How is your hand holding technique?
big country
p.1 #1 · How is your hand holding technique?
Handholding technique of a lens is just as important as your AF setup and exposure. out in the field I see so many people that hold their lenses in the least efficient way, ways that work against them. When the light is dropping, you have no choice but to reduce your shutter speed, and your hand holding technique is critical.
Here is a male tiger, his face is lacerated and bloodied from a fight with another male. The sun was dropping, and yes I know with the R1 i can push that camera to the limits with high iso, but with a good hand holding technique, you don't have to do that until it gets really dark.
Canon R1 + RF 600 4.0 + RF 1.4x @840mm
1/100 | f/5.6 | ISO 4000 Handheld
Apr 18, 2026 at 01:36 AM
Dilemma
p.1 #2 · How is your hand holding technique?
Good I'd say. Elbows tucked in against my side, viewfinder pressed against my brow. Works for me.
Apr 18, 2026 at 10:22 AM
big country
p.1 #3 · How is your hand holding technique?
when it gets dark, you gotta go lower, here is 1/20 shutter speed with the R1 and 600mm f/4. ISO is 10,000
Apr 18, 2026 at 10:47 AM
chez
p.1 #4 · How is your hand holding technique?
It isn’t the sharp photos that only count…but the one’s that did not make the cut because of the slower shutter speed. I have no issues with increasing the shutter slightly to ensure the image is sharp with today’s sensors and software.
Apr 18, 2026 at 10:56 AM
big country
p.1 #5 · How is your hand holding technique?
There is a line somewhere on how far noise reduction will go.
The first image at 1/100 i got plenty of sharp photos.
The second shot was basically in the dark. i did get a decent number of "sharp" photos at 1/20.
Software is one thing, technique is everything.
Apr 18, 2026 at 02:13 PM
Imagemaster
p.1 #6 · How is your hand holding technique?
Software is one thing, technique is one thing, gear is one thing, and subject movement is one thing.
Monopod is better than handheld, and tripod is better than monopod.
Apr 18, 2026 at 02:58 PM
Mike_5D
p.1 #7 · How is your hand holding technique?
I guess mine's ok. I've done 1.0-0.5sec at 24 mm with OIS+IBIS, but there's no way I'm holding a 600 f/4 steady for 1/20 sec without some support.
Apr 18, 2026 at 04:39 PM
chuck4242
p.1 #8 · How is your hand holding technique?
In low light my left elbow is pressed against myself mid-torso and my right elbow is tacked against my side. Less flailing around and I can get into the 1/50 shutter speed range.
Apr 18, 2026 at 04:46 PM
Gochugogi
p.1 #9 · How is your hand holding technique?
I usually interlock fingers so I don't lose them in a crowd.
Apr 18, 2026 at 06:25 PM
artsupreme
p.1 #10 · How is your hand holding technique?
Practice makes perfect.
Apr 18, 2026 at 10:10 PM
EB-1
p.1 #11 · How is your hand holding technique?
For big teles on safari vehicles I usually use a beanbag or monopod, then hand hold as a last resort. I am likely to brace on the vehicle to help support and also to improve composition accuracy. ES mode along with a high framing rate also helps in really marginal conditions. The more you shoot the greater the chances if only a small percentage are free from subject movement and have the DOF at low speeds.
The combination of lens IS and IBID has improved handholdability quite a bit in the MILS era.
Apr 19, 2026 at 12:11 AM
Z250SA
p.1 #12 · How is your hand holding technique?
Though I usually try to avoid getting overwhelmed by the number of shots, but in low light I up the fps as far as it goes with the shutterspeeds available. Often there is a lucky one or two in a series.
I guess rifle shooting techniques helps some too, sync with breathing and hearbeat, shoot when steady.
Apr 19, 2026 at 03:59 AM
Sy Sez
p.1 #13 · How is your hand holding technique?
How to test your hand-holding ability, or lack thereof.
With a 400-500mm lens attached, set your camera to Spot AF, pick a small target in the distance, and see how steady you can hold the Spot AF square on the target with no movement.
Apr 20, 2026 at 09:27 AM
EB-1
p.1 #14 · How is your hand holding technique?
That measures the compostion. You could use a resolution chart to check for IS/IBID effectiveness.
Apr 20, 2026 at 10:19 AM
Mike Deep
p.1 #15 · How is your hand holding technique?
My hand-holding technique was pretty good. I could reliably break the reciprocal rule by a stop without IS or support equipment.
Post-coma my technique is awful. The left arm trembles however and whenever it wants to. Only IS saves my bacon with telephoto shooting.
Apr 23, 2026 at 08:40 PM
Uarctos
p.1 #16 · How is your hand holding technique?
Much easier to shoot at lower shutter speeds with a mirrorless in ES, than with a DSLR. I can shoot at 1/20-1/30s with a DSLR at 600mm.
Apr 23, 2026 at 11:32 PM
rscheffler
p.1 #17 · How is your hand holding technique?
AND press the magnification button twice for maximum EVF magnification. I did this yesterday with the 70-200/2.8 Z at 200mm with maximum magnification to view some things very far away. For example, an airliner on approach probably several km away filled the entire 'square' of the magnified focus point. Once IS/IBIS stabilized it was possible to keep it within the square but did require some concentration to minimize vibrations/movement. So far, the 70-200Z is the best IS/IBIS stabilization combo I've yet tried for RF mount.
I definitely rely on IS/IBIS. My other system does not use it and I very much miss it when I use that system!
Apr 26, 2026 at 03:52 AM
Tom_W
p.1 #18 · How is your hand holding technique?
I managed to take a few 1/4 second shots of the most recent eclipse a couple of months back with my R5 and the 200-800 lens. I was around 500 mm and was able to get 'some' good shots. I cheated and leaned on the back of the Applebee's restaurant building that was out in front of my hotel.
I couldn't hold steady enough at the full 800 mm focal length, but was able to do reasonably well at 500.
Apr 26, 2026 at 08:33 PM
