New background?
grandmas
p.1 #1 · New background?
I didn't like the background, did I do too much?
Jan 13, 2026 at 08:37 PM
Shasoc
p.1 #2 · New background?
It works for me. Personally I like dark BG as makes the subject more powerful. I would even push it further, but it doesn't need to.
BTW,you can also eliminate some of the BG using a vertical crop.
The only thing I see is some light halos on the left petal. Probably some reminiscence of the original BG?
Beautiful flower, I like the vivid colors. May be do some dodging/burning on the flower to create more depth?
Socrate
Jan 13, 2026 at 10:42 PM
grandmas
p.1 #3 · New background?
Thanks for the comments. It is a work in progress, but I thought I might have gone too far. I am not seeing the halos could you be more specific?
Jan 14, 2026 at 01:38 PM
Shasoc
p.1 #4 · New background?
I called "halos" because I couldn't find a better word. Bu, as I said might be part of the original BG.
It shows better on a computer. I have noticed that images posted on FM get darkened a bit.
Socrate
Jan 14, 2026 at 02:49 PM
grandmas
p.1 #5 · New background?
Here is the original file cropped. I think what you are seeing is natural.
I didn't replace the background I did this in several layers and did some curves and dodging and burning. I plan to redo the image and be a little more careful. Just replacing the background didn't give me the look I was going for.
Jan 14, 2026 at 03:50 PM
Camperjim
p.1 #6 · New background?
I like the black background. Use of flash can make that much easier with even better results.
Jan 15, 2026 at 07:00 AM
grandmas
p.1 #7 · New background?
You are right! A few years ago I used to use a flash with a fast shutter to get this look, and don't know why I quit.
Jan 15, 2026 at 01:32 PM
ichiboy
p.1 #8 · New background?
If you have the ability to be there at an ideal time, I think isolating through light would be the ideal way of creating the effect.
Jan 29, 2026 at 05:54 PM
