       2       3       …       6       7       end
Canon RF 45mm f/1.2
JohnDizzo15
p.1 #1 · Canon RF 45mm f/1.2
Didn't see a dedicated thread, so starting one for image and thought sharing.
Just received mine earlier this evening from B&H. No real chance to shoot yet, but did take a couple of snapshots just to test out. Also outfitted it with a Haoge square metal hood, as currently, I'm still unwilling to buy the OEM hood out of principle.
Lens feels nice in hand, super light as advertised, compact for a 1.2, AF speed is definitely leisurely but fine if not needing to rack from MFD to infinity or vice versa.
Canon RF 45/1.2 by John Dizzo, on Flickr
Standard color profile applied in LR with lens correction profile enabled
RF 45 w/ profile corrections by John Dizzo, on Flickr
Off-center test. Still plenty sharp enough for my taste.
Lens correction profile off
Dec 04, 2025 at 10:46 PM
absolutic
p.1 #2 · Canon RF 45mm f/1.2
after I read all the negative reviews about it being not very sharp, I am pleasantly surprised. Granted I am using the 45 on the 24MP R8, I don't currently have R5M2 anymore, so I can't tell how it resolves 45mp, but on my 24MP it looks fine. Interestingly I received Nikon 40mm F2. for Z mount at the same time and tested that lens. I was shocked how soft that 40mm Nikkor was on my 24MP Z6III. I have not seen lenses that soft for a long long long time. The 45 1.2 on the other hand is a keeper for me.
45 1.2 RF by Dmitry Brodsky, on Flickr
Dec 05, 2025 at 12:01 AM
artsupreme
p.1 #3 · Canon RF 45mm f/1.2
https://live.staticflickr.com/65535/54964647978_967c5eeaf3_b.jpgCanon RF 45/1.2 by John Dizzo, on Flickr
...Show more →
Looks good. I'm liking the uncorrected versions of this latest batch of Canon RF lenses. That harsh vignetting can be cleaned up a bit with some inverted radial masks.
I think this lens is going to be very popular.
Dec 05, 2025 at 12:22 AM
rscheffler
p.1 #4 · Canon RF 45mm f/1.2
In the R6III and 45/1.2 thread, Gary Voth mentioned he observed quite prominent focus shift in the f/2.8 range at nearer focusing distances. It appears that the best way to counteract this is to set the EVF exposure simulation setting to exposure + DOF. This will force the camera to stop down the lens to the shooting aperture while focusing, which for this lens will be beneficial because it will then compensate for the focus shift that otherwise would affect images if AF was done wide open. From my brief testing of this setting (with a different lens), it appears the camera will AF with a shooting aperture as small as around f/5.0. If set smaller than f/5.0, the camera will open the aperture to around f/5.0 to perform AF and then stop down to the shooting aperture to provide DOF preview once AF is done.
Thanks for posting these. My impression from the DPR sample image gallery was that the lens was decently sharp for its price. Your test photos do reveal bokeh quality that I do not like, which specifically is how the bokeh balls at the image edges are significantly smaller than near the center. With any lens there will be some optical vignetting that affects peripheral bokeh ball size and shape, but it seems to be quite an extreme case for this lens. It will be interesting to see how much is due to optical vignetting and if there is also field curvature compounding the issue.
Dec 05, 2025 at 12:43 AM
Pixelpuffin
p.1 #5 · Canon RF 45mm f/1.2
Not sure why
But I seem to prefer a little vignetting these days??
It occurred to me a while back that when I used lenses without corrections turned on the pictures had a filmic look. At first I couldn’t understand why then realised the vignette was giving a more ….3D pop??
If I turned corrections on the shot just becomes flat.
The 45/1.2 does seem nice… I bet paired with a light weight body like the R8 makes a fantastic combination.
Well done canon 👍🏻
Dec 05, 2025 at 12:50 AM
garyvot
p.1 #6 · Canon RF 45mm f/1.2
Pixelpuffin wrote:
Not sure why
As do many of us. However, assuming you shoot RAW, this is quite easy to add in post, and you can control it so that all lenses receive the same setting if you like.
In ACR/LR, there is an "Effects" adjustment group that includes a Vignette slider. I use lens corrections, but I use this to apply a tasteful vignette as part of my default edits.
Dec 05, 2025 at 02:24 PM
netexpress
p.1 #7 · Canon RF 45mm f/1.2
The bokeh is horrible IMO. I'd like to see an image that goes edge-to-edge. The MTF charges look pretty bad in the corners. I think I'll skip this lens. And I rarely say anything bad about Canon lenses. But a cheap 1.2 prime for portraits? Why not? It still can be a lot of fun!
Dec 05, 2025 at 03:04 PM
philip_pj
p.1 #8 · Canon RF 45mm f/1.2
'If I turned corrections on the shot just becomes flat.'
As a rule, outer frame 'aberrations' are designed to form an image that looks akin to our natural vision. 'Perfect' lenses are themselves an aberration, departing from our natural true-to-life vision. Some supporting evidence from the masters in the cine world:
‘curving focus roll-off creates a dimensionality that has always set M lenses apart from more advanced optics that can be precise to the point of boring.’
‘modern lenses pop into focus in a flat and layered manner that appears unrealistic by drawing attention to themselves.’
‘the M 0.8 lenses roll into focus on a curve that more accurately recreates natural perception.’
‘this creates images that feel different and dimensional, that appear satisfying on a subconscious level.’
That is from Leitz, the others are the same (except Zeiss). We naturally see outer frames (edges of vision) as having lower contrast, lower resolution and a steady decline of brightness. The cine design masters know this.
Will stills photography lens designers get there at some stage? I think they will, after they have exhausted all other possibilities. Give them five years or so.
They are presently lost and wandering around in the high tech desert of their own fever dreams of perfection and endless 'sharpness' - to the neglect of creating lenses that make beautiful artistic images. Once they realize this, they might issue a mea culpa and reform themselves. Don't hold your breath for now, though. They have the rubes just where the marketing department wants them.
Dec 05, 2025 at 06:15 PM
garyvot
p.1 #9 · Canon RF 45mm f/1.2
Having used the lens for a bit, I actually disagree. I've found the bokeh to be better than expected, with fairly smooth OOF rendering. Those cat's-eye highlights are already mostly cleaned up by f/1.6, and there is very little in the way of onion rings or business overall.
And if you look at the MTF comparisons here, you'll see the 45 is actually sharper and more contrasty in the center wide open than was the EF 50L. There is also less longitudinal CA evident in my copy than was my experience with the EF 50L.
It won't be for everyone. Yes, the corners are poor, probably even stopped down. This is not a landscape lens, but I think it punches above its weight for what it is likely to be used for.
The good news is that Canon has at least two world-class 50mm lenses to choose from, if this lens is too much compromise.
Dec 05, 2025 at 06:23 PM
JohnDizzo15
p.1 #10 · Canon RF 45mm f/1.2
...Show more →
Even on the R5ii, it looks sharp enough relative to what my expectations were going into it. Surprised to hear how soft the Nikkor is.
I too, prefer the uncorrected look for the majority of my lenses and leave corrections off accordingly.
...Show more →
Thank you both for sharing and confirming the fix to mitigate this issue. I've changed the setting but have yet to have much shooting time to test. I should be getting some time tonight though.
I also tend to agree regarding the bokeh quality. The shapes are rather odd. However, I also am one of those weirdos that keeps a stable of old lenses because of their weird bokeh (some Helios 58mm lenses and their 85 for the swirls, Zenitar ME1 for it's square bokeh, etc). Personally though, I care more about how much dimensionality this lens will produce across varying conditions. If it does well in that regard, I will be more forgiving to some of the weird specular highlight shapes.
Pixelpuffin wrote:
Not sure why
Well done canon 👍🏻
Right there with you.
As stated above, I tend to agree with regard to the bokeh shapes, but if this thing ends up yielding images that have a specific look across varying scenes, I'll be plenty happy. I've had all the near perfect lenses and have kept some, but have offloaded many (including the RF 50/1.2) because I just didn't care much for the images.
...Show more →
Agreed. This is one of the reasons I have stuck with the original Sigma 35/1.2 on the Sony side. The MKii, the Viltrox, or GM1.4 just don't yield the same look. Distortion, a touch of field curvature, etc. never killed anyone.
There's a time and a place for modern, more near perfect lenses. But they don't always pump out the images we love most. With regard to the RF45 though, I'm looking forward to finding out where it falls.
Dec 05, 2025 at 06:33 PM
GabrielPhoto
p.1 #11 · Canon RF 45mm f/1.2
I downloaded the files from this review:
Unless I was imagining things, bokeh seems smoother at 1.8 than at 1.2
In fact, at 1.8 I like it better than the 50mm 1.8 and 35mm 1.8 in terms of bokeh.
Intriguing
Dec 05, 2025 at 10:07 PM
garyvot
p.1 #12 · Canon RF 45mm f/1.2
Yes, I have observed this in my copy too. I think even by f/1.6 the bokeh cleans up nicely.
I haven't really looked at it versus the RF 35 f/1.8 IS, but I can say that my copy of that lens has nicer rendering than my old EF 35mm f/2.0 IS, which I count as a significant win at that price point.
Edited on Dec 06, 2025 at 12:01 AM · View previous versions
Dec 05, 2025 at 11:58 PM
Dave C
p.1 #13 · Canon RF 45mm f/1.2
I received mine, today. All I did was take some pet pics in the house, but I like the sharpness, af speed, and light weight. Given how recessed the objective lens is, I’m not sure it really needs a hood. I need more experience in different lighting outdoors, but for me it looks like the value is there.
Dec 05, 2025 at 11:59 PM
garyvot
p.1 #14 · Canon RF 45mm f/1.2
I would agree that the bayonet hood is probably overkill, but I have a 67mm short metal screw in hood that is just perfect. (I keep these permanently mounted to all of the lenses they are suited for, to cut down on size and fiddle factor.)
Dec 06, 2025 at 12:07 AM
netexpress
p.1 #15 · Canon RF 45mm f/1.2
...Show more →
OK - thanks for sharing your experience. Maybe once it comes on sale I'll pick up a copy to try. Might as well since I've bought 99% of Canon's RF lenses so far... They know how to pick my wallet! I'd just really like to see some no compromise lenses for photography from Canon. I know they are still building a system so I'll be patient. They have some excellent lenses so far.
Dec 06, 2025 at 03:25 PM
netexpress
p.1 #16 · Canon RF 45mm f/1.2
...Show more →
You have a point! I might give it a try.
Dec 06, 2025 at 03:26 PM
netexpress
p.1 #17 · Canon RF 45mm f/1.2
Hmmm... Good stuff!
Dec 06, 2025 at 03:28 PM
swldstn
p.1 #18 · Canon RF 45mm f/1.2
...Show more →
Can share which Haoge hood you purchased and where you got it? Thank you.
Dec 06, 2025 at 05:55 PM
JohnDizzo15
p.1 #19 · Canon RF 45mm f/1.2
Intriguing
Very interesting. Thanks for the find and share! Quick test to see on my end.
1.2
0P7A4464 by John Dizzo, on Flickr
1.4
0P7A4466 by John Dizzo, on Flickr
1.6
0P7A4468 by John Dizzo, on Flickr
1.8
0P7A4469 by John Dizzo, on Flickr
2.0
0P7A4472 by John Dizzo, on Flickr
Agreed regarding the old 35 IS. Was never a fan.
This is the one I have. Can't speak for the other member though. I recently realized that they sometimes make dedicated bayonet versions for specific lenses and hope that they might do one for the RF45 at some point. I just picked one of those up for my GM 24 on the Sony side, and its very nice.
https://www.amazon.com/Haoge-Voigtlander-Panasonic-Fujifilm-Olympus/dp/B07D8ZD2VP
Couple shots from last night.
Dec 06, 2025 at 06:41 PM
GabrielPhoto
p.1 #20 · Canon RF 45mm f/1.2
Can you do the same with foliage or similar backdrop that usually gets very nervous at 1.2 with that 45mm lens?
I want to see how soon it starts getting smoother like is it at 1.8m or even earlier?
Thanks!
1.2
https://live.staticflickr.com/65535/54968239034_917af1079f_b.jpg0P7A4464 by John Dizzo, on Flickr
1.4
https://live.staticflickr.com/65535/54967078387_cfc8656d74_b.jpg0P7A4466 by John Dizzo, on Flickr
1.6
https://live.staticflickr.com/65535/54968229174_6f15570812_b.jpg0P7A4468 by John Dizzo, on Flickr
1.8
https://live.staticflickr.com/65535/54968275550_9837f8280c_b.jpg0P7A4469 by John Dizzo, on Flickr
2.0
https://live.staticflickr.com/65535/54968229204_6a038bfbd9_b.jpg0P7A4472 by John Dizzo, on Flickr
...Show more →
Dec 06, 2025 at 07:57 PM
       2       3       …       6       7       end
       2       3       …       6       7       end
