Nice little tripod for hiking and travel
DaveInHawaii
p.1 #1 · Nice little tripod for hiking and travel
Hi,
I'm really happy with this Oben CQL-13 Compact Carbon Fiber Travel Tripod with Ball Head from B&H.
https://www.bhphotovideo.com/c/product/1765443-REG/oben_cql_13_compact_carbon_fiber.html
It's small enough to fit in one of my water bottle holders on my pack and light enough to not really notice.
Quality seems pretty good.
Dave
Aug 15, 2025 at 07:13 PM
EB-1
p.1 #2 · Nice little tripod for hiking and travel
Interesting, but the leg angle looks really narrow. Does it go a bit wider or is that the upper leg stop?
Aug 15, 2025 at 07:15 PM
DaveInHawaii
p.1 #3 · Nice little tripod for hiking and travel
Good question. I don't recall. There's a lot of times that I have to make it narrower depending the rocks, etc. That could have been the case here.
Aug 15, 2025 at 07:21 PM
tntcorp1
p.1 #4 · Nice little tripod for hiking and travel
21 to 80 degrees leg angles according to bnh link.
Aug 15, 2025 at 10:02 PM
Bobarino
p.1 #5 · Nice little tripod for hiking and travel
That's a valid concern. . . The "effecive leg-angle" becomes even steeper as you raise the column. The 21-degree angle occurs only when the column is down.
..I'd be wary of placing an expensive camera on this type of tripod.. The feet would be yet another factor.
Aug 19, 2025 at 09:36 AM
gdanmitchell
p.1 #6 · Nice little tripod for hiking and travel
I would not use a tripod like that for general photography — I’ll use something bigger and more sturdy that usually doesn’t require me to extend the center column.
However, if you use it prudently it can be a fine solution for things like some hiking and for travel.
Aug 20, 2025 at 04:53 PM
DaveInHawaii
p.1 #7 · Nice little tripod for hiking and travel
I was using a bigger one that weighed a pound more and was longer. A small increase in size and weight made a real difference in packing and lugging up the mountains. If you guys know of something better in this weight and closed length then I’m all ears.
Aug 20, 2025 at 06:36 PM
gdanmitchell
p.1 #8 · Nice little tripod for hiking and travel
I think it all depends on how reliant you are on the tripod, how heavy your camera and lenses are, and what you are willing to sacrifice a bit of weight. As a backpacker myself (for decades) I do understand the lengths folks will go to in order to lighten their packs. (One ultra lite aficionado friend of mine literally files down bumps on the inside of his bear canister to save a few grams, and he makes his own alcohol stokers out of cut up soda cans!)
I think it is possible to get some useful service out of a small and light tripod if you are careful, conditions are pretty good, and you use very light gear — perhaps a smaller APS-C or MFT camera, for example. Downsides are that it may be less easily adjustable, less stable, and you are going to rely on that fully extended center column a lot.
Some will compromise on a larger but not quite as heavy tripod in the backcountry. My “light” tripod is one of the long models of the Gitzo mountaineer series, with a somewhat iighter Acratech Ultimate Ballhead. I sacrifice some ease of control with that ballhead, and the tripod isn’t quite a rock solid as the even larger one I use for non-backpacking photography.
How to balance the trade-offs is up to each person, I’d say.
Aug 20, 2025 at 10:59 PM
DaveInHawaii
p.1 #9 · Nice little tripod for hiking and travel
Thanks, I agree with your earlier message regarding using it prudently. The camera I'm using is a A7CR and the lens I generally use is the 20mm G.
Having it short enough to fit in the water bottle pouch is a huge benefit. The longer tripod had to be strapped on the bottom of my pack and one side would stick out a little further catching bamboo or trees on the trail.
It's a good little tripod. Maybe not perfect, but I'm quite pleased with it.
Aug 21, 2025 at 02:27 AM
Bobarino
p.1 #10 · Nice little tripod for hiking and travel
With any small tripod,, it's important to consider the center of gravity of the load.(camera and lens) The longer and heavier the lens, the more off-balance the load becomes, and the load is no longer evenly distributed to the three legs..
With a tight leg-angle and raised load, you reduce the circle of stability, and increase the possibility of tip-over. Furthermore, as you raise the column, the footprint remains the same, yet the heightened load decreases the "effective" leg-angle.
The "effective" angle is the angle between the vertical centerline, and a new line drawn from the camera center of gravity, to the foot..
Oben unfortunately, does not specify the tripod's column up vs. column down height. They simply show a "working range". If I had that info, I could tell precisely how much lean that tripod could tolerate before tip=over occurs.
Aug 21, 2025 at 11:04 AM
RichP42
p.1 #11 · Nice little tripod for hiking and travel
I am also in the market for a lighter tripod for longer / tougher canoe trips (with lots of portages) so the Oben interests me. Unfortunately it is no longer in stock at B&H and they told me it has been discontinued.
I’ve ordered the Sirui AT-125 that is a pound lighter than my Gitzo. Hopefully it will work for milky way photos.
Richard
Aug 21, 2025 at 01:05 PM
jeffbuzz
p.1 #12 · Nice little tripod for hiking and travel
Those non-serviceable internal leg locks are a no-go for me. Makes the legs disposable. Looks like another rebranding of the Ulanzi Coman Zero.
Aug 24, 2025 at 11:43 AM
xicimummy
p.1 #13 · Nice little tripod for hiking and travel
Thanks for sharing.
Aug 28, 2025 at 09:25 PM
grog13
p.1 #14 · Nice little tripod for hiking and travel
I got one of these for a backpacking trip to Olympic NP last summer, and it performed very well, all things considered. (Used an A7C2 with the 28-60 and Voigtlander 21.) The criticisms of it are valid - obviously it's a seriously compromised tripod. And those leg locks are indeed suspect (but very easy to use!) But I can't think of anything of its weight that would do any better, and can think of many heavier ones that perform worse. I stumbled on to this one a couple weeks before the trip and decided to give it a shot. The pod that would have gone with me otherwise was a glorified tabletop tripod, about 28 inches high with a flimsy screw-on column about as stiff as a fly rod, but only about 3 ounces lighter than this one. At my size, age, and condition, carrying anything heavier on a multi-day backpack is just out of the question.
Sep 08, 2025 at 07:51 PM
jcw1982
p.1 #15 · Nice little tripod for hiking and travel
Thanks for the report Dave. Sounds like you found something that works great for you. I found a Leofoto travel tripod that is similar in size to yours. It's great having such a small lightweight tripod when out in the field. Looks like it works fine for your pictured setup.
Dec 16, 2025 at 07:56 PM
Yesac13
p.1 #16 · Nice little tripod for hiking and travel
The funny thing is, in the past, I passed on the smaller travel Slik tripods because of the low 4.4 LBS load rating. Turns out Slik was pretty excessively conservative in their load ratings. I briefly owned a Manfrotto BeFree tripod with a 8 LBS load rating. The Slik I own is stiffer! It however starts to flex a bit too much if you make the legs wider which is different vs my other tripods. I never use the legs wide, I just shorten the legs to get lower.
The one most similar to my old Slik is this one at B&H. It looks exactly the same but is 2" longer folded and has a different head (much better than mine). It will work fine for a 3.5 LBS camera, the heaviest combination I had on it. Most times, my camera/lens combination is just under 3 LBS.
https://www.bhphotovideo.com/c/product/1778828-REG/slik_611_903_sprint_mini_iii_travel.html
The center column is in two pieces, you can remove the bottom half to further reduce the weight. Only 1.9 LBS and removing that bottom half of the center column will push the weight down a hair.
I know, 4.4 LBS rating seems too low but it is legit stronger than that. Stiffer than others twice the rating somehow. Just lower it instead of widening the legs, tho. So this is a worthy backpacking tripod that weights 1.9 LBS. Just putting out an alternative tripod.
Jan 23, 2026 at 04:57 PM
gdanmitchell
p.1 #17 · Nice little tripod for hiking and travel
As I’ve written before, I normally use much heftier tripods. (A high-end RRS with the BH-55 head or, for something a bit lighter, a Gitzo mountaineer in large size with an Acratech Ultimate Ballhead.) But I also have a littel tripod quite similar to the one you mention, equipped with the very smallest RRS head.
By “serious” standards it is too short, not stiff enough, and has a head without full adjustments. But for something purposes (emergency use while travelling, sticking into a very small pack) when I don’t need a tripod for all of my shooting, it can be a useful tool.
Jan 24, 2026 at 11:20 AM
KankRat
p.1 #18 · Nice little tripod for hiking and travel
If it's good enough for Ken Rockwell, it's good enough for me!
?si=0xPS-G3AzEZmkbFn
Looks pretty sweet.
Jan 25, 2026 at 06:31 PM
gdanmitchell
p.1 #19 · Nice little tripod for hiking and travel
Ken.Rockwell,eh? ;-)
Jan 26, 2026 at 01:32 AM
EB-1
p.1 #20 · Nice little tripod for hiking and travel
Is that a joke?
Jan 26, 2026 at 02:11 AM
