/50, coming from Thailand
I bought this before heading to Africa for two years. I used it on a few safaris but then plans changed after just 4 months. I’ve been carrying it around for about a year now and as nomad, it’s too heavy to keep carrying.
It’s basically new and has barely been used. However, the screw has been bent ever so slightly.
Comes with a Hoya alpha II UV Protector 82mm, lens caps (front &back), lens hood, and arca-type tripod foot.
Specs:
Focal Length
150 to 500mm (35mm Equivalent: 225 to 750mm)
Aperture
Maximum: f/5 to 6.7
Minimum: f/22 to 32
Lens Mount
FUJIFILM X
Lens Format Coverage
APS-C
Angle of View
16° 25' to 4° 57'
Minimum Focus Distance
23.6" / 60 cm
Magnification
1:3.1 Macro Reproduction Ratio
0.32x Magnification
Optical Design
25 Elements in 16 Groups
Aperture/Iris Blades
7, Rounded
Focus Type
Autofocus
Image Stabilization
Yes
Tripod Mounting
Removable and Rotating Collar
Filter Size
82 mm (Front)
Dimensions
ø: 3.7 x L: 8.3" / ø: 93 x L: 209.9 mm
Weight
3.77 lb / 1.71 kg
Lens full view
Lens from front, you can see the slightly bent screw
